Coolers for towing...
Old Nov 16, 2009 | 01:43 PM
mjferguson's Avatar
I am going to install an aftermarket hitch on my 2006 MDX (Touring edition). I see things our there about the coolers needed for the transmission and power steering? I haven't been able to find mention of them here. Are these needed and/or does the 06 come with these already? I will only be towing a very light trailer or Jetski. Don't want to mess anything up by not adding coolers if needed, but also don't want to spend all that money if not. :-)
Old Nov 16, 2009 | 07:48 PM
FiftyFive's Avatar
Moderator Alumnus
I would do it right the first time. The 2004-2006 transmission isn't the worst Acura has made but i wouldn't take any chances. Plus i think they can void your warranty on transmission/power steering components if they found out you have been towing without the coolers.
I would at least get the ATF cooler, I can provide you with instructions for everything if you feel comfortable doing it yourself. It could save you a pretty penny.
Old Nov 17, 2009 | 03:07 PM
mjferguson's Avatar
Thanks for the input. I would like to do this right, but I can't see paying the dealer $1100 for a hitch install. Are the coolers pretty simple to install? I am no machanic, but I can definitely handle a simple install if I have some detailed instructions. Any idea on the cheapest place to get both coolers?
Old Nov 18, 2009 | 01:24 PM
Majofo's Avatar
acuraoemparts has the OE cooler kit for ~$130 + s/h.. easy install. You might already have it installed, check your radiator for this bad boy.. should sit behind, if you see something similar in front it's the p/s cooler. If you don't have the OE kit or it's a little out of your price rance, you could get a B&M aftermarket cooler for about half that price but you'll have to figure out the pipe fitting & mounting yourself (not a biggie).
Old Mar 6, 2010 | 04:11 PM
mjferguson's Avatar
Sorry for bringing this old post back to life, but I need a little help in identifying if I have the ATF cooler already or not. I am thinking not, but if someone could help with exactly where this sits I would appreciate it. In teh front of the radiator I see two bars running the length of it, doesn't really look like the bars in the picture above. Behind I see two large fans, not much else? No real machanical ability at all as you can probably tell from my post, but any assistance would be appreciated.
lanechanger
Oct 13, 2015 10:56 AM
flybyglass
Sep 24, 2015 01:12 PM
ghuns
Sep 16, 2015 04:26 PM
Sep 14, 2015 10:09 PM
EPS CL
Mar 19, 2005 07:46 PM
