Cleaning between the seats?
Old 01-17-2011 | 05:54 AM
Kyin01's Avatar
I have an 03 MDX so i dont know if they 'improved' on this yet but... on the 03 MDX the space between the front seats and the center console is like a black hole. When you drop something its almost impossible to ever get it back. there is literally less then an inch for you to squeeze your hand in.
Has anyone found a way to clean / pick things up from there?
Old 01-17-2011 | 07:22 AM
007Acura's Avatar
try moving the seat all the way forward and up... then try to get it from the second row behind the seat & console
Old 01-17-2011 | 07:48 PM
Dentgirl's Avatar
If its dust or small trash use an air gun to blow out. If its something larger get a large screwdriver 18 inch or longer to work it out.
Old 01-27-2011 | 10:10 PM
acutech's Avatar
Dentgirl is right. If you don't have a big compressor and tank, Ask your mechanic to stick an air gun on the sides of the seats, and blast away. It'll blow almost anything out, into the back seat floor
Old 01-27-2011 | 10:11 PM
acutech's Avatar
Dentgirl is right. If you don't have a big compressor and tank, Ask your mechanic to stick an air gun on the sides of the seats, and blast away. It'll blow almost anything out, into the back seat floor. This works on every car I do it on.
Old 01-28-2011 | 11:59 AM
AgentHubcap's Avatar
I remove the seats once a year to clean the carpet nice and good. I find a ton of change, too.
mlody
12-04-2019 02:11 PM
blacktsxwagon
10-27-2015 10:12 PM
Desert Ridge
09-27-2015 02:37 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
flybyglass
09-24-2015 01:12 PM
Quick Reply: Cleaning between the seats?
