Check Trailer Stability, Check VSA, Check SH-AWD
Hello I’m new to this forum and wanted to share some information with you guys, about a recent problem that I had and fixed. My 2011 MDX base was giving these messages intermittently:
Check Trailer Stability Assist, Check VSA, Check ABS System, Check SH-AWD system, and sometimes also check TPSM system. During this, the MDX will only show it’s using front wheel drive. Brake lights work fine, checked fuses, good. Tire air pressure good. I noticed that sometimes when I tried to shift from park to drive with the brake pedal pressed, I couldn’t shift out of park, had to try it a few times for it to work. So I replaced the brake pedal switch and that turned out to be the problem, it is now fixed.
ncius (11-02-2023)
Hi.
Do not worry about the SH-AWD System by default it will disable itself with some OBD-II codes.. First we need to know what codes popped up so If you could get the codes we could further help you.
Right now I am only guessing but a faulty ABS Speed sensor can pop up all of those issues.
2010 Acura MDX abs, vsa,sh-awd and check stability trailer assist.
I also have a 2011 Acura MDX and was getting these same error messages. Based on the post by Shawngs300, I replaced the brake pedal switch. My MDX is now fixed.
BwaAnthony
1G RDX (2007-2012)
04-02-2020 07:15 PM
aggie07
4G TL Problems & Fixes
08-10-2019 12:44 PM
rondo717
02-28-2019 12:50 PM
angeljr8282
07-31-2018 10:49 AM
