Changing Battery on 11 MDX
Hi guys, so I was looking to swap out my battery on my MDX. Apparently the stock battery has no holding strap of any kind and it is REALLY difficult to lift out. Does anyone have a technique to get out short of buying a battery carrier ?
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
Part NO 2/17
It most def has a tie down strap!
Part NO 2/17
Part NO 2/17
There is a bracket that holds it down if that is what your referring to. But I am talking about a handle that would enable me to grab it out. The interstate battery I purchased has one. I borrowed one of these from a local shop. - OEM Automotive tools - Built by GreatNeck » Battery Carrier Great tool !
justnspace (02-05-2016)
ha. You guys are funny. But with no strap, you are not getting this battery out. Maybe I dont have the stock battery, but there is literally nothing to grab in the tight spot its in. I got it out with the battery pulling tool pretty easily though.
Guess it depends on your strength. I slipped my fingers down both sides, squeezed hard to generate as much clamping force as I could and lifted straight up. I am almost 67 and don't think I could do it again in a few years.
You are right, there are no straps to pull it out with. I was able to barely squeeze in my hands down the sides and pull it out. It's even more tricky when you go to lower it back in. Like others stated, just squeeze as tight as possible until you can get it above the brace, at which you can set it for a brief moment to reposition your hands to have a better grip.
flybyglass
01-15-2016 07:00 PM
Inspire08
01-13-2016 09:41 PM
