Caster plates? A way to adjust caster
Old Aug 4, 2013 | 10:30 AM
pimpin-tl's Avatar
Has anyone ever found a way to adjust the caster on the 2nd gen MDX? Ours was in small accident with a pole, and everything was replaced but the caster is at 3.6 degrees which is at the manufacture limit so it's basically in red. This is creating a tiny pull to the left and we need a way to adjust the caster to get it adjusted slightly back into spec. Please let me know if anyone has a way or aftermarket products that can do this for the MDX.
Thanks!
Old Aug 5, 2013 | 12:36 PM
ls973800's Avatar
Looking at
Rockauto.com for 2012 Acura MDX I find a Raybestos Caster/Camber Cam Bolt Kit under suspension. It is Raybestos part number 616039 and list for $12.52.
It says it is a single offset of minus 1 3/4 degrees to plus 1 3/4 degrees.
Perhaps this will help?
Old Aug 5, 2013 | 12:43 PM
pimpin-tl's Avatar
Thanks for that. I will ask the guy I know who did the alignment if he thinks that will fix it.
Old Aug 5, 2013 | 12:46 PM
sounds like something is still damaged.
Old Aug 5, 2013 | 12:57 PM
pimpin-tl's Avatar
All suspension on that side was replaced. Nothing else can be replaced. So no idea what it could be.
Old Aug 5, 2013 | 01:19 PM
pimpin-tl's Avatar
Per the guy, those bolts won't work. Those are only mainly for Camber.
Old Aug 6, 2013 | 09:32 AM
ls973800's Avatar
That's all I could find. Hopefully someone else will come up with a better fix.
Good luck
Old Sep 3, 2013 | 03:02 AM
TheWrench116's Avatar
FLETCH
sounds like the body shop didn't straiten the unibody back out seems like they just eye balled it got it close and gave it back to you. I would see if another shop can put it on there rack an check the straightness out see how twisted it is and weather it can be fixed.
Old Sep 6, 2013 | 06:58 PM
pimpin-tl's Avatar
They put it on the laser alignment and showed me the sheet. The frame was never bent.
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
lowgrowl
Sep 26, 2015 05:18 PM
flybyglass
Sep 24, 2015 01:12 PM
