B1 service
Received 7,772 Likes
You can quite literally type "Acura B1 Service" into Google and the first result is this:
"A" Service - Oil change and multi-point inspection
"B" Service - Oil & filter change and multi-point inspection
"1" Service - Rotate tires, check tire pressure and condition
"2" Service - Engine air filter & cabin air filter replacement
"3" Service - Replace transmission fluid and transfer case fluid (if equipped)
"4" Service - Replace spark plugs, timing belt service (if equipped)
"5" Service - Replace engine coolant
"6" Service - Rear differential fluid service
And the second result is an abundance of Acurazine posts detailing the same.
‘24 MDX A-SPEC
TL260power
01-31-2016 10:18 PM
mlody
01-15-2016 07:22 PM
