Acc outlets acura 2010 won't work
Hi,
Two ACC OUTLETS quit on me . The rear one (in the trunk ) works fine though.
I looked at the manual and it states that both ACC OUTLETS protected by single fuse.Is it correct? Also it is pretty odd that both went bad while I plugged power inveter to it .Please help me
Stay Out Of the Left Lane
We have an 07 MDX and the two ACC outlets are protected by two different circuits. The rear outlet is protected by fuse # 5 which is a 10A fuse in the rear fuse box. The front outlet is protected by fuse #9, which is a 15A fuse in the interior fuse box. I also see a listing for fuse #32 which protects something listed as "ACC" and is a 10A fuse - may be the outlet in the center console arm rest. Check your owners manual and in the back there should be listings for the various circuts and which fuses protect them, but suspect it will be very similar if not the same.
nsl752
14
12-06-2016 07:32 AM
