Is the 3.7 engine of the 07 MDX rebuildable
Hey guys,
I rebuild marine engines all the time, after all they are just good old SBC or BBC but I was wondering about those Acura engines; are they rebuild-able?
I mean the same way we rebuild chevy or Ford engine... reboring and honing cylinders, oversized pistons, different cam bearing sizes etc?
What abut the heads, can they be machined and the valves replaced?
Or the only option is to drop a new engine/heads?
Thanks in Advance
Thanks in Advance
hmmmm.... this site shows they only sell the standard sized and not the oversized pistons...
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
They scrap them much sooner, because of stricter pollution requirements.
Then find out how to make minor part swaps, to reposition the accessories, for a lefthand drive (USA) engine bay.
You might need a usdm oil pump and crank position sensor.
Look into getting a used motor from japan.
Originally Posted by Honda
The J-series engine was designed in the United States by Honda engineers. It is built at Honda's Anna, Ohio engine plant.
Hey guys,
Thanks in Advance
Thanks in Advance
You can rebuild them but the max bore is 90mm. Going past that and you decrease the strength of the liners quite a bit and soon end up in the jacket. It'd be better to get new sleeves, IE darton, put in rather than rehone and deal with weak walls, etc.
that with some custom coated pistons and the J37 you have will be putting out a ton of power.
You can also do a 3.6L by using J35 block and J37 crank. J35 is a much more common engine.
benny_jdm
01-31-2016 06:15 AM
