2013 Acura MDX, electronic problem.
Old 10-29-2019, 12:13 AM
6th Gear
Srey65's Avatar
Hello
I have a 2013 Acura MDX that suddenly stop working the driver for controls. I can't lock or open any doors from the driver for control. Lights are pit and I have noticed that when I lock my SUV with ant of the keys, I don't hear the beep and neither I can't open the rear door. Also, the panic key does not work. I don't know if both issues are related.
First, i noticed that i have to close the for to make those locks keys work, the lights were working properly and them started failing, then i have to open the door just a but to work and now neither with for openor close i can't lock or open the doors from driver side, neither thru are lit.
What should I do? Please advise me.
Regards.
Old 10-29-2019, 06:06 AM
Carpayment4life's Avatar
Opening and closing the door will change the preasure on the wires between the door and the chassis. You probably have a bad cable harness and will need to take the door panel off to look at it.
It is easy to change and the is a DIY on this site, by Skirmich.
door harness install
Old 10-29-2019, 04:48 PM
6th Gear
Srey65's Avatar
Thank you, I will try that
Old 10-30-2019, 06:43 PM
AcuraAddicted's Avatar
Most of these issues are usually caused by loose wires in the driver door harness. You can diagnose it by looking at the wires, wiggling them a little and seeing if any one of them is loose.
It's a $25 part and very easy to replace.
Here's a detailed video on how to do it:
Old 10-30-2019, 08:25 PM
6th Gear
Srey65's Avatar
https://youtu.be/aZRB1A1aIpY
Thank you for the information, I haven't try yet do to my job, but i will check it out as soon as I have time. Thank you again
Old 04-16-2024, 10:26 AM
Maximus3001's Avatar
Hello
Regards.
Spoiler
saddle
1/2G MDX (2001-2013)
07-23-2019 08:41 PM
hotrod351
03-06-2017 06:13 PM
chiu0nthls
3G MDX (2014-2020)
09-28-2015 03:46 AM
xgliu128
3G MDX (2014-2020)
01-14-2015 05:39 AM
Quick Reply: 2013 Acura MDX, electronic problem.
