2009 MDX false oil change indicator and engine stutter on startup
Hi Guys,
I have few issues right now:
1. My oil change indicator keeps turning on despite changing the oil and resetting it at the dealership. I think it's the oil pressure sensor. Is it? Is this a common issue?
2. My engine stutters after I start in the cold. Once I give it some gas it gets better.
3. SH-AWD Check emissions light. Read some posts so I'll try tightening the gas cap.
4. I shut off the car and I can still hear the car fan (radiator fan?) still running. I had this issue fixed before at the dealership but the issue is back again. Sometimes it does this sometimes not.
Any ideas?
Any ideas?
If your dealer did not help, then you need to go to another, all the problems that you listed can appear due to 30 different faults.
I don't know anything about cars but Scotty on YouTube suggests a fuel injector cleaner and cleaning the throttle assembly as likely solutions.
Commanderchop
04-26-2022 05:36 PM
