2009 mdx
Old Oct 11, 2019 | 10:26 AM
grip1968's Avatar
2009 mdx
This morning I start my mdx up and the check emission light and sh-awd light came on, I’m thinking it might be one of the o2 sensor going bad or bad. Anyone ever experience this issue.
Old Oct 11, 2019 | 08:01 PM
grip1968's Avatar
So I guess no one have had this issue with there MDX.
Old Oct 11, 2019 | 08:55 PM
Midnight Mystery's Avatar
Null and proud of it
Very common. Mine does it occasionally.
In my RDX, I think it's the fuel filter.
Go have a scan tool hooked to it and pull the codes, weather they're stored or throwing a light thry should show on a scanner. Auto parts stores usually do this for free.
Old Oct 11, 2019 | 10:16 PM
it could be a multitude of things; from a bad battery to the o2 sensor, like you said...
you need to troubleshoot, otherwise no one will know what is wrong with your car...
to troubleshoot; pull the battery's negative cable for a minute to reset the code...if code comes back you know you have a real problem with emissions.
it could even be a clogged EGR valve.
go investigate.
Old Oct 12, 2019 | 01:53 AM
Skirmich's Avatar
Without the codes you are looking at a myriad of possibilities…
SH-AWD disables itself with ANY ECM Code related to Air and Fuel so no need to worry about that just yet.
Old Oct 13, 2019 | 10:17 AM
grip1968's Avatar
The code I got is P2413, EGR valve. I’m going to try and clean it and see if that’s work. If not then I will replace it.
Guzzy
1/2G MDX (2001-2013)
Mar 28, 2017 08:45 PM
o3jeff
Jun 2, 2015 09:49 AM
medracr
Sep 21, 2010 08:53 PM
