2009 Acura MDX Front Outlet Power
5th Gear
I just bought a 2009 Acura MDX and I think it may have an electrical problem. I put my car charger in the front outlet and when I turned the car on the navigation, radio and charger had no power. I thought I may have just needed to change the fuse.. So I took the charger out... About an hour later I came back to my car to go drive to get the fuse and just for the heck of it I decided to try and push the power on the radio and all of a sudden the navigation, radio and power outlet came on. Next time I went to go use the car once again no power to navigation, radio and power outlet. Is this a known issue with the 09's??
mrgold35
Power outlets are rated at 120v/10amps or less. Something is pulling more power causing the outlet to act like a circuit breaker and you have to turn the MDX off/on to reset it. Does this only happen with the car charger plugged in (car charger pulling too much power)? Maybe there is the wrong type of fuse for the outlet?
I have a power outlet in the cargo area on my 2011. Does it do the same thing with that outlet with the charger?
freshy03 (03-24-2014)
5th Gear
Been testing it for the whole day. Sometimes it will come on even with the phone charger plugged in. Sometimes it won't come on and I have to do what u said "turn it off and turn it back on". One time it just came on by itself while I was driving and then turned back off
mrgold35
That sounds like an intermittent problem like a bad wire and/or a connection problem with the outlet. Was a aftermarket upgrade added to the MDX like an iPod connection, alarm, remote start or hard wire radar detector?
5th Gear
I took it into Acura and they said it was a loose relay wire... Not sure how it got loose but it is working now.... I just added remote start to the car yesterday but the problem was happening before that. Are there any known issues for the 2009 Acuras?? I want to have the dealer fix everything before my 60 day warranty is up
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
