2007 MDX maintenance recommendations, again
Old Oct 9, 2012 | 05:46 PM
kandwsmom's Avatar
7th Gear
Last time my dealer tried to sell me on additional maintenance you guys came through. I did the one fix and the others came due through maintenance minder--just like you said.
Which leaves me these questions: I have about 83,000 miles on the 2007 MDX with tech. All scheduled maintenance performed. Dealer suggests I do the following: power steering fluid flush $100; coolant service $130; 3 part fuel system service $180. I live in Houston, TX if region of US makes a difference.
Do I need these, or not?
Old Oct 9, 2012 | 09:11 PM
TLtrigirl's Avatar
3G TL/2G MDX Owner
power steering fluid- flush only if dirty otherwise there is nothing in the OM that gives an interval. if you get the recent TSB done then you may not have to worry about this. though getting it done certainly won't hurt it. coolant, i believe is MID 5 or up to 10yrs (memory is a little fuzzy)? and the fuel service is an upsell. unless your car is running weird, it is not really needed.
so...up to you.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
copmagnet82
3G MDX (2014-2020)
71
Nov 5, 2015 08:29 PM
Ponsey_Scheme
Oct 23, 2015 09:16 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
