2006 Driver Window Will not roll up or down help!
Old Nov 9, 2017 | 10:59 AM
playerz007's Avatar
Hi all -
I am working on my 2006 MDX. The initial problem was the drive window regulator needed to be replaced. The cable on the regulator was broken. I replace the window regulator, but the widown will not move up or down. I read alot of posts about the drive door subharness. The 'DIY: Replacing Door Sub-Harness' has a drifferent harness as my 2006. Does this DIY apply to a 2006? I looked at the fuses, peeled back the subharness looking for broken wires - did not find any broken wires. I am stumped now, is there anything else I can look at.
Any help will be appreciated.
2006 MDX.
Old Nov 10, 2017 | 03:12 PM
AlanW's Avatar
2006 NBP TL MT6/ 02TL-S
I take it you do not hear the window motor running? If you hear the motor running, the problem is in the regulator.
If not, and the fuse & harness is OK, most likely there is a problem behind the door panel, maybe you forgot to re-plug in the motor harness or the plug under the window switches or some other problem with them. I'd take the door panel back off and check everything.
