2004 mdx p0741
Old Jul 23, 2020 | 10:21 PM
richard203's Avatar
5th Gear
2004 mdx p0741
Hi i just got a p0741 code the car shifts fine i was wondering if this transmission is sealed or I can change the fluid? another question is where is the torque converter clutch solenoid located at? thanks
Old Jul 26, 2020 | 08:53 PM
acuratech481's Avatar
Code of death...transmission has an internal hydraulic fault with the torque converter circuit. Put a transmission in it...
Old Jul 26, 2020 | 09:48 PM
richard203's Avatar
5th Gear
the car drive fine tho
Old Jul 26, 2020 | 10:01 PM
perhaps a sensor is unplugged or has gone bad?
Old Jul 26, 2020 | 10:04 PM
richard203's Avatar
5th Gear
thats what im thinking do you guys know where the torque converter solenoid at?
Old Jul 27, 2020 | 02:42 AM
Skirmich's Avatar
In my experience even when the car runs fine, The P0741 is rarely very very RARELY an actual issue with the Torque Converter Solenoid....
I would say 99% of the times its the telltale sign of the impending doom (Transmission Dies).
Old Jul 27, 2020 | 03:24 AM
richard203's Avatar
5th Gear
I was hoping it was the solenoid that goes bad. =(
Old Sep 23, 2024 | 09:27 PM
Glonotamechanic's Avatar
3rd Gear
did you managed to get this fixed? I’m thinking of doing a flush mines is slightly overfilled but I’m getting this code.
Old Sep 23, 2024 | 09:37 PM
richard203's Avatar
5th Gear
I tried flushing, and changing out the solenoid both didnt work and at the end I have to go to the expensive route which is changing out the transmission.
Old Sep 24, 2024 | 02:42 PM
3rd Gear
ok I will just wait till it blows then(had one blow on my civic b4 due to a sensor popping out) as of the solenoid where is it located? I know for our model 03-06 mdx it doesn’t have the solenoids accessible. It’s under the two tube piece and I have one tube piece. Idk which one is what so I’m not doing anything there. I will try to see if my obd2 can do tcc diagnostics if it’s engaging ima just let it be. Seen people drive 80k miles with this code n seen people only drive 100 miles. Odd. Anything anybody can offer me to do b4 I change it.
Old Sep 24, 2024 | 02:44 PM
3rd Gear
how much they charge you for a new transmission? And please tell me Yu got it rebuild
4th Acura
1G (01-06) & 2G (07-13) MDX Photograph Gallery
Jul 3, 2020 06:45 AM
Souperdave816
1/2G MDX (2001-2013)
May 12, 2020 02:53 PM
edesoto
Oct 24, 2015 09:53 AM
rsinger
Feb 16, 2010 11:28 AM
