Is 11 mpg normal???
Is 11 mpg normal???
We had our new 2012 MDX for a couple of weeks now. First tank, we averaged 11.2 mpg. Second tank, we are looking at 11.8 mpg. Will this get better after the break-in period? This is with mix of 70% city, 30% hwy.
StayAtHomeDad
A couple of weeks is just too soon to project what the MPGs will be. Just give it a couple thousand miles and then you can have a better idea. 11mpgs is definitely low, but I don't know about your driving habits or where you live.
My new 2012 MDX with Tech starts from 16.0 and gradually climbs to about 18 in city - haven't done sufficient highway miles yet.
So 11 mpg sounds very low unless you live in downtown with a light at every block.
I know the MDX has a larger engine and is heavier, but our Honda Pilot AWD routinely gets about 14 MPG in the city. So 11-12 for an MDX makes sense for a new vehicle that has not been broken-in fully.
Our Pilot doesn't have a MID, but I figure my Wife's avg speed is < 20MPH. My average MPH is routinely < 27 and she has a much worse driving environment than me. She's rarely on highway and lots of stop lights and idle times. I bet the OP is <20 MPH when he gives the data being asked. Most people with sucky MPG will have < 20 MPH.
The best we have done in the Pilot is 25MPG with 100% highway driving- my guess is that would be tops on an MDX as well.
We have a 2012 with around 1000 miles and in the city we get around 14mpg and highway around 20-21. But, like others have said, 11mpg isn't necessarily out of line for the first few thousand miles (or more) if your traffic conditions cause for a lot of stop and go. The beast weighs almost 4600lbs, so getting it moving takes a bit of fuel.
3G TL/2G MDX Owner
here we go again...
11 mpg can be normal IF you sit in traffic all day. stop and go will eat the MPGs. idling in traffic or in front of your house you will yield ZERO MPGs.
i've seen my MPGs go from almost 25mpg at 65+ mph to 14mpg with the dealer techs stomping on the gas for the however many miles they were trying to reproduce stuff in the car.
my typical avg MPH is about 25-26 with avg MPGs at 16-17 MPGs.
i've gone all hwy (>60+ mph) and avg'd 23-24 mpg. when i avg 45mph the MPGs hover around 21-22 and light on the throttle. lead foot will drop the MPGs.
OP- point being if you avg <15-18 mph, it is very possible to get 11mpg. this just indicates you sit in traffic all day. and the MDX is a heavy beast to get moving. once she gets up to hwy cruising...newton's law...she is quite an efficient animal.
The following 3 users liked this post by TLtrigirl:
Wife took the car for a 50 mile trip before I can get the avg speed prior. The avg speed is now 20mph with avg 18mpg. I will check again after next fill up.
I have no problem with 11mpg if the car was advertised as such. Yes, we live in the city and yes, we are in traffic sometimes. But that's why they have a CITY estimate. What's the point of advertising 16mpg city if it's not true city estimate. Maybe they should call it 16mpg granny slow suburban middle of the night estimate.
StayAtHomeDad
3G TL/2G MDX Owner
this is why justn asked for a avg mph over a % of city vs hwy b/c everyone's city vs hwy is different. some people's hwy is city.
i believe the EPA estimates are measured at 25 mph for city. there is a disclaimer on your window sticker (if new) saying that it is an estimate and may vary based on conditions and it gives a range of like +/- 4-5mpg. if you live in a metro area...then you're probably on that low end and a prius would be better for MPGs. for roadtrips and such...the MDX fairs pretty well considering.
The following 2 users liked this post by TLtrigirl:
HEAVY_RL (01-02-2013),
justnspace (08-21-2012)
3G TL/2G MDX Owner
it should reset the avg mph you've gone for that given tank or whatever you are measuring against.
i reset mine after topping the tank off. my recent mostly hwy trip (65-75mph) and a few miles to get to the hwy (avg 25-30mph) yielded around 47 mph at it's highest for 35 miles.
huh? the first sentence doesn't make sense with your 2nd sentence. maybe i'm just reading it wrong.
StayAtHomeDad
I don't know if it works the same way for all years, but my 2012 can be programed to reset at each fill up (I think that all can be programed for that), and also that the time/speed thing gets reset every time you start the car automatically
3G TL/2G MDX Owner
the speed screen is independent of the trip mileage. so you have to reset the trip odometer (A/B) from the temp/oil life/trip odometer screens (select trip A or B, press and hold reset. then go into trip computer to reset the avg speed from that screen. then all of your trip computer screens wil be at zero.
stay on the avg speed screen. press and hold reset/select. it will zero out.
3G TL/2G MDX Owner
yes^^^ this would make it much more accurate. this is why it should be based on a tank of gas not short trips. i think your explanation is what confused me. now that you are clarifying...it makes a lot more sense
Have you reset the MPG since you bought it? It could of spent hrs idleing at the dealer after test drives, waiting to be washed a few times, etc which will make it lower. I average 21.0 mpg according to the computer with an average speed arpund 40mph.
I have nicknamed my mdx The Beast because it.s a lot more vehicle then I expected. 16 city is what I get with not much better hwy. but my two long hwy trips were fully loaded with people and gear sooooooo. Now looking for a commuter car. Tsx was too much road noise, Tsl was up there in $$ for slamming 25 k miles per year
A tank or two ago I was I reached 24 mpg on the highway at 65 mph. In the city with traffic I average 14 mpg.
Rich and Famous
16 - 17 City
21 - 22 Highway
Keep in mind ... your drive style in your home area may differ significantly ..
Some data points from a 2010 MDX tech/ent with added weight of roof rails and sport running boards, fully broken in at 23k miles. Drove NJ to Asheville NC, then down to Atlanta GA, then back up to Roanoke VA, then back to NJ. Over 10 days. 3 adults and one kid, trunk totally full of luggage. Road trip distance was probably nearly 2000 miles.
NJ to NC : 19.2 mpg running at about 70 mph mostly hwy, a few jams along the way.
NC to Atlanta, GA: 19.5 mpg with a few detours off the highway to avoid jams.
Atlanta GA to VA: 21 mpg highway - no jams doing 70 mph
VA to NJ: 22 mpg highway - no jams 65 mph
Used Costco 93 octane most of the way ( up to 10% ethanol )
Also found that on stretches where I was forced to drive at 55-60 mph highway, mpgs can improve quite a lot - got a 23 mpg reading on a slow stretch of highway where I did 55 mph steady with no stops required for 30 or 40 miles.
And finally, when driving around in city conditions in the various places we visited, it was 14 mpg at best, though more like 13.5 most times.
The only mod I have is a K&N drop in air filter.
Overall, i would say I am satisified that the car meets specifications. While I wish I did not have to drive like a grandma to get the best mpgs, I'll live with it to drive such a capable machine. Really love the response when I stomp on the gas for overtaking.
Hope this data helps a bit.
I averaged a bit over 18 mpg on my excursion between Central NJ and Cincinnati. As I have a fairly "heavy foot", I think that fair enough for a 4,600lb SUV with AWD, four passengers and luggage.
