01 steering shake
Old May 28, 2010 | 02:26 PM
financedirect's Avatar
3rd Gear
01 steering shake
Hi everyone, recently purchased a used 01 with a known steering vibration issue but i cant seem to diagnose the problem myself so here are the details and hoping some of you can chime in.
The shake/vibration in the steering wheel happens under all conditions. If the car is at a stand still and i turn the steering wheel to the right and then let the steering wheel out of my hand i see the wheel pull to the left and visa versa. On the highway i can feel every imperfection in the road through the steering wheel. The vibration/shake isnt dramatic and does not shake the entire car, its mostly only a visual/feel through the steering wheel.
All comments will be greatly appreciated
Old Jun 1, 2010 | 10:19 PM
akord 97's Avatar
Steering rack? Power steering?
Old Jun 2, 2010 | 04:12 AM
Type34's Avatar
First of all, welcome to Acurazine
Until you said "from a standstill", I thought it was wheel based. I'm not sure I'm understanding "...and then let the steering wheel out of my hand i see the wheel pull to the left...", is the car turned off? If so, I imagine some self-correction is somewhat normal as the wheel no longer has power steering (vehicle is off).
Anyway, for the moment I'm ignoring the "from a standstill" comment and will ask the following:
  • Does the vehicle have aftermarket wheels?
  • If so, do you have hubrings? (i.e. are the wheels properly balanced on the hub?)
  • Aftermarket or OEM, are you sure the wheels are not bent/damaged?
  • Do the tires have unusual or inconsistent wear? (i.e. two are like-new, the other two are bald ... or is the inner tread worn while the outer is newer)
Vibrations through the steering wheel often start at the wheels/tires. Often times the wheels are not properly centered on the hub or a set of new tires + a vehicle alignment can provide the cure. This statement is what makes me lean toward wheels/tires: "The vibration/shake isnt dramatic and does not shake the entire car, its mostly only a visual/feel through the steering wheel."
Old Jun 2, 2010 | 02:35 PM
3rd Gear
thanks for the information. My X has stock wheels so im going to check if the problem is in the tires since they do have uneven wear. After i put on new tires and get an alignment ill keep everyone posted. Thanks again
Old Jun 3, 2010 | 02:46 PM
Type34's Avatar
Good luck finance. I have aftermarket 19's, but I recently had unmanageable shake in the steering wheel and it was because of my tires. After new tires with a fresh balance, the problem basically went away. An alignment would further ensure proper balance and tracking.
GL
Old Jun 8, 2010 | 04:58 PM
3rd Gear
hey Type34, thanks for the advise! New tires and alignment solved the issue. Thanks again
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
Euro4gen
Dec 12, 2015 03:14 AM
prbori
Sep 27, 2015 01:37 AM
