Best wheel fitment with H&R Springs
Hey Guys!
I was wondering if 245/35/19 with a 35+ offset and 19x8.5 will fit on my car lowered on H&R springs? I want a concave look with my wheels but I do not want to roll my fendors. Any opinions and suggestions will definitely help!
Yes fits back for sure no issues and no need rolled.
I tested with wheel exact setup above and I am on H&R sport springs
Fronts will be perfect
I just put 255/35/19 on 19x8.5 ET 35 and just had to slightly pull on front fenders to make it look better in my eye as it was to close to outside lip to me.
This pic is however a 275/35 19 on 9.5 ET 40 with lips rolled. But you can see how the fronts sits!
VTEC just kicked in, yo!
Natural camber from lowering the car. I'm guessing that's around -2.5 degrees; no more than -3. Very acceptable IMO, but of course that's just an opinion so it may not fit if you decide to install a rear camber kit and dial it back to -1.5 or so.
looking at the car, the fronts don't seem to have much extra negative camber from the drop. The rears appear to have a little. But with the size wheels he suggested there is still room to pull a little negative camber out closer to stock and still not rub with fender not rolled if so desired. There was quite a bit of space between top of tire and fender lip!
Drove on stock tires for 7 months ~10k miles w/o adjusting camber or alignment after H&R springs and tires still worn even across
Ok thanks guys!
Hankook V12 EVO 2 came in yesterday (245/35/19) front and rear
My TSW Bathurst Gloss Gunmetal (19x8 35offset) is coming in today as well!
And I didn't get a camber kit so I think it should fit fine.
Thanks alot guys
Thanks alot guys
Nice looking wheels! And those Hankooks are a great bang-for-the-buck tires. I had them on my last set of wheels and they were great especially for the price.
Can't wait to see them on!
I'm running H&R sports springs with 19" avante garde wheels....19x9.5 with 40mm offsets. tires are 245/35....setup is great with no rubbing whatsoever. The drop with these springs is perfect.
1fatcrxnem1
22
06-01-2018 01:23 AM
nuldabz
09-03-2015 05:49 PM
