Will the 20" wheels from the 2010+ Camaro fit our 2009+ TLs
Hello all, I have been doing some research to see if this setup would work on our cars but so far I have not came across any TLs using this setup. On the other hand, there are a couple of posts over on the Acura MDX forums showing that the wheels work on their cars.
The specs of the TL SH-AWD wheels are 18"x8" with +55 offset and 5x120 bolt patterns cb = 64.1
The Camaro wheels are 20"x8" +35 offset on the fronts and 20"x9" +40 on the rears with 5x120 bolt patterns cb =67
These wheels are OEM and are selling pretty cheap ($500-$400) on Craigslist. The tire setup I thinking of using would be 245/35/20 all around with Tein coilovers for the drop.
Whats your take on it and do you think its a direct fitment without any rubs or needing to roll fenders?
Here is how they look on the car.
This is up close.
This is up close.
spytter (10-16-2015)
David_Dude
Yes. There's a member here who has CV3's on his 4G TL. IIRC the specs on those are 20x9 et35, no modification either. I'd go with the same size/width all the way around. That's just my preference though. Good luck, nice choice!
I installed a set of 20X10 (+35?) with 275/35/20's on a 4G TL SH OMG AWD BBQ. The rear lip just barely needed a touch of roll. Like...another 3mm, and it would be clear. Also installed Tein SA's at the same time to lower it.
justnspace (07-08-2015)
Its usually what you expect with OEM wheels. They are durable but you pay the price in weight or money if you have a forged OEM wheel option like my previous EVO. I will try and post some pics once I have done painted them.
A lot have happened today....
I finished painting the wheels and they came out great. I used Dupicolor Satin Black and Matte Clear.
I covered the center caps with some 2.25" Acura decal.
The lugs for the Camaros are the same thread pitch as our Acura TLs 14x1.5. I went ahead and purchased a set of Gorilla Locking Lugs Wheel Locks Part# 71643NBC. It had a lot of great reviews and fits all 2010-2015 Camaro wheels.
I'm sure from a short distance away it wont be visible and that most likely an acura center cap will not fit, hence why he did that.
HeartTLs (07-14-2015)
Most Acura caps are 2 3/4, I need atleast 2 1/4. I found some blank after market caps but I was not planning on spending $50+ and then still having to use the Acura stickers on them.
Did they fit on the front too and are those studded snow tires?
