Stupid transmission question
Old 05-22-2016, 08:46 PM
outdoorlife99's Avatar
Just recently had my trans. Rebuilt at 150,000 in an 06 TL, I don't think they put dw-1 back in it as its more of a grey tint than red. Anyway have been waiting on the 10,000 Mark so I can do a 3 quart swap and every 10,000 after till I know what's in it. But, question is, why does it matter or does it if the trans. Was rebuilt with an after market kit? I'm sure it's not Honda parts, it wasn't a crate trans. From Honda so does it really matter what's in it being not o.e.m. anymore?
Old 05-23-2016, 07:15 AM
Turbonut's Avatar
No problems with aftermarket trans parts. If assembled correctly, it will last for years.
Old 05-27-2016, 11:34 PM
Yea I understand that, what I'm asking is if it's aftermarket parts is dw-1 make a difference one way or the other?
Old 05-30-2016, 02:10 AM
AlbinLee's Avatar
Just doing some critical thinking, from an engineer's perspective...
Although parts in this rebuild may be aftermarket, the critical load bearing components would most likely be identical in material and dimensions to the Honda/OEM equivalent (or so we hope ). That being said, the recommended OEM transmission fluid should still be best suited for the job. The biggest influence on lubricating oil for tranny should be material, material interface/tolerance, and temperature. Since DW-1 has superseded Z-1 in Honda auto's, I would suggest that DW-1 is going to suit your rebuild very well.
PS. I am by no means an expert on aftermarket/rebuilt tranny's. Just giving you what my thought process would be, were I in your shoes.
Old 06-01-2016, 10:01 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
you should go back to the shop that did the repair as the fluid should be pink, not gray. Gray is a sign of moisture or failing components in the trans leaving debris in the fluid.
Old 06-02-2016, 11:40 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
^^^this.
Old 06-02-2016, 11:47 PM
I did an was told it was dw-1 with an additive Honda recommends. Anyone heard of this?
Old 06-03-2016, 01:23 AM
csmeance's Avatar
Honda does not recommend any sort of additive and only DW1!
Old 06-03-2016, 11:51 AM
truonghthe's Avatar
Sound like a whole bunch of BS to me.
brent112
05-09-2016 08:16 AM
qwxilvr
5G TLX Problems & Fixes
05-07-2016 02:35 AM
Evilocity
04-22-2016 09:33 AM
DJMikeT
01-27-2016 12:03 AM
Quick Reply: Stupid transmission question
