Serpentine belt pulleys not lined up ?
Old 10-09-2016, 08:34 PM
3rd Gear
lucky777's Avatar
My first post so Hi to you all and hope your day is going great, I have a 2005 Acura TL and the guy I bought it from did an engine swap with an 06 and it seems to be running fine except the serpentine belt started chirping and squealing so replaced it and tensioner assembly but looking closely it looks like the belt is riding closer to the motor on the lower idler pulley and away from the engine on the tensioner pulley? we are talking maybe 3/16 or so ? new alternator and power steering pump and pulley and the air conditioning pulley seems fine with no wobble so ? checked everything I could think of but looks to me like the power steering pump is to far away from the motor or ? I dont think you can put the crankshaft pulley on wrong? anyway not squealling now but new belt seems to be wearing fast, is this normal ? tensioner pulley is vibrating and moving around more than it should it seems, any input would be appreciated
Old 10-09-2016, 09:08 PM
01acls's Avatar
Old 10-10-2016, 10:52 AM
3rd Gear
lucky777's Avatar
thanks but my problem is with the serpentine belt, not the timing belt
Old 01-16-2017, 09:17 PM
4ndr3's Avatar
Serpentine belt not lined up
Hi lucky777,
i have 07 TL Type S, and I have the same exact problem like you.
do you figure it out already?
i change everything but still not line up.
thx before.
Old 01-16-2017, 10:23 PM
3rd Gear
lucky777's Avatar
Originally Posted by 4ndr3
Hi lucky777,
thx before.
So after replacing everything but the crankshaft pulley I bought a oem serpentine belt from a acura dealer and it has been working fine for the last 1k miles with no sqeeling or chirping? It kinda lined it self back up for the most part? Can't explain it but the belts I was buying at autozone and advance auto parts just didn't work well for some reason? So do try buy a belt from the dealer and pay the extra $ and hopefully that will solve your problem also
Old 01-16-2017, 11:30 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Hi, and welcome. I'm going to move this over to the model specific forum since it's mostly technical in nature and not so much new member introductions.
Hopefully you'll get more eyeballs on your problem there.
Happy motoring!
projektvertx
44
11-10-2019 09:07 AM
DerrickW
24
03-08-2017 01:42 AM
03max6spd
3G TL Photograph Gallery
14
02-14-2017 11:27 AM
uneedkhoality
1/2G MDX (2001-2013)
01-23-2017 03:39 AM
07tsx20
1G TSX Problems & Fixes
01-08-2017 06:26 AM
Quick Reply: Serpentine belt pulleys not lined up ?
