Oil Change. How often? Synthetic, Blend or Regular
#41
It is very common to see posts like this: What is better in the sand? Foam filter or K&N ? - ATVConnection.com ATV Enthusiast Community see post #3.
which indicate more silica in the oil.
Your experience does not match up with these. Unless the oil was also tested after using paper filters and the data compared it may not be possible to say if one allows more particles into the engine than the other.
The bottom line for you is that it does not matter since the silica readings are clearly not a issue.
#42
Here is another post: Threw away K&N's due to high silicon in UOA's | Engine Air Filters | Bob Is The Oil Guy
I am still not against using the K&N air filter but I would do a lot of investigating and run UOA to be safe.
IBankMouse
06-13-2020 12:53 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
