The Official "Does This Fit My Car?" Thread
Old 06-28-2008, 01:08 AM
  #201
94 DC4 RS LSV/Turbo
stillhere153's Avatar
I think your best course of action is to either get all 4 swapped or minimum the fronts alone (if you swap the fronts alone it could alter your vsa/abs system)
Old 06-28-2008, 01:21 AM
  #202
I have car ADD
BLACKURA_NY's Avatar
Originally Posted by dchea03@hotmail.com
05 tl auto blk
my local bodyshop install the side mirrors w/ blinkers blinkers works but my (1)heated mirrors, (2) memory seats, (3) reverse tilt mirrors does not work wat can i do.... ???
install type s tail lights fits nicely but i it seems as though its not bright (is there LEDs behind the tailights or is it conventional bulbs could i get LEDS for it ???
hey al.. ill help ya out
when i installed my viper alarm.. i forgot to plug the harness back in... so that little part of the dash where the buttons for the mirrors are... will pop right off (standard interior clips) and just check the wiring harness... its a big thick plug, might not be plugged in
OR
you have a blown fuse
Old 06-28-2008, 12:53 PM
  #203
wps007's Avatar
Originally Posted by stillhere153
You got it... The diameter difference between 245/40-18 and 255/35-19 when compared to each other is minimal
Pm me when you do it... Def wanna see this
Have ordered wheels will be by the 4th will have both cars at ACURAZINE meet in Pismo in July
Old 06-28-2008, 02:37 PM
  #204
ade99's Avatar
I have another wheel fitment question.
2005 TL 6SPD
Brembo Brakes
H&R Sport Springs (1.4"F & 1.3"R Drops)
Looking at getting the ADR M Sport
18x8.5 +35 245/40/18 on all 4 sides
Will they clear the Calipers? And is there going to be any rubbing?
Old 06-29-2008, 12:10 AM
  #205
94 DC4 RS LSV/Turbo
2005 TL 6SPD
Brembo Brakes
they appear to clear... quick search on pics show that the spoke design appears to be brembo compliant... worst case a 3mm spacer would put you at the brink of barely clearing fender so you'd have to negative camber your wheels... but I dunno it looks like it clears...
Old 06-29-2008, 05:51 PM
  #206
redcamaro72's Avatar
what rims will fit on a 2007 tl type s
what other year acura tl's or type s rims will fit on a 2007 acura tl type s. I'm looking for some rims for puttting winter tires on but not sure which ones will work
Old 06-30-2008, 12:02 AM
  #207
94 DC4 RS LSV/Turbo
Both bellow clear factory brembos no problem
04-06 Base TL (5 Spoke)
07-08 Base TL (Split 5 Spoke)
Old 06-30-2008, 02:37 AM
  #208
Herro
NBPacuraTL's Avatar
hey stillhere, i hope you don't mind answering this for me. but offset affects the amount of lip on the rim right? But if the lip is the same, then it just changes how far the rim is pushed left or right in the wheel well?
Old 06-30-2008, 05:30 AM
  #209
94 DC4 RS LSV/Turbo
The lip width is determined by 3 factors
Wheel width
Spoke Design
Offset
Certain wheels are concaved causing a smaller lip, other wheels are flared causing a large lip... The offset also comes into play as some wheels are design for big break caliper clearance, these three factors come together aswell as the main design of the wheel to provide either a small lip or a monstrous lip... Finally the wheel width is the main characteristic for the lip as an 8" wide wheel will never provide the lipage width a 10" wheel will
Old 06-30-2008, 12:00 PM
  #210
Jokerman
jokerman826's Avatar
Year: 2004
Trim: Base (non-Nav)
Color: WDP
Item you would like fitment verified: 07-08 Headlight housing on a 04-06. If yes any modding required. Also does the 07-08 housing have the bi-Xenon type lighting as the 04-06. (low and high beams in the projector) Or will this have to be transfered from the 04-06 housing.
Old 06-30-2008, 03:18 PM
  #211
94 DC4 RS LSV/Turbo
Originally Posted by jokerman826
Year: 2004
Color: WDP
100% fitment verified by bforbrian & ua6spec
The only difference is the blinker bulb size... Projector does not require modification last I checked...
Old 06-30-2008, 11:18 PM
  #212
FizzyStatus!
ballinfizzle89's Avatar
Projector doesn't but the ballast is different. Will have to be custom mounted because the bracket and clips do not fit.
Old 07-01-2008, 12:20 AM
  #213
94 DC4 RS LSV/Turbo
good looking out fiz
Old 07-02-2008, 09:08 AM
  #214
NTMD8
jimsta's Avatar
Year: 2005
Trim: Base
Color: WDP
Item you would like fitment verified: 07-08 colormatched Splash guards, will these fit on the 04-06?
Is there any additional hardware needed to install them?
I know that A-spec requires removal of them, but if I only installed the front and rear lips any possible way to keep them on?
Old 07-02-2008, 09:29 AM
  #215
94 DC4 RS LSV/Turbo
They are the same from 04-08... Only difference is the part numbers for the specified vehicle color
As far as aspec installation and keeping the mud guards? If you don't install the side skirt you keep the front splash guards.... The rear aspec replaces the rear splash guards....
Enjoy
Originally Posted by jimsta
Year: 2005
Trim: Base
Color: WDP
Old 07-04-2008, 02:56 PM
  #216
Jokerman
I apologize from steering away from the normal routine, but, what do you mean by different blinker bulb size and for fiz what type of custom modification do you mean, you can PM me if you would like.
Old 07-05-2008, 03:18 AM
  #217
94 DC4 RS LSV/Turbo
Well foglight bulbs come in numbered sizes... 7447 something is base model and type s is like 1250.... I don't know the numbers off the top but its something like that
Old 07-05-2008, 08:28 AM
  #218
Looking for new mods
jguerra23's Avatar
I belive is 7443 for the front blinkers, atleast for the 07 base.
Old 07-05-2008, 02:32 PM
  #219
SlammedOnKonis
ifirahse's Avatar
Year: 2008
Trim: Type-s
Color: nbp
Item you would like fitment verified: I found all other numbers, but I can't find the bulb number for the vanity mirror light. Do you know it?
Old 07-05-2008, 04:33 PM
  #220
94 DC4 RS LSV/Turbo
should be 194 or 168
Old 07-07-2008, 10:01 PM
  #221
NBP REPRESENT
BlacuraTL-S's Avatar
hey man im looking to see if
these will work 07 tl - s
18x8.5 with 245/45/18
im 99% sure they will
Old 07-07-2008, 11:55 PM
  #222
94 DC4 RS LSV/Turbo
Tires should be 245/40-18....
245/45-18 is for a nissan maxima
Old 07-08-2008, 10:01 AM
  #223
NBP REPRESENT
doesnt the 45 mean more tread?
i thought the stock ones were 235/45/17?
Old 07-08-2008, 10:06 AM
  #224
zaino'd
jmkiang's Avatar
well you can't run the same tires on 17s and 18s... so my guess is get a set of winter tires for your stock 17s and put some falken 452s on ur legend gt
245/45-17 for the stocks
245/40-18 for the gt
Hey,
I ended up getting the Aspec rims. Would you still recommend 245/40/18? Would these tires rub (at stock height ATM but planning a 1" drop)? Why not 235/40/18s to stay closer to the stock diameter?
Thanks again!
Old 07-08-2008, 01:24 PM
  #225
NBP REPRESENT
forgot to mention +38 offset...that wont stick out right?
Old 07-08-2008, 06:11 PM
  #226
94 DC4 RS LSV/Turbo
Originally Posted by jmkiang
Hey,
Thanks again!
go with 245/4-18 for a little bit more lip protection
  #227
94 DC4 RS LSV/Turbo
your ok do it
Old 07-08-2008, 11:27 PM
  #228
wdp skyhawk
bigmoetl1's Avatar
year 2008
tl type s auto
wdp
want to know if these will clear brembos
20" menzari ms sport
no drop will run 245-30-20
Old 07-09-2008, 12:07 PM
  #229
bforbrian's Avatar
Year: 2005
Trim: 5AT Navi
Color: NBP
20x8 +31
20x10.5 +31
Stock brakes
Tein Basic Coilovers
Will not drop aggressively
Is this possible at all?
Old 07-10-2008, 01:55 AM
  #230
94 DC4 RS LSV/Turbo
Originally Posted by bforbrian
Year: 2005
Trim: 5AT Navi
Color: NBP
20x8 +31
20x10.5 +31
Stock brakes
the fronts will clear with a 235.... the rear will stickout way passed the fender, if you run 225 tires it might not rub if you roll... and with maximum camber you will be reducing ur contact patch by more than 75%
for purposes of force fitting these wheels i would say no
Old 07-10-2008, 02:20 AM
  #231
94 DC4 RS LSV/Turbo
Originally Posted by bigmoetl1
year 2008
tl type s auto
wdp
http://www.menzari.com/site_MSC04_msport.htm
possibly clears fronts 20 x 8.5 +35 at worst requires a 3mm spacer... 5mm can be used for an aggressive fit with some camber and 235/30-20 tires
you cannot go staggered for rears without rolling the fenders...
good luck
Old 07-11-2008, 08:07 PM
  #232
bforbrian's Avatar
ok so i realized the rims are
20x9 +31 front
20x10.5 +31 rear
Will the fronts even clear?
You recommend no? Can I just lower it right above the top of the tire and not have anyone sit in the back?
This is kind of what i'm talking about:
Old 07-11-2008, 09:51 PM
  #233
'10 Hyundai Genesis Coupe
Eoanou's Avatar
Do you know if the Type-S IM will bolt right in a UA6, also I need to know if I get the Type-S IM will I need to get the Type-S TB to fit or will it be fine?
Also do you know if the Type-S TB is bigger than the UA6, I don't know for sure but I think it might be 2mm larger.
Last, I need to know if the Type-S cam will bolt into a UA6, the Type-S cam is hallowed out so it weighs a couple lbs less than a UA6 cam, and its slightly more aggressive.
Oh and one more question do you think I can run all three mods with a stock UA6 ECU?
Old 07-12-2008, 12:11 AM
  #234
94 DC4 RS LSV/Turbo
20x9 +31 front
20x10.5 +31 rear
Damn B... you going hard.... if you going for the stretched look, and I believe that wheel is running a 225... it will be fine....bippu
Old 07-12-2008, 12:15 AM
  #235
94 DC4 RS LSV/Turbo
since the gasket bellow the intake manifold is the same, the 10mm bolts which hold the IM are in the same location it will bolt up no problem at all
They are the same... someone must of lied to you on this one
in order to get the best out of every mod, a custom tune would really provide you with more gains... emanage blue? would be a good option imo
Old 07-12-2008, 03:07 AM
  #236
bforbrian's Avatar
damn you are good... my boy IS running a 225.
So even with +31 offsets 20x9 and 20x10.5 they'll be okay?
I'm talkin about Maya's here
Old 07-12-2008, 03:24 AM
  #237
I have car ADD
Are you saying same fitment? definitely not the same cam-shafts.... and they do drop in.. I upgrade the cam-shafts on my BLACKURA to the type-s cams.
Type-s are hollow core , and yeah they are lighter
TL-P CamShafts
14100-RCA-A10 ACURA TL FR. CAMSHAFT
14200-RCA-A10 ACURA TL RR. CAMSHAFT
TL-S CamShafts
14100-RDB-A00 ACURA TL FR. CAMSHAFT
14200-RDB-A00 ACURA TL RR. CAMSHAFT
Old 07-12-2008, 04:34 AM
  #238
94 DC4 RS LSV/Turbo
WHOOPS... thanks for the correction I overlooked the part number real fast...
... still no gain if you don't piggyback...
Old 07-12-2008, 04:36 AM
  #239
94 DC4 RS LSV/Turbo
Are you planning to negative camber... cuz you will have to have something in there, I mean i see you are trying for straight bippu... again gonna try and sell my damn front camber kit, I have a brand new one from ingalls part # 35590....
for the rear you have a couple of choices
ingalls makes one
wicked also makes one
ps. get intouch with rodney and see if you can roll the rears
Old 07-14-2008, 07:53 PM
  #240
all work and no play
MWalsh9152's Avatar
ok I'm feeling lazy and dont wanna search no mo tonight
Year: 2008
Trim: Type S
Color: KBP
Item you would like fitment verified: I have Axis supermesh (similar to penta) 19x8.5 45mm offset with a 235/35 from my 06 5AT sitting in my store room. What size spacer is best, and what bore for hubcentric?
Quick Reply: The Official "Does This Fit My Car?" Thread
