De-Badging
Old 03-22-2007, 08:49 AM
JT22's Avatar
De-Badging
What is the best to de-badge the emblems?
Old 03-22-2007, 09:25 AM
06 TL
TL310's Avatar
dental floss & goo gone.
Old 03-22-2007, 09:29 AM
now with four rings
rimz's Avatar
goo-gone didn't do shit for me...i had to use a rubbing compound made by the same people that make turtle wax...worked perfectly...
Old 03-22-2007, 09:30 AM
06 TL
TL310's Avatar
it work for me. or tar remover.
Old 03-22-2007, 10:25 AM
pimpin-tl's Avatar
Blow Dryer or a Heat Gun to blow hot air where the emblems are to heat them up. Make them warm to hot where the doublesided tape behind them gets soft. Then you can use a old credit card to work it behind them and slowly start to pull them while working the doublesided tape off the metal. This is the safest way to do it. I would also have some Goo-gone ready for the left over residue.
On dark colored cars you might need to get some light compound and polish/wax to get rid of the marks that are left from the emblems.
Old 03-22-2007, 10:29 AM
~Da Nocturnal Cheetah~
darksom1's Avatar
Or this:
https://acurazine.com/forums/ramblings-12/place-round-here-i-guess-155445/
Just saved me $15!!!!
Old 03-22-2007, 10:56 AM
B A N N E D
Slammed_JDM's Avatar
blow dryer than some fishing string then some rubbing compund. Goo GOne is garbage...
Old 03-22-2007, 11:18 AM
My Garage not
wasupdog's Avatar
the easy and cheap way to do it:
1. use a blow dryer to heat up the emblems and then they will come off really easily with some dental floss
2. put some turtle wax bug and tar remover on the excess adhesive remaining on the trunk, heat it up a little, and start rubbing with your finger. wipe all the crap away gently with a wet paper towel and then repeat this about 3 times to get all of the adhesive off.
3. wash it and make sure to re-wax this area. you won't even be able to notice that there was a badge there before.
-i used goo gone before without the blow dryer and it didn't do jack
-don't use your fingernails or anything else on the paint, it scratches like a mother
Old 03-22-2007, 11:48 AM
05tlvietboi's Avatar
^^^ thats exactly what i did...
but you might have to go through a couple of carwashes... becaus eyou might be able to see the outline of it
Old 03-22-2007, 02:22 PM
gimme a 4G !!
Dedpheonix's Avatar
After debadging, I used the glass cleaner that I use on my kitchen table to clean the residue from the emblems and the 'gunk' came right off.
Old 03-22-2007, 02:40 PM
datmrman's Avatar
I would only add detailing clay before waxing. Detailing clay will remove all contaminants above the paint surface.
In the thread that darksom1 referenced, I used those products (in order) ONCE and it did the job.
Old 06-19-2007, 07:01 PM
MiaQbn23's Avatar
So I just took off the Acura and TL. Everything came off but there is a border around where the letters used to be... will they come off once I wax?
Old 06-19-2007, 11:22 PM
now with four rings
rimz's Avatar
rubbing compound then wax...will look flawless...
Old 06-20-2007, 12:06 AM
Treb
Trebor314's Avatar
I left my car in the sun for 3-4 hours used some spider wire fishing line and it came right off. Rubbed the heavy adheasive off with my finger then used the clay bar with some maguires 34. Polished it with maguires cleaner polish (medium cutting power) and a coat of polish (wax) on top of that. Never would know it was there.
Old 06-21-2007, 10:48 AM
'06 6MT WDP
Mike 06 TL's Avatar
Just did this last weekend. Looks 100x better without the acura & TL emblems. Very clean on WDP.
1. Hair dryer
2. Dental floss
3. Goo Gone (spray gel type)
4. Roll excess adheasive tape off with finger.
5. Clay bar
6. Zaino
7. Perfection
Old 06-21-2007, 01:48 PM
now with four rings
rimz's Avatar
7 steps...? ...okay 6 minus perfection...
for me it went:
1. dental floss
2. rubbing compound
3. wax
nonetheless, looks much better with both the Acura and TL emblem removed (originally i had only removed the Acura one)...
Old 06-21-2007, 03:04 PM
I have car ADD
BLACKURA_NY's Avatar
my was is the BEST way... you can never tell there was an emblem there
get rear-ended by an old lady. when the body shop replaces your trunk lid, just dont put the emblems back on!! looks great! can't tell there was any emblems before!!
JRC3904
08-03-2005 12:25 AM
Da_iLLeZt_TL973
2G TL Photograph Gallery
04-08-2005 06:29 PM
Da_iLLeZt_TL973
03-31-2005 01:20 PM
Jonesi
08-31-2003 02:32 PM
Quick Reply: De-Badging
