FOG-LED DIY-Very Simple
Old 11-19-2015, 11:41 PM
QuickTL07's Avatar
Ok here it is guys my first diy on acurazine.
I wanted to replace my fog lights for some time now, I decided to pull a trigger and buy something more expensive with good warranty and great reviews all over the web. This kit comes with lots of different cables for a simple plug and play install, I have no errors on dash, no extra work needed to be done. simply plug and play... this cant get any better or easier !
I paid 99.99 and here is the outcome.
Also I didn't had to take out the front bumper like a lot of you did when upgrading / installing fog lights to HID or LED and this is how I did it.
Lets Get Started
H8 bulbs
I really really like the quality of these LEDS, it has a big heat sink in the back to keep it cool, also it has a build in fan that wine up a little on rpm to keep the bulbs cool... The way they feel in your hand, they feel like quality and I really like them. They fit in the fog light housing nice, tight, and simple...
1. I took used a jack to lift the car a little, and turned my wheels to get some room between the fender and the tires.
2. I took 2 plastic bults / nuts whatever they are called, and also removed a screw on the bottom by the faster that holds the plastic in place, its a 10mm socket.
3. After that I had enough room to remove the stock bulb, and put the led in there.
4. There is a little hole by the front bumper, I put the wires there for easy connection also taped them so it wont come apart...
5. Turn them on, make sure everything is working and led lights up... If it does, I used zip ties to hold the wires in place.
This is a driver side that I did, it was so quick i forgot to take a pictures of the driver side..
The same procedure goes for the passenger, 2 plastic clips, and 10mm bolt on the bottom.
The outcome before pulling it out from the garage...
Even the cat liked it
First reaction... F-ing Awesome!
Took it for a spin through the woods where is pitch black. OEM HID
With LED On!
I'm very happy with them, I didn't get anyone flashing at me that they are to brite or someone getting blind by it... I would recommend them..
Now I'm thinking what can I do with OEM HID
David_BNSF (02-14-2022)
Old 11-20-2015, 12:39 AM
eastcoastguy's Avatar
Nice work! Not sure I like a $100 bill for bulbs but they do look nice! It looks like they match the OEM, I imagine thats just the camera, are they more white? My other issue would be glare but you mentioned that didnt seem like an issue.
My biggest issue with LED's is reliability. I am wondering how these will stand up to weather and use. I think the fan might get wet and is weatherproof?!
Thanks for the post!
QuickTL07 (11-20-2015)
Old 11-20-2015, 12:58 AM
QuickTL07's Avatar
Yes on their web site it says water prof and also they put the whole led in to a water while its working. I will post a link tomorrow.
Old 11-20-2015, 05:16 AM
MyGuti's Avatar
how close is the color of the fogs to the OEM headights?
Old 11-20-2015, 07:07 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Haha cat!
Nice writeup
Old 11-20-2015, 08:15 AM
QuickTL07's Avatar
Very close,,, I wish oem were little more white, but over all its looks good... no complains.
Old 11-20-2015, 08:16 AM
QuickTL07's Avatar
Haha cat!
Nice writeup
Thanks... I need to do a write up on my car audio build that I did lol but that will take to long
Old 11-20-2015, 09:34 AM
Be a better driver
RedRyder's Avatar
Those look great, nice job. If they last as long as they're supposed to, $100 is not bad.
Old 11-20-2015, 09:47 AM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
those look great! i would love to go this route but there is no way that thing is fitting in any car that has a CAI. our oem fog lights already hit the filter for the CAI and i'm sure this thing is much longer than the OEM plug.
that cat is hilarious!
Old 11-20-2015, 09:48 AM
Received 8,585 Likes on 6,631 Posts
Awesome!
Now about reliability, I wonder how long these will last..
Old 11-20-2015, 11:38 AM
jz113's Avatar
wow.. looks easy to do.. can i have a link where you got em please?
Old 11-20-2015, 12:52 PM
b3nsonx's Avatar
I have those too and they're awesome!
Old 11-20-2015, 12:57 PM
jz113's Avatar
is it pretty reliable? does it last long? and where do u get em? thanks
Old 11-21-2015, 09:30 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Picture of just the foglights on??
Old 11-21-2015, 10:20 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
nice write up, I will pick one of these puppy for my TL later.
Old 11-22-2015, 09:14 PM
vietxquangstah's Avatar
Amazon.com: OPT7 3,500Lm LED Fog Light Kit w/ Arc-Beam™ Clear Beam - 60w Crystal White 6K CREE (H11, H8, H9) Bulbs - 2 Yr Warranty: Automotive Amazon.com: OPT7 3,500Lm LED Fog Light Kit w/ Arc-Beam™ Clear Beam - 60w Crystal White 6K CREE (H11, H8, H9) Bulbs - 2 Yr Warranty: Automotive
QuickTL07 (11-23-2015)
Old 11-23-2015, 10:46 AM
jz113's Avatar
scroll up and you'll see
Old 11-23-2015, 04:21 PM
QuickTL07's Avatar
I will send you the link when i get home from work
Old 11-23-2015, 04:23 PM
QuickTL07's Avatar
These are not it, i got them and had to return them I will post correct link when i get home... I'm behind proxy server so i cant get to everything...
Old 11-23-2015, 05:14 PM
EvilVirus's Avatar
I'm asking for the foglights only with headlights off.
A pix shot like this with headlights off.
Old 11-23-2015, 06:26 PM
QuickTL07's Avatar
Its not possible because i cant turn them off there is no option on my car to do that.
EvilVirus (11-24-2015)
Old 11-23-2015, 06:27 PM
QuickTL07's Avatar
This is a link to what I bought,
http://www.ebay.com/itm/141626730616?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 11-23-2015, 08:19 PM
Why did you have to return the amazon ones? Its the same brand and seller. Am i missing something?
Old 11-23-2015, 08:30 PM
joz00's Avatar
Awesome!
I've been running some LED's similar to the below link (with the correct connection for our car) in my fogs for about a year and 3 months now. They were also just plug and play and I have had zero issues. They've seen temps down to 10 degrees F and up to 90 degrees F. Mine are on anytime my lights are on so they've definitely seen a lot of use especially during the fall/winter/spring since we are a bit North. I think I paid around $50 for my bulbs.
I didn't have to jack the car up to install, just cranked the wheel and slipped my arm in after pulling back the fender liner if that helps.
http://www.ebay.com/itm/like/221945433287?ul_noapp=true&chn=ps&lpid=82
Old 11-23-2015, 08:51 PM
This is what I'm using in my G37 fogs. No fan.
VX3 H11 H8 H9 H16 2800LM LED HEADLIGHT FOG LIGHT | 1 PAIR - H8 - H Series - Shop Bulb #
On a side note, do any of you have a cold air intake in your TL? I ask because I still have a cold air intake on my TL and the air filter rubs against the back of my halogen bulb. I would imagine there would be fitment issues with these LED fog light bulbs due to the giant heat sink/fan assembly.
Old 11-23-2015, 10:14 PM
Originally Posted by vietxquangstah
How have these been for you? I think its interesting that the ones from Vleds only have a 90 day warranty while OP's come with a 2 year warranty. Because I still am leery about LEDs I would want the longest warranty possible. IMO!
Old 11-23-2015, 10:33 PM
Didn't realize it was 90 days. I bought them back in May of this year and they were not going to be discontinued. They were $100 (i had a 20% off coupon so i paid $80) and had a 1 year warranty.
They are pushing there new $130 led fogs and i guess trying to clear out what's left of the VX3 models.
They've been good however my G is a weekend car. So they don't have much hours on them. They've been in for almost 6 months now
Old 11-24-2015, 12:55 AM
That is another thing I do not like about Vleds, they seem to update their products so much and do not support their old stuff. Just seems like there are too many variables with LED's. I do not want to spend a bunch of money and have them not work right or not at all.
Old 11-25-2015, 07:11 AM
QuickTL07's Avatar
MY TL is a daily driver, i go to work and come back to work, and go out... So I will tell you how long they will last... since winter is here and it gets dark, I have them on all the time... time will only tell....
EvilVirus (11-25-2015)
Old 11-29-2015, 10:20 PM
QuickTL07's Avatar
Update,,, no problem with LEDS i went through car was, crazy rain, snow, ice, and they are still going strong, as colder as it gets the less i hear the fan kick on... I think they will outlast 2 years i hope, if not warranty is its place
Old 11-30-2015, 06:00 PM
'13 Hyundai Sonata
TLin401's Avatar
Those look awesome. I'm in the process of retrofitting TRS fog light kits into my sonata
Old 11-30-2015, 06:44 PM
nismotypeS's Avatar
The Vleds led fog lights that you listed above are they plug and play for a 08 TL-S?
Old 11-30-2015, 10:48 PM
Yes
Old 12-01-2015, 01:50 PM
luis72091's Avatar
Did this trigger any sort of bulb out warning on the dash?
Old 12-01-2015, 01:53 PM
Our cars don't have bulb out warnings for fogs
Old 12-01-2015, 07:20 PM
Luis Chavez's Avatar
These look great OP. I wish I could buy them for my TL-S, but the reflector inside one of my fogs is damaged and messes with the beam pattern. It was like this when I bought the car. I wonder how that happened?
Old 12-01-2015, 07:29 PM
When water gets inside, it messed up the reflective coating
Old 12-03-2015, 01:27 AM
Oh Okay. Thanks for the info. I'm currently looking into purchasing some full LED assembly fogs soon. Any suggestions?
Old 12-04-2015, 12:33 AM
As far as I know there is no LED assembly that fits our cars, only adding an LED bulb to the housing.
Old 12-04-2015, 06:12 AM
What about the ones that TRS sells? Those don't fit either?
Quick Reply: FOG-LED DIY-Very Simple
