DIY Video: Removing Your Rear Bumper 3G Garage #E-095
Old 09-26-2010, 11:46 AM
  #41
8th Gear
TheRide's Avatar
Great video, I just finished swapping my OEM tail lights with TL-S lights and the video (and Ron's post https://acurazine.com/forums/3g-tl-2004-2008-93/how-do-i-remove-rear-bumper-569062/) helped out a lot.
Some of those bumper clips were a pain in the ass to get off. I didn't break any but this chew up a few, but not to the point that they are unusable. Also, a stubby Philips head screwdriver helped out a lot.
Old 01-02-2011, 07:24 PM
  #42
dpace32's Avatar
THANK YOU! Excellent tutorial, I used it this weekend to help replace a cracked tail light.
Old 01-04-2011, 11:58 AM
  #43
vuuha05's Avatar
Thanked OP, the videos have helped me do so many things
Old 04-03-2011, 08:47 AM
  #44
duggan419's Avatar
I figured the front bumper out last year....which took....maybe 3 hours...sheesh you made the rear bumper removal look like cake work.
Anyone removing the bumpers which entails snapping those plastic fitting out with a flathead (a little bit finesse but more brute strength)....I recommend picking up some extras from the stealership...I paid 8 bucks for 5 of them (ridiculous I know). Well worth it if you break some and you are doing this fix on the weekend. Just my 2 cents!!
Old 10-17-2011, 11:12 AM
  #45
2007 6SMT Type-S
SurfingScotty's Avatar
Great video! It may come in handy if, Question: The previous owner was in a rear end collision. As a result: the sides of the bumper at the very top where it meets the corner of the tail light is flared out. Is there a way to square it up I.e. a clip that is worn out? Any ideas? It's not huge but it bugs the hell out of me.
Old 11-30-2011, 12:46 PM
  #46
3rd Gear
Skidazl's Avatar
Great video, for a very unmechanical person, this made it rather easy to replace my rear tail light.
Old 02-09-2013, 10:05 AM
  #47
NTMD8
jimsta's Avatar
Is it me or does the video not work anymore?
Old 02-09-2013, 10:05 PM
  #48
v 4910shp/19,600ft-lb v
kjelly's Avatar
Try
http://s142.beta.photobucket.com/use...l?sort=3&o=175
madenz (05-29-2013)
Old 04-12-2013, 07:57 PM
  #49
9th Gear
tl5155's Avatar
Sweet video. Thanks for taking the time to put it together. While your procedure seems pretty straightforward and easy, are there any things to be careful not to do, i.e. use too much force and possibly break something, think something is in place when it really isn't, rattles, etc.?
I know there are written instructions for replacing the tail light lenses, but is there a video like this one. Seeing it done via video is SOOOO much nicer.
Old 04-12-2013, 08:02 PM
  #50
TegoTL's Avatar
thanks for the video! Helped out big time!
Old 04-12-2013, 08:03 PM
  #51
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
TL5155 - Once you get in there its easy. Just dont over torque the nuts on the tail lights. For the lights there are four screws where you will access them from the trunk (pull back the liner) and from the outside there are 2 there. You will have to take out the led board from your tails and swap it into the new one. Then just put everything . Oh I got it pack and box and will drop it off at the USPS.
Old 07-18-2013, 09:48 PM
  #52
9th Gear
blastermaster's Avatar
Excellent video! Just replaced my rear bumper using your tutorial. Took about 30 min with a friend helping me.
Old 07-30-2013, 08:08 AM
  #53
VolatileVFR's Avatar
Is it just me, or is this video broken or not available anymore? I cant seem to find it anywhere, on photobucket or anywhere else..
Old 07-30-2013, 08:11 AM
  #54
story.customz's Avatar
Try the link above. I'm at work so I can't see if it works, but I'm pretty sure I used this a couple months ago when I swapped tails
Old 07-30-2013, 08:22 AM
  #55
Yeah,that worked.. I ended up finding the vid buried amongst his pics on photobucket, but for some reason I couldnt access it directly from the posted link on the forum.. Thanks!
Old 08-01-2015, 10:09 AM
  #56
Akira'sPapa's Avatar
Originally Posted by sandiegodrive
Hey guys you wanted a video for removing your rear bumper and here it is.
It was fairly easy to film this time around. I only had 5 minutes to cover things in this video so I hope it was enough.
If for some reason the video doesn't play just click refresh (F5) on the photobucket page.
Needed Tools:
- 1 Flat Head screw driver (2 would be better for clips)
- 1 Normal length Phillips Screw Driver (longer would be better)
- 1 wrench with 10mm socket
Hey! Couldn't get the video to work even after refreshing, so I just found it otherwise. Here's the link for anyone else that worked for me!
DIY Video: Rear Bumper Removal Video by SanDiegoDrive | Photobucket
Thanks!
Old 08-28-2015, 10:06 AM
  #57
uneedkhoality's Avatar
Thanks!
thanks for finding the working link!
Old 02-16-2017, 07:12 PM
  #58
MikeekiM's Avatar
Very useful video (and still active in 2017)...
Thanks for making this available!
Old 04-19-2020, 05:01 PM
  #59
YJLTG-TLS's Avatar
Needed Tools:
Link isnt working, anyway you could please update it?
Old 04-20-2020, 08:52 AM
  #60
2007 6SMT Type-S
I don’t think this is the OP’er link but it actually works.
Old 04-20-2020, 01:53 PM
  #61
YJLTG-TLS's Avatar
https://m.youtube.com/watch?v=Ft50NPKeLOw
I have watched this once or twice and the guy constantly complains about missing clips, bolts and how it is an after market bumper.
Old 04-21-2020, 07:31 AM
  #62
2007 6SMT Type-S
the basic locations of mounting hardware is the same, whether OEM or aftermarket. The procedure of removing the rear bumper is one of the more basic procedures for our cars and honestly, if you can’t figure it out after watching the video, you’re
better off taking your car to a shop.
Old 04-21-2020, 02:43 PM
  #63
YJLTG-TLS's Avatar
Wow thanks for the helpful comment.....
"Figuring it out" is how shit gets broken, this is why service manuals exist.
Old 04-22-2020, 06:56 AM
  #64
2007 6SMT Type-S
Watching the video= figuring it out.
cycdaniel
12-17-2019 10:58 AM
space_boy
ILX
51
08-15-2017 12:06 PM
obsessedmotors
09-10-2015 10:49 AM
09-04-2015 08:03 AM
Quick Reply: DIY Video: Removing Your Rear Bumper 3G Garage #E-095
