Best LED's on the Market! Who Needs HID's?!
Old 10-14-2014, 11:14 PM
  #401
9th Gear
TravisJohn82's Avatar
u have front bumper plugs?? if so how much?
Old 10-15-2014, 02:11 PM
  #402
08-TL-S's Avatar
so these are leds you are running for the drls? not hids? they look great, where can i get them? would like to change my fogs to yellow leds as well
Originally Posted by Frosty
It is still my understanding that the lights will work with the 6v power of the OEM wiring, but will not reach their FULL brightness unless you use an aftermarket, 12v Harness (either VLEDs or iJDMToy).
However, even with only 6v, the lights are still rather bright. Here is a picture of a 9th Gen Civic using these LEDs in his 6v DRLs with NO 12v harness or load resistors whatsoever.
Old 10-15-2014, 09:31 PM
  #403
Frosty's Avatar
Yep, they are plug-n-play LEDs. I ordered mine from HERE, and used their GTXM2 coupon code for 20% off and free shipping (in the U.S.).
I got the Blue Edition (because those were the only ones available when I ordered), but I've heard great things about the Black Edition as well. They are slightly brighter, and have slightly less of a blue hint in the color. I wouldn't recommend the JDM Edition, as they have an external fan that can be somewhat noisy.
Old 10-16-2014, 12:21 PM
  #404
08-TL-S's Avatar
Thanks Frosty! Did these fit the rubber housing without modifying? Don't want water to get in. The blue edition should be bright enough, only using as drls and fogs. i have a 08 type s, which type of bulbs I need for drl and fog?
Old 10-16-2014, 12:35 PM
  #405
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Mine were VERY loose, and adding duct tape tightened it up a bit, but during my drives at night, condensation shows up.
Old 10-16-2014, 03:16 PM
  #406
vietxquangstah's Avatar
drl is 9005
fog is h8
Old 10-16-2014, 09:08 PM
  #407
08-TL-S's Avatar
Thanks!
Originally Posted by vietxquangstah
drl is 9005
fog is h8
Old 10-18-2014, 02:11 PM
  #408
08-TL-S's Avatar
Frosty, can you confirm how the bulbs sit inside the headlight, are they loose. Any water gets in? thanks
Old 10-18-2014, 02:23 PM
  #409
Frosty's Avatar
The LEDs are somewhat loose in the '04-'06 fogs (DRLs in Canada). As I've said before, I don't blame the LEDs for this, but rather the headlight housing itself. Out of all of the other places I've seen these installed (my Inspire fogs, 335i fogs, SRX fogs, Civic fogs, Civic lows, Civic DRLs, etc), the '04-'06 TL fogs/drls are the ONLY locations that appear to be somewhat loose after installation.
That being said, I don't think one needs to worry about the bulb actually falling out, or anything crazy like that. As Guitarplayer16 mentioned, you can wrap some duct tape around the 3 tabs if you want to snug it up a bit. I've been running these for 2 months without any issues, and no water has gotten inside because of them.
Old 10-18-2014, 03:07 PM
  #410
3rd Gear
KingJeevy's Avatar
Sweet, def getting these installed..
Old 10-19-2014, 12:53 PM
  #411
Frosty's Avatar
Old 10-19-2014, 01:12 PM
  #412
9th Gear
my stock hid's are not bright anymore? do they slowly die off? the reason why i ask they only lite up about 40 ft in front of me. and ds2 hid are like 80 dollars a piece
Old 10-19-2014, 01:15 PM
  #413
My theory is that heat gets in through the not so tight seal, and since it's cold out, the cold air hitting the lens condensates the warm air inside.
The LED heatsinks get SO hot, it doesn't help with the problem lol
Hot heatsink + hot engine air + bad seal = condensation.
I can test out if it's the LED bulb or not.
I will plug in my OEM bulbs back in, and see if it condensates.
Gonna go for a drive at night, and see what happens.
If it condensates with OEM bulbs, I have another problem lol
Old 10-19-2014, 02:07 PM
  #414
Your question isn't relevant to this thread at all but I'll still answer it.
Yes HID bulbs slowly color fade as they age. The end result is a dim colored HID bulb that is not the original color compared to when it is new.
D2S bulbs do not cost $80 a piece if you know where to look. If you go to The Retrofit Source Inc you can find Morimoto branded D2S bulbs for $45 A PAIR.
Morimoto is a aftermarket brand that is very good quality. Do not mistaken them for cheap eBay brand bulbs. If you are to buy any aftermarket HID bulb or kit Morimoto is the only way to go.
They also sell OEM bulbs which are Osram Sylvania or Philips. Those are $95-$100 A PAIR.
The Retrofit Source | Innovative Headlight Upgrades <----- Click this link
Old 10-19-2014, 06:03 PM
  #415
carbngrytl's Avatar
I noticed when I put one in my 07 fog, it fit pretty loose. Unfortunately I had to send one of the bulbs back due to it being faulty. When I receive the replacement, I think I will put a small amount of rubber cement or silicon around the rubber seal to keep the seal tight.
Old 10-21-2014, 01:07 PM
  #416
Besides my fitment issues, I drove yesterday (I don't drive much) and these things are BRIGHT. They light up speed signs/road signs during MID day. I know this when I'm sitting at a red light and the cars driving by block the light on the signs.
Old 10-21-2014, 01:43 PM
  #417
under renovations....
CubanLynx84's Avatar
I noticed it too. I also took pics of the reflection off of a van in front of me and it lit it up pretty good. I am tempted to get a set for my fogs.
Old 10-30-2014, 11:48 PM
  #418
Frosty's Avatar
UPDATE:
The seller has given me a NEW email address to share with everyone, that will hopefully improve the response time after an inquiry. He runs an eBay store, so his other email address is bombarded with hundreds of emails every day from eBay, therefore making it difficult to sift through and find messages from individuals contacting him through the GT Lighting website.
Please send all questions, comments, and concerns to this email address from now on: GTLightingInfo@gmail.com
Thank You!
Old 10-31-2014, 12:56 AM
  #419
QuickTL07's Avatar
Thank you for great info, just ordered mine,
I got my car on Monday and keep ordering crap for it lol next is fogs!
Old 10-31-2014, 07:07 AM
  #420
Did you buy these for DRLs? If so what kind of harness did you go with?
Old 11-01-2014, 09:31 AM
  #421
eaf
eaf's Avatar
The biggest question remains: has the radio interference been addressed yet or not?
Old 11-01-2014, 04:00 PM
  #422
Crux's Avatar
I'm amazed with all the questions and issues around those certain LEDs people are still getting them. Nothing against you frosty you seem more than willing to help for a company you recommended, just seems like a silly hassle to save a few bucks over other options that have yet to present any.
Old 11-01-2014, 09:41 PM
  #423
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
Say what
"..........a silly hassle to save a few bucks over other options that have yet to present any.". What does that mean?
Old 11-01-2014, 10:09 PM
  #424
Crux's Avatar
Say what
fitment, freq. interference, etc of the ones that keep getting proposed which IIRC are cheaper than some other LED application options which have yet (to my knowledge) have any issues.
Old 11-02-2014, 01:47 AM
  #425
YeuEmMaiMai's Avatar
I have different LEDs in my Subaru and oncoming glare is not an issue. the light definitely lights up more evenly in front of you. My only issue is that the high beams are worthless (reflect straight up for the most part). I might try a different set to see if I can get results closer to the halogens.
Also there is no RF interference between these LEDS and the FM radio
I compared my LED to the halogens and while the LED placement is similar to the filament, it's not quite the same
Old 11-02-2014, 08:05 AM
  #426
QuickTL07's Avatar
i didnt get any harness with it.. didnt know i need any!!!???
Old 11-02-2014, 08:35 AM
  #427
I don't have any radio interference issues with mine. Mine are working just fine. bright as hell too
Old 11-02-2014, 08:39 AM
  #428
yeah you do need it. get the vleds harness linked a few pages back. I still don't believe that they will work without the harness in an 07-08 tl-s. Although it is claimed to work there hasn't been any solid proof presented here to support it.
Old 11-02-2014, 09:33 AM
  #429
Crux's Avatar
it's needed. ~$50 IIRC
Old 11-02-2014, 01:09 PM
  #430
PDX
Dwilliams92's Avatar
Were you ever able to test this theory? Got LEDs and custom headlights on the way. Would rather not run into this problem as well!
Old 11-03-2014, 07:33 AM
  #431
QuickTL07's Avatar
I guess I will need this "R2"
Acura Honda Lexus High Beam LED Daytime Running Lights Decoder Modules
WTF why wont they say that right away ?
Old 11-03-2014, 07:40 AM
  #432
No sorry not yet.
Condensation only occurs during the driving in the night, I don't know what that means.
It condensates at night in 9 degree weather but these days it's been 3 degrees out and it doesn't condensate even that cold during the day.
You need R3.
  #433
Just get the vleds harness. Better quality this time around.
  #434
QuickTL07's Avatar
Just ordered mine, and they are killing on shipping 8$ to me its B.S, but whatever I will need it, i don't want to have a yellow light. That will be annoying!
Old 11-03-2014, 08:57 AM
  #435
It's not only to get rid of the yellow light, it's to give full power to the leds so they will actually work as DRLs
Old 11-03-2014, 12:27 PM
  #436
MyGuti's Avatar
I ordered the ijdm's harness as well. As guitarplayer said a few pages back, "it's cheaper and it works". Mines still on its way to me but I will definitely update here once I get them installed finally.
Old 11-03-2014, 03:23 PM
  #437
2014 RDX AWD Tech
Comfy's Avatar
Can anyone confirm if these will work as fog lights on an Acura RDX as true plug and play?
Old 11-03-2014, 09:18 PM
  #438
Frosty's Avatar
I've never installed them in an RDX, but I'm almost positive that they'll be plug-and-play in the fogs just like they are in the TL fogs. The RDX fogs use an H11 bulb.
Old 11-05-2014, 07:01 PM
  #439
thegipper's Avatar
Just an update.
the seller of these lights sent me a replacement set because of the radio interference I was experiencing.
The new set works perfect and no radio issues whatsoever.
Thanks Frosty for all the help.
Old 11-05-2014, 07:40 PM
  #440
I don't know if this has been mentioned yet, but yesterday I decided to check out their website and it seems like they have newer models out.
Looks like they only emit light from one side, though.
Quick Reply: Best LED's on the Market! Who Needs HID's?!
