The 3G Ramblings & General Discussion Thread (Part 2)
Old 03-15-2013, 01:21 PM
  #161
JJH
JJH's Avatar
Originally Posted by Sick TLS
take the belt off and spin the pulleys by hand. youll be able to tell which pulley/tensioner/whatever it is thats making the noise
I'm going to take the serpentine belt off and verify that the noise is in fact either the belt, a pulley, or a tensioner and not the timing belt auto tensioner. That would be catastrophic.
the pulleys are too close to each other...rather than guess whether it was idler or tensioner pulley, I just changed out the whole tensioner. More money but it's a part that needs changing at some point anyway, so no regrets. You'll do new tensioner and belt and you should be good.
14MM to push back tensioner, remove belt, then tensioner is held with 2 bolts, IIRC. It's been a while.
Thank you, so it sounds like the tensioner is spring loaded and that I don't have to manually tighten the tensioner after installing?
JJH is offline
Old 03-15-2013, 01:24 PM
  #162
Desert Life Sucks!!
sauceja's Avatar
Originally Posted by JJH
Hello everyone,
So after going through the car wash today, my car started squeaking (which is nothing abnormal, it always does that if the belt gets a little wet or when it's real cold in the morning on cold start-ups), however, the squeakiness didn't go away. An hour passed and I drove to autozone to pick up some belt dressing. Upon opening the hood, this was worse that a typical dry squeaky belt. It almost sounds like sandpaper getting rubbed across cement. It worries me that either a pulley or tensioner is bad, especially if it's the alternator pulley because I will have to replace the whole thing.
Thanks Azine.
I had a weird sound, I though my crank bearings were grinding. Replaced serpentine belt, problem solved.
^my buddy had a similar issue. replaced the tensioner and belts and it was fine afterwards.
I just replaced the belt.
I was trying to find a DIY on how to replace the tensioner, but I'm worried that it might be one of the pulleys going bad and not the tensioner. Any good way to tell that you know of?
Good luck searching anything on A-Z. Start with the belt, its a cheaper throw parts at it solution.
^honestly i don't think that there is. i know he did a bunch of trial and errors trying to figure out what it was, and it sure sounds like the way yours is.
maybe someone else can chime in that knows a bit more about it.
You can use a long screwdriver while motor is running and stick handle end into 1 ear and tap the other end on a piece of metal as close to the moving part as possible without touching a moving part. I have an automotive stethoscope that I use. You will hear a smoother noise and a nasty grind if the pulley is bad.
Good for checking alternators but works on all pulleys.
This would kinda work but unless you can spin them as fast as the motor it will be hard to tell unless your pulley is straight fucked.
Again I would start with a belt.
I've always had bad experiences with FedEx. I'll take UPS every time. I don't think I've ever had a late package arrive via UPS.
I have had opposite luck, I prefer fedex where possible. It helps I know the drivers maybe.
Oh yea and
JJH
sauceja is offline
JJH (03-15-2013)
Old 03-15-2013, 01:26 PM
  #163
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
It's not the belt on our cars...the auto tensioner keep it from ever being the problem. If tension is it, it's the tensioner. If pulley is it...it's the tensioner.
If I ever need a stockade though, I'll call you, ya bastid. If I DID have an automotive stethoscope I can tell you what I'd want to hear on YOU.
rockstar143 is offline
Old 03-15-2013, 01:27 PM
  #164
Desert Life Sucks!!
sauceja's Avatar
Do farts have lumps?
sauceja is offline
Old 03-15-2013, 01:39 PM
  #165
Mine do, but I call them sharts.
Old 03-15-2013, 01:48 PM
  #166
story.customz's Avatar
I call mine fumps
story.customz is offline
Old 03-15-2013, 01:50 PM
  #167
JJH
JJH's Avatar
Cheapest I could find the belt and tensioner was here:
http://www.parkacuraoemparts.com/par...agramCallOut=1
[ 1 ] COOLING SYSTEM / COOLING / BELTS & PULLEYS / Serpentine belt
serpentine belt
MSRP Core ? Save Online Price
$38.68 $0.00 $10.60 $28.08
[ 2 ] COOLING SYSTEM / COOLING / BELTS & PULLEYS / Tensioner
tensioner
$112.35 $0.00 $30.78 $81.57
JJH is offline
Old 03-15-2013, 01:52 PM
  #168
I remember paying like $160 for my tensioner and belt. Something like that. It's one of those dynamite to kill an ant fixes but I didn't want to waste time fixing the wrong pulley or just the belt. Figured it was a wear and tear item...no regrets.
Old 03-15-2013, 01:53 PM
  #169
Desert Life Sucks!!
sauceja's Avatar
Sounds about right. 30.00 for a belt is common. I ordered mine with a few air filters and other stuff I needed to save shipping costs.
sauceja is offline
Old 03-15-2013, 01:57 PM
  #170
DaeHanMeenGuk's Avatar
What are the chances of another crazy thread appearing?
DaeHanMeenGuk is offline
Old 03-15-2013, 02:01 PM
  #171
Yumcha's Avatar
Received 22,653 Likes on 13,892 Posts
^ Depends.
Yumcha is online now
Old 03-15-2013, 02:25 PM
  #172
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Crazy?
Majofo is offline
Old 03-15-2013, 02:57 PM
  #173
Desert Life Sucks!!
sauceja's Avatar
At the end of page 5 maybe we should create 3G Ramblings & General Discussion Thread (part 3)
sauceja is offline
Old 03-15-2013, 03:06 PM
  #174
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
You mean page 500.
Undying Dreams is offline
Old 03-15-2013, 03:11 PM
  #175
Desert Life Sucks!!
sauceja's Avatar
We can keep it fresh. Maybe 3g ramb and gen dis (part 500)
sauceja is offline
Old 03-15-2013, 03:14 PM
  #176
Majofo's Avatar
Maybe change the name..
The thread for assholes and the men that love them.
Majofo is offline
  #177
Majofo's Avatar
assholes that is
Majofo is offline
Old 03-15-2013, 03:16 PM
  #178
Desert Life Sucks!!
sauceja's Avatar
So a thread for WD and rockstar??????
sauceja is offline
Old 03-15-2013, 03:19 PM
  #179
Majofo's Avatar
whose the asshole and whose the asshole lover?
jk.. We all know RS is the asshole.
Majofo is offline
Old 03-15-2013, 03:21 PM
  #180
Joneill44's Avatar
Received 3,594 Likes on 1,720 Posts
Joneill44 is online now
Old 03-15-2013, 07:54 PM
  #181
sup guise?
Old 03-15-2013, 08:06 PM
  #182
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,145 Likes on 4,812 Posts
No.
civicdrivr is offline
Old 03-15-2013, 08:24 PM
  #183
Yumcha's Avatar
to the
civicdrivr (03-15-2013)
Old 03-15-2013, 08:26 PM
  #184
Old 03-15-2013, 08:32 PM
  #185
civicdrivr's Avatar
I need a new avy. Mine is quite old. But alas, I am way too lazy to find one. *hint* Yummy*hint*
Old 03-15-2013, 08:42 PM
  #186
Yumcha's Avatar
@ FRSdrivr...
Enjoy the new avatar!
  #187
Give him a unicorn gif
Old 03-15-2013, 08:47 PM
  #188
Yumcha's Avatar
I like the Gundam-canning avatar. No unicorn today.
Old 03-15-2013, 09:05 PM
  #189
Majofo's Avatar
Majofo is offline
Old 03-15-2013, 09:25 PM
  #190
civicdrivr's Avatar
Man, robots are totally ghey. What are those in my avatar? Some sort of Autobot?
Old 03-15-2013, 09:35 PM
  #191
Yumcha's Avatar
How dare you!
Old 03-15-2013, 09:38 PM
  #192
civicdrivr's Avatar
Old 03-15-2013, 09:45 PM
  #193
I like turtles
IamaTL's Avatar
Originally Posted by Majofo
gotta get the whole gif.
IamaTL is offline
Old 03-15-2013, 09:48 PM
  #194
Majofo's Avatar
If I wanted the whole gif, I would have posted it noob.
3G TL owners..
Majofo is offline
Old 03-15-2013, 09:50 PM
  #195
civicdrivr's Avatar
Cant live with them....
Old 03-15-2013, 10:01 PM
  #196
I like turtles
IamaTL's Avatar
sorry, continue your circle jerking.
IamaTL is offline
Old 03-15-2013, 10:03 PM
  #197
Majofo's Avatar
That's all I ask.
Majofo is offline
Old 03-15-2013, 10:04 PM
  #198
civicdrivr's Avatar
No circle jerk here. Theres only two of us. Thats a double dutch rudder.
sauceja (03-15-2013)
Old 03-15-2013, 10:05 PM
  #199
Majofo's Avatar
It's not gay. Trust Majofo.
Majofo is offline
civicdrivr (03-16-2013)
Old 03-15-2013, 11:19 PM
  #200
Desert Life Sucks!!
sauceja's Avatar
Yeah trust the fluffy ghey pink puppy
sauceja is offline
Quick Reply: The 3G Ramblings & General Discussion Thread (Part 2)
