A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
Old 09-09-2010, 07:55 AM
  #81
Mjakaz09TL's Avatar
Originally Posted by saturated_fat
I've attached a pic of the front cam as it is now. Is this correct? Is it off by a tooth? I've done this twice now I dont see how to get it any tighter on that cam.
I havnt slept in awhile so maybe the CP isnt EXACTLY on the arrow when I took the pic but I think it is....
Any thoughts?
I think u forgot to post your pic? At least i am not seeing it...
Old 09-09-2010, 07:58 AM
  #82
saturated_fat's Avatar
Originally Posted by Majofo
pics?
sounds more like misfire to me.
If you still cant see it, I can email it?
Old 09-09-2010, 08:00 AM
  #83
Oh yea the car has a CAI, headers, greddy exhaust on it and some other things 5AT. Coolant may have spilled
Old 09-09-2010, 08:01 AM
  #84
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Don't go by the marks on the timing cover, it's just a visual guide. upload a pic of the timing mark on the block and the cam gear if you can.. but again.. it sounds like it's a misfire issue rather than a timing issue.
JD TL-S (03-19-2015)
  #85
Majofo's Avatar
headers?
you mean straight piped primaries?
Old 09-09-2010, 08:03 AM
  #86
headers?
I meant high flow cats :P
I'm realyl really tired sorry.
When you say its a misfire...how do I go about fixing that? Steps the troubleshoot ?
Old 09-09-2010, 08:19 AM
  #87
Majofo's Avatar
well check your timing marks first and foremost, the cam gear marks should line up TDC with the block mark. As illustrated below:
If that checks out.. go ahead and drive it to your local auto parts store / autozone and pull the code but get some sleep first. We don't want you crashing into something on the way there. Report back the codes to us when you do.
When you swap the plugs you have to be pretty careful with the coils.. you didn't drop any did you? Also don't put any dielectric grease on top of the plug and make sure the coil seats properly. The pressure from the coil will seat like it's spring loaded so if it pushes back any give it a 1/4 twist left to right until it does seat correctly and then secure it with the fastening bolt. Pay particular attention to the connection as well. Make sure they are fully clipped into the coil.
As a final note I would check all your electrical connections that you unfastened when doing the job. Make sure everything is hooked up properly. I would also change out the PCV valve (cheap & easy, forgot to include it in the DIY). I think worst case for you is a bad coil or possible valve adjustment.
Old 09-09-2010, 08:47 AM
  #88
I'm gonna take a nap and then take it over to autozone, thanks for the help!
Is there a quick way to check the TDC marks without removing the CP again ?
One more quick thing...one of the Coils was brown, like completely brown, so was the spark plug that went with it. However the car was not having any issues before the TB change.
Old 09-10-2010, 08:47 AM
  #89
Ok went to advance auto and got the car scanned. Multiple codes came out, Most popular ones were Misfire in Cyl 5. There was a Misfire in random cylinders error also. The other cylinders mentioned were 2,4,6 (In seperate errors).
So...does this mean the timing is off ?
Old 09-10-2010, 09:04 AM
  #90
I should also mention that before taking the car there I did unplug different coils to see the effect. This may be the reason I threw so many codes. See the below diagram....
O O O
O X O
X has no affect on the cars idle when unplugged, the other O's all will cause the car is idle horribly. I'm assuming this means there is no spark on that cylinder...even If I switch coils there is still no change.
So...does this mean the timing is off or that its still a misfire?
Old 09-10-2010, 11:17 AM
  #91
Majofo's Avatar
Did you check the timing marks again from cam gear to block mark? I would remove the timing covers and crank pulley again to double check all the marks just to be 100% on TDC marks. The rear cam can sometimes rock a tooth forward when installing the timing belt as well. Although 1 tooth advance is probably not going to cause misfire issues it's not out of the question.
If all the timing marks look good, I'd focus your attention to the coils. A bad coil will cause a misfire and will throw multiple misfire codes even though only one cylinder is the issue. You can test the coils individually with a multimeter (I don't know the procedure off hand) or you can buy a single coil and play hopscotch until you find the culprit. If all the coils check out you should then check the valve clearances. You'll have to remove the intake manifold and associated components (intake tract, throttle body, etc), and remove your valve covers. Get a feeler gauge and check the top valve clearances and adjust accordingly.
Valve clearance spec:
Intake 0.20 - 0.24mm (0.008 - 0.009 in)
Exhaust 0.28 - 0.32mm (0.011 - 0.013 in)
Keep us updated.
Old 09-10-2010, 11:22 AM
  #92
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Well, what cylinder was the "brown" coil on before you moved it around? If it was #5, then I think you have your answer....
Old 09-10-2010, 11:45 AM
  #93
DMZ
Head a da Family
DMZ's Avatar
What it as brown as the back of the undies I took off last night?
Enquiring minds want to know!
Old 09-10-2010, 11:50 AM
  #94
Majofo's Avatar
brown? oh.. I read right past that reference. If it is the same coil that you unplugged and the idle settles down / doesn't get worse, it's probably the issue.. can you post pics of said spark plug and coil OP?
To save a bit of coin.. try to salvage a coil from a junk yard otherwise go get a new one from your local Honda / Acura shop.. probably around $50-100 depending on where you go.
Old 09-10-2010, 11:52 AM
  #95
Majofo's Avatar
Originally Posted by dmz
what it as brown as the back of the undies i took off last night?
tmi
Old 09-10-2010, 11:58 AM
  #96
nfnsquared's Avatar
Depends??
Old 09-10-2010, 11:59 AM
  #97
AVB for President!
TLTrance's Avatar
It looks like changing the spark plugs has a lot more considerations than I thought... Easy to swap, but perhaps not so easy to get right?
Old 09-10-2010, 12:00 PM
  #98
Majofo's Avatar
Depends??
well played sir.
Old 09-10-2010, 12:02 PM
  #99
Majofo's Avatar
not really.. doing many things all at once, returning an issue and then trying to find the culprit can be a bit complicated is all. Changing the spark plugs alone isn't, just be patient and take your time to do it right.
Old 09-10-2010, 01:15 PM
  #100
Hi, Thanks for all the responses. I'm going to triple check the timing marks once I get some time. I'll post pics once I get that far with it.
The brown plug was at Position B, see below, X is the one that seems to have no affect on idle:
O O O
B X O
My hunch is still the timing belt, simply because it was working before... but then again who knows since so much was done.
Is it safe to unplug the coil while the engine is running ? Can someone tell me which bank is #5 ??
Old 09-10-2010, 02:31 PM
  #101
nfnsquared's Avatar
Assuming the bottom of the page is the front of the car, B is #4, X is #5.
firewall
123
456
front
Old 09-10-2010, 02:39 PM
  #102
Majofo's Avatar
You can unplug a coil while running. My advice after thinking it over a bit is to go ahead and buy another coil, replace #5 and go from there.
Old 09-10-2010, 03:06 PM
  #103
nfnsquared's Avatar
^^^I agree, replace the "brown" coil.
Old 09-10-2010, 03:15 PM
  #104
Majofo's Avatar
Definitely try it on both.. I'm more inclined to believe it's the 5th cyl coil and not the brown one (if indeed the brown one isn't the 5th) since he said the idle didn't change with the 5th unplugged but all the others got worse.
Old 09-10-2010, 03:47 PM
  #105
nfnsquared's Avatar
Hmmm. Yeah, try both I guess. It does make sense that #5 may be the culprit instead of the "brown" one on #4 based on your test.
Did you happen to buy the brown one from DMZ?
Old 09-10-2010, 03:54 PM
  #106
Majofo's Avatar
Old 09-13-2010, 06:15 PM
  #107
5th Gear
glizenndale's Avatar
Originally Posted by vytenisb
Partsd should be available from Acura or aftermarket from an auto parts store.
The difficulty I'm having is locating the 50 mm hex tool to aid the removal of the crank pulley. Acura dealer will not sell it to me.
Planning on doing this DIY this weekend. Thought I would contribute after looking for the Honda pulley removal tool. I called Checker (O'Reilly) here in AZ and they actually have it available for rent in the store. It's part number 67101 in their computer. It's a $50 deposit refundable when the tool is returned. In case anyone wants to double check with their local Checker/O'Reilly it may be rentable there as well. Save some cash for a one-time use item.
Old 09-13-2010, 07:17 PM
  #108
Guys,
Here are some pics as promised. Any input appreciated.
http://www.seebadan.com/incoming/TL/timing/
Old 09-14-2010, 12:06 AM
  #109
It appears that #5 will always report a misfire before anything after a reset.
We checked the 456 coils to see if they were sparking and they were. We're going to buy a new coil to see if its just a bad coil or not.
Timing has been redone yet again, and looks dead on.
Any other parts to try?
Old 09-14-2010, 12:20 AM
  #110
Majofo's Avatar
That sounds like the best option.. If you want to buy the tool you can get the 50mm hex wrench for $25 or get the hex wrench with the attached breaker bar for $50 from Amazon.
Guys,
Timing marks look good, crankshaft looks a hair off but it could be the angle of the shot as well. I would get a coil and try swapping out 4 & 5 as suggested.
Old 09-14-2010, 10:37 AM
  #111
ScoobyZINE
AMUA6's Avatar
Hey I needed this! Thanks!
Old 09-14-2010, 12:17 PM
  #112
Played hopscotch with the coils, still same error codes.
Old 09-14-2010, 01:18 PM
  #113
Majofo's Avatar
With a new coil? Remove the spark plug as well and replace it with a new one.
Old 09-14-2010, 01:24 PM
  #114
Well we tried all new plugs last night, now we tried just swaping the coil 1 by 1 with a brand new coil.
Old 09-14-2010, 02:02 PM
  #115
nfnsquared's Avatar
Hmmm. Timing looks to be correct, although it's hard to be completely sure from the pictures....
It's a long shot, but I wonder if there's any chance that both #4 and #5 (or multiple) coils are bad?
Can you post the codes (the code numbers) that you got?
Did you pull the new plugs to be sure one/some didn't get fouled after the run last night?
Old 09-14-2010, 02:17 PM
  #116
Majofo's Avatar
Assuming timing isn't an issue and the plugs & coil packs are fine.. I'd do a compression test and a valve adjustment at this point.
Old 09-14-2010, 02:41 PM
  #117
I'm assuming the valve adjustment isnt a DIY type thing? Also why would the valves need to be adjusted if they were fine before?
Basically it doesnt matter how I put the coils in, cyl 5 will always report a misfire. In other words I cannot get the misfire code to switch cylinders.
The codes are P0305, 0300, 0304, 0302. The 0300 only appears after the car has been running (engine under load, driving it).
At this point I'm running out of patience . I appreciate all the help. I'm going to go ahead and remove all plugs/coils and ensure they are not fouled and replace everything.
Old 09-14-2010, 02:49 PM
  #118
Majofo's Avatar
You can definitely do a valve adjustment on your own. It'll take you a little more time and a few extra parts & tools but it's not expensive nor more difficult than the timing belt procedure.
Old 09-14-2010, 03:11 PM
  #119
nfnsquared's Avatar
P0300 is general misfire code, P0302, 0304, and 0305 indicate misfire on cylinders 2,4, and 5. Anytime you get a -02, -04, or -05 you should also get a -00. Not sure why the -00 is not showing up at the same time as the others...
If you haven't already, you might want to reset/clear the codes and take another reading.
Possible causes are listed as:
* Faulty spark plug or wire
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector
* Burned exhaust valve
* Faulty catalytic converter(s)
* Running out of fuel
* Poor compression
* Defective computer
I'd think if timing was the issue that you'd have a misfire code for all/most cylinders...
Old 09-16-2010, 09:48 AM
  #120
It's poor compression on cylinder #5...local shop is taking a look at it now.
Quick Reply: A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
