ROTORA Big Brake Kits: CL, TL, TSX
Old 05-12-2007, 10:16 PM
  #81
shayan's Avatar
Do you have the new bbk rotors with the special coating on them? it was from this thread https://acurazine.com/forums/showthread.php?t=156263
Old 05-13-2007, 08:34 PM
  #82
Former Sponsor
Excelerate's Avatar
When you say BBK do you mean the TL w/ Brembo calipers? If so yes.
Old 05-13-2007, 11:56 PM
  #83
I have car ADD
BLACKURA_NY's Avatar
hey josh. do you have the 13" 1pc fronts in stock for the 3G? I might be picking up a set real soon. thanks!
Old 05-14-2007, 11:26 AM
  #84
Former Sponsor
Excelerate's Avatar
An entire BBK? For the 3rd gen TL A/T? If so, yes, I do have that BBK in stock.
Old 05-14-2007, 04:10 PM
  #85
shayan's Avatar
What I ment to say was will the rotors in the BBK come with that special coating you were talking about in that thread?
Old 05-14-2007, 05:34 PM
  #86
Former Sponsor
Excelerate's Avatar
I don't think ROTORA has done the BBK rotors yet with that new ecoating. There is still an ecoating on those rotors that is on the hub and and the vanes. It is a black coating. This is an additional coating on the face of the disc.
Old 06-04-2007, 10:34 AM
  #87
I'm Cool
Bobbydoedoe's Avatar
hey josh, i got the 1 piece rotor for the front bbk, i was wondering if it is possible to switch to a 2 piece rotor using the same caliper from the 1 piece bbk? and do you guys carry the the brakepads for this bbk? if so, could i get a price quote. thanks
Old 06-04-2007, 06:37 PM
  #88
Former Sponsor
Excelerate's Avatar
ROTORA will eventually set up their caliper so that those who buy 1 pc rotor BBK's can also upgrade to the 2 pc disc but that isn't possible yet. You would have to see your setup and buy a 2 pc setup or you could just replace the rotors with another 1 pc disc. PM me with your vehicle info, BBK info, and zip code and what you need and I'll get you a quote.
Old 06-08-2007, 05:06 PM
  #89
Inspired
00 acura tl's Avatar
hey, do you sell any bbk for 00 tl, only the front ones, 1 piece, and if you do i would like to know the price with the shipping. I live in Canada, Montreal. thank you
Old 06-12-2007, 09:37 AM
  #90
Former Sponsor
Excelerate's Avatar
Yes I do. Look in the first post. I'll shoot you a PM.
Old 07-04-2007, 01:01 AM
  #91
Time to Climb
godfather2's Avatar
josh, i've been seriously contemplating taking my tsx in a new direction. just wanted to know if rotora plans on building a rear bbk for my ride. if so, i'm gonna have to scoop up both front and rear kits real soon
Old 07-05-2007, 08:18 PM
  #92
Former Sponsor
Excelerate's Avatar
Last I spoke with ROTORA they did not plan to make one. It wasn't off the table but not planned as I said. Stoptech however makes a front and rear kit. PM me for pricing.
Old 07-07-2007, 12:15 PM
  #93
Time to Climb
godfather2's Avatar
^ pm sent
Old 07-10-2007, 06:42 PM
  #94
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
is it possible to just buy parts from rotora from you such as the capiler later on? My friend wants to know this before he invests in a set? He wants to know this because he had some problems with a different company on his other car and it was a damaged capler. They did not have parts anymore and told him he needed to buy the entire kit again and doesn't want to have the same problem again. Also he wanted to know if he could use a Rotora rear kit and a stoptech front kit as stoptech does not have a rear one.
Old 07-12-2007, 12:21 AM
  #95
Former Sponsor
Excelerate's Avatar
Yes ROTORA does sell "Service parts", which are replacement pieces for every single part of their BBK's. You may use a ROTORA and Stoptech kit together but I don't see why he wouldn't just do ROTORA F&R. ROTORA has a tendency to have a forward brake bias like the stock setup, whereas Stoptech has a rearward bias. So yes they can work together but they develop their systems based on different theories. If you need either kit let me know. I sell both.
Old 07-12-2007, 02:08 AM
  #96
csmeance's Avatar
I am thinking about a BBK since i have money saved up and need new brakes soon.Just a few questions I have:
1. I have heard that rotora BBk's can cause the master cylinder to break or fail. Is this true?
2. Will any BBK cause premature wear onto the master cylinder?
3. Are there any spec sheets/data that shows the improvement of braking with a BBK?
4. I have factory brakes on my 04 and they are pretty "touchy" that if i tap them, the can bring the car to a halt. will this still occur with the BBK?
5. Does the installation of a BBK require a fluid change? I am due for one soon so it is well worth knowing now.
6. Does stopetech also have replacement parts?
7. What do you mean by forwards and rearwards bias? I get a little confused.
8. can stoptech/Rotora kits be painted by the manufacturer to a specific design (such as acura written instead of Rotora/Stoptech)?
Old 07-12-2007, 11:52 PM
  #97
Former Sponsor
Excelerate's Avatar
1. I have never heard that and I have never seen that. I have sold and installed dozens of ROTORA BBK's and I have nothing but great reviews.
2. These kits are designed to work with the stock master cylinder.
3. You may email ROTORA for data on this but I don't have any sheets on this. I don't see how sheets could prove anything but I can give you real life experience and tell you that the ROTORA kits have plenty of leverage and will decrease stopping distances.
4. Yes.
5. Yes it requires you bleed the brakes. It may not be a full fluid change but I would recommend one while there.
6. I will have to ask Stoptech tomorrow about service parts but I would assume they would. It wouldn't make sense not to.
7. When you brake with a ROTORA BBK you will feel a front brake bias like you do with the OEM setup. When you brake with a Stoptech kit the car leans rearward and kind of squats.
8. You can get custom caliper colors but I assume we can just have nothing put on there and you could put on an Acura sticker. I will have to talk to both tomorrow to ask.
Old 07-13-2007, 01:00 AM
  #98
csmeance's Avatar
^ Thank you Excelerate
Old 09-01-2007, 05:44 PM
  #99
Columbia Univ. c/o 2004
architectonic's Avatar
Can you go a bit lower on this BBK for 3g TL (5AT)? I have some extra cash and can borrow some more, but not enough for $1300. Is the price absolutely fixed? Please PM me if you can help. Thank you sir.
ROTORA 1 Piece Front 330MM Disc w/ 4 Piston Caliper BBK - $1300 shipped
Old 09-04-2007, 03:41 PM
  #100
Former Sponsor
Excelerate's Avatar
We can talk via PM.
Old 09-04-2007, 05:29 PM
  #101
We can talk via PM.
Sure. PM sent.
Old 09-05-2007, 12:28 PM
  #102
Just PM'ed you. I'm ready to pay. I just need a shipping question answered. Thanks.
Old 10-05-2007, 01:54 AM
  #103
m733l's Avatar
hey josh,
is the 03 tl rear bbk kit the same part number as the 03 cl rear bbk kit?
Old 10-05-2007, 08:49 AM
  #104
Retired!!! ON TOP!!!
rodneyc77's Avatar
Does Rotora make the 4 piston Rear BBK for the '04-'06 3G TL???
Old 10-05-2007, 10:39 AM
  #105
Former Sponsor
Excelerate's Avatar
Yes they do. It is $1750 shipped, like the front 4 piston 2pc disc kit. I actually have a 2 piston kit rear BBK in stock w/ red caliper and slotted/drilled rotors that I am clearing out for $1275 shipped. It's usually $1475 shipped.
Old 10-05-2007, 11:10 AM
  #106
m733l's Avatar
Originally Posted by m733l
hey josh,
Old 10-05-2007, 12:03 PM
  #107
Former Sponsor
Excelerate's Avatar
hey josh,
Sorry didn't see your post. No, they are not the same. The CL rear disc is slightly different.
Old 10-05-2007, 12:58 PM
  #108
rodneyc77's Avatar
Do you have a link or picture of what the 2 piston caliper looks like???
Old 10-05-2007, 02:04 PM
  #109
Former Sponsor
Excelerate's Avatar
Yes look at the first post on the first page. It has a pic of the 4 piston front BBK and the 2 piston rear BBK.
Old 10-05-2007, 11:48 PM
  #110
m733l's Avatar
it's cool. thanks for the info.
Old 10-30-2007, 08:22 PM
  #111
DURAN007's Avatar
Do you have those BBK at $1275 for clp fronts?
Old 11-01-2007, 06:32 PM
  #112
DURAN007's Avatar
Also since I have 04-05 OEM TL wheels on my cl will it clear without the spacers? How much for install and do u have them in stock for this saturday installlation?
Old 11-06-2007, 11:08 AM
  #113
Former Sponsor
Excelerate's Avatar
$1300 shipped for the front 1 pc BBK. Yes I do have a set in stock. What color caliper though? They will clear the 3rd gen TL wheel. Call me for install info and pricing and an appointment.
Old 11-10-2007, 02:34 PM
  #114
DURAN007's Avatar
Do you have red? Plus do you have coilovers in stock... Just wanna drop a little but keep firm ride.
  #115
DURAN007's Avatar
Do you have red? Plus do you have coilovers in stock... Just wanna drop a little but keep firm soft ride.
Old 11-13-2007, 11:45 AM
  #116
Former Sponsor
Excelerate's Avatar
Yes I do have the red calipers in stock. Yes I have coilovers in stock.
Old 02-26-2008, 11:31 PM
  #117
NighthawkBlack's Avatar
How much for the 2 piston rears shipped to FL for the 2000 tl with 2 piece rotor and can I get it in black? Can you get crossdrilled by itself or only slotted alone?
Whats the lead time on that?
Old 02-29-2008, 06:39 PM
  #118
Former Sponsor
Excelerate's Avatar
$1475 shipped on the rear BBK. It can come in either sky blue metallic or red caliper with a slotted or drilled and slotted disc. If you want black it will be custom order with an additional $300 custom caliper charge for the color and a 60-90 day lead time.
Old 03-18-2008, 11:20 PM
  #119
Dtls's Avatar
The brake shimmy
I am in the market to improve the shimmy in Acura's brake system. If I upgrade to a bb kit front and back, will it eliminate the shimmy in the brake system.
Old 03-19-2008, 11:59 PM
  #120
Former Sponsor
Excelerate's Avatar
Well if you have warped rotors you don't need a BBK to eliminate the shimmying however a BBK will eliminate it. All you need is an OE replacement rotor like a ROTORA slotted or drilled/slotted rotor.
Quick Reply: ROTORA Big Brake Kits: CL, TL, TSX
