humming noise at high speed
Old 01-15-2011, 08:28 AM
type sexy's Avatar
i got this humming noise at speeds over 35/40 mph.i can tell its strictly comming from the wheels not sure which one.its not operational cause she drives and performs great,its jus that the nois is annoying and i have the slightest clue
Old 01-15-2011, 08:53 AM
totaledTL's Avatar
Could be a wheel bearing- if front bearing- does the sound change when you slightly turn the wheel?
Might also be a tire. Belts sometimes can separate & the tire makes a noise. sHad any tires replaced?
Old 01-15-2011, 11:18 AM
or rotated the tires and noise appeared?
Have the tire shop ck the all the wheel bearings for you
RR likes to fail for some reason and noises transmit in strange directions in a car
it helps to list your car year-type S if so and current miles when asking for help
how long its been doing the current problem
any work done on it recently
thank you!, it can speed diagnosis by the group- some detail triggers a memory in a ziner and says- yes!- I had that and it cost xx to replace xyz
Old 01-15-2011, 11:20 AM
might be a cv/axle bearing too- the inner ones will act like that
outer bearing failure you usually hear click click click with wheels turned hard, at very low speed- as you start rolling
ck the cv rubber boots for grease trails = broken boot let grease out and grit in
Old 01-15-2011, 01:35 PM
type sexy's Avatar
just got brand new tires,had the prob for about 6mos now,but its louder when im making hard or fast right turns or curves...03 tl-type s 116xxx 2nd tranny no mods still beautiful...thanks
Old 01-15-2011, 08:44 PM
get to the shop that does front end work-
that sounds like a major bearing prob you dont want failing at speed
Old 01-16-2011, 06:13 AM
Original Owner / Oct 1998
Carbuff's Avatar
Our TL needed a LF wheel bearing at ~ 130K miles. Same symptoms as yours.
Old 02-13-2011, 11:00 PM
slvrcrunch's Avatar
bad alignment? tire noise is most noticeable around those speeds. if your previous tires didnt have much tread on them then you wouldnt get any noise. check for cupping, stepping in tread. or wheel bearings.
Old 02-13-2011, 11:03 PM
kidduce's Avatar
Most likely wheel bearings. I had the same issue.
Old 02-14-2011, 12:04 AM
the fun is finding which one- the sound travels and a front noise may be a rear bearing
Old 02-14-2011, 06:41 PM
kidduce's Avatar
I tend to be seeing the front ones going first though.
Old 02-15-2011, 10:56 PM
alhalljr1980's Avatar
i had the same issue got it done for 240 front drivers side bearing
peti1212
ILX
22
01-05-2022 05:14 PM
Frathora
09-28-2015 11:29 PM
Sixers12
ILX
09-06-2015 07:54 PM
Quick Reply: humming noise at high speed
