'96 3.2 TL: How do I compress the rear caliper brake piston
Old 06-24-2010, 06:06 PM
BLUE
Bluish's Avatar
I need to change my rear brake pads on my '96 3.2 TL for the 3rd time in 240,000 miles.
The first time I completely removed the calipers from the vehicle and then forced the caliper piston back in using a hammer. I did this because I didn't know what I was doing and because the odd shape of the caliper made using a C-Clamp impossible.
The 2nd time I just replaced the calipers with rebuilt parts - so I did not need to reset the brake piston.
Now I want to do it right, but I need help from someone with experience on a 1st gen 3.2 TL. Once I have the rear caliper removed from the mount bracket and the pad shims and brake pads have been removed, how do I reset the brake piston?
NOTE: I have the full service manuals, but could not find instructions in section 19-17 Rear Brake Pads Inspection and Replacement.
Old 06-24-2010, 06:19 PM
undyroos's Avatar
the rear piston needs to be screwed in, not clamped in like the front. the face of the piston looks like a + sign slotted into it, get whatever you can slot into the grooves and turn it in. i used a handle from a pair of pliers to give me more leverage/torque, a screwdriver may work as well. good luck.
Old 06-24-2010, 07:07 PM
myisanog's Avatar
they have a certain tool u can use to screw in the rear piston
Old 06-24-2010, 07:10 PM
myisanog's Avatar
i have no idea what its called but it is shaped as a cube with different shapes on each side . u attach it to a ratchet and crank the piston in . u can purchase at any oreillys store
Old 06-24-2010, 07:25 PM
myisanog's Avatar
heres a pic of it . for our rear brake pistons u use the side with 4 bumps, one on each corner. attach it to a ratchet and line it up with the piston and it will grip the piston so u can crank it in .. and make sure when u screw the piston in to make the piston a t and not an x because it will eat the pads faster
Old 06-24-2010, 07:30 PM
myisanog's Avatar
i found the link for ya ..
http://www.oreillyauto.com/site/c/de...0675&ppt=C0067
Old 06-25-2010, 12:50 PM
tuanrich's Avatar
AutoZone let you borrow the tools for free!!!
Old 07-03-2010, 03:43 PM
BLUE
Bluish's Avatar
I changed the rear pads last night. The job took 60 minutes. It took me a while to reset one of the caliper pistions, but I got it done.
The passenger side pads had more than 50% of their life remaining. The drivers side inside pad was OK, but the outside pad was almost 100% gone, particularly along the outside of the rotor. The wheel rotates freely, but perhaps the caliper is seizing intermittently. I'll monitor the new pads for excessive heat and wear.
Old 07-04-2010, 01:19 PM
myisanog's Avatar
what tool did u use
Old 07-04-2010, 01:41 PM
BLUE
Bluish's Avatar
The tool shown in the picture you posted above.
Old 07-05-2010, 11:05 AM
myisanog's Avatar
glad to know i was of help . i was going to change a friends brakes today but the screw was on so tight that it broke 2 of my 12mm sokcets and then i told him i could no longer do it
1fatcrxnem1
22
06-01-2018 01:23 AM
yesSIR-S
05-13-2016 05:42 PM
nanos
11-12-2015 08:41 PM
09-14-2015 10:10 AM
Ny1718
09-11-2015 09:21 AM
Quick Reply: '96 3.2 TL: How do I compress the rear caliper brake piston
