DIY installation of Daytime Running Lights**with detailed pictures** 3G Garage #G-067
Old 11-12-2007, 06:36 PM
  #161
King of NYC
rockyfeller's Avatar
Guys,
I am on my 3rd DRL module and it looks like this one is working good so far.
I now have a totally new and unique problem (well maybe it's not a problem) with my foglights being used as DRLs. I changed the bulbs to LED SMT modules that are made to fit into the 9006 bulb socket. They're not as bright as stock but give a nice white HIDish output.
Thing is though when I turn the car OFF the lights still stay on very very dimly. This leads me to believe there is a very small amount of current going to them even when the car is off! Is this a normal part of the design of the designtech module? I think what's happening here is that because I had normal filament bulbs before, the current passing through was hardly enough to light the bulb even dimly. Now I have LEDs and they must be so sensitive and low draw that they light up.
Actually it looks really cool at night when my car is parked! As if my car is sleeping with an eye open. My only concern is whether this would result in any serious drain on my battery. A reason I'd think not is because every car has alarm LEDs etc. that blink even when a car is off with negligible drain on a battery. The reason I think that it may affect the battery is because the bulbs have at least 12 LEDs on them and they stay on continuously. Anyone have any idea what is causing this and/or if you recommend keeping the lights off?
Old 11-13-2007, 06:53 AM
  #162
bhelsdon's Avatar
Originally Posted by rockyfeller
Guys,
I will have to check it out with my multi-meter.
Old 11-13-2007, 12:13 PM
  #163
Sweet CL Type S
Sweetcls6sp's Avatar
Didn't work for me.
Originally Posted by Sweetcls6sp
Sorry to barge in on the TL forum but will these awesome instructions and part number work on a 2003 CL Type S? I'd really like to have these lights set up but I don't want a Mickey Mouse job. This looks like it'd be perfect! Thanks
Update...I did buy one of these units and installed it exactly as the instructions showed for a negative setup. When I started the car I had only one high beam light on as it should be and the low beam on the same side was flickering. I rechecked my wiring and saw it was correct. I pulled it out as I certainly don't want to ruin any of the wiring or have something happen to the headlight system. I'll just order some foglights and run those.
Hey, I tried!! thanks
Old 11-13-2007, 01:03 PM
  #164
King of NYC
Somehow that constant +ve tap is trickling some power through even when the car is off. That can mean a constant drain on all of our cars.....Or is there only a drain if the bulb lights up? I have a fancy multimeter here but I don't think I'd be able to infer too much about it though. Sorry I'm not an electronic guru here.
Old 11-14-2007, 11:16 AM
  #165
bhelsdon's Avatar
when I get my car back from the body shop (I hit a deer) I will check to see if there is a draw. I have had the DRL's installed for almost 2 years and I have had no trouble with the battery. In that time it sat at the air port for 2 weeks and it fired right up.
Old 11-15-2007, 01:48 AM
  #166
got boost?
hamsup's Avatar
bwhaha..my car came with DRLS...
well...tahst cuz in Canada..all cars must have DRLS....or at least now of days they do..
to make it look more sexy....put JDM Yellow bulbs in there
Old 11-15-2007, 07:11 AM
  #167
2006 TL MT RJ BodyKit
Steeve's Avatar
We need pics bro!
Hey I'm in Canada and I don't have DRLs?!...Oh yeah...my car is American
But I have the RonJon bodykit though
Cheers!
Old 11-15-2007, 11:40 AM
  #168
got boost?
hamsup's Avatar
haha..sweet..ok..i'll get pics up asap..
Old 11-15-2007, 11:51 AM
  #169
got boost?
hamsup's Avatar
ok..here's one pic...gotta upload some more...but heres one for now..
i got some better ones coming...
this is a night shot btw
Old 11-16-2007, 03:18 AM
  #170
got boost?
hamsup's Avatar
ok..heres a few more for ya
enjoy
Old 11-16-2007, 08:43 AM
  #171
King of NYC
are those 3000k HIDs or are they yellow Nokyas?
Old 11-16-2007, 01:35 PM
  #172
got boost?
hamsup's Avatar
nope..they are just the "JDM Yellow" lumeric bulbs..
Old 12-09-2007, 11:22 PM
  #173
Falen's Avatar
where can i buy daytime running module ????
Old 12-10-2007, 11:23 AM
  #174
bhelsdon's Avatar
I purchased mine from auto barn.com.
Old 12-10-2007, 12:06 PM
  #175
Falen's Avatar
How much , is it a good products, never have trouble with it ????
Old 12-10-2007, 12:54 PM
  #176
King of NYC
u gotta read the thread all the info is there
Old 05-12-2008, 10:29 AM
  #177
lazyboykhoa's Avatar
does anyone here have model #20013VA? cuz thats wat they sent me and the colors are a little different and i also purchased it from autobarn.com
Old 05-12-2008, 11:01 AM
  #178
bhelsdon's Avatar
if you can scan the directions on here I can tell you where each one goes.
Old 05-14-2008, 11:29 AM
  #179
for positive light systems (most vehicle)
1. locate a suitable place behind one of the headlights which allows you easy access to the headlight's wires, +12 volt supply and a switched ignition wire. use the enclosed cable tie to screws to mount the unit
2. clip off the white/red wire where it enters the module. connect the red wire with the in-line fuse holder and 20 amp fuse to the plus side (+12 V) of the battery. ( no ground wire is necessary for this product)
3. use the wiring guide to locate the high beam and the low beam wires behind one headlight. use the blue connectores to conect the orange wire to the high beam wire and the white (optional) wire to the low beam wires. the white wire turns the DRL off when the low beams come on.
4. using the wiring guide, locate the ignition sense wire and connect to the units blue wire using one of the tap connectors. this is a wire which shows power (+12 V) when the key is turned to the ignition position and not power when the ignition is off.
5. tide up the wires such that no moving parts or hot engine surfaces will come in contact with these wires
for negative light systems
clip off the white wire where it enters the modult. follow the above directions with the change being that the red and orange wires are reversed with the orange going to ground, red to the high beam wire and white/red to the low beam wire. do not connect the red/white wire until all other wires have been properly connected.
Old 05-14-2008, 05:29 PM
  #180
bhelsdon's Avatar
Red to positive battery post
Orange from module goes to Blue/yellow tracer at fog light connector
white from module goes to red/orange tracer at ballast
blue from module goes to green in the wiper motor harness.
Old 05-16-2008, 09:32 AM
  #181
i actually it. thanks for the help
Old 05-29-2008, 04:48 PM
  #182
信是寶
Tecciztecatl's Avatar
Just a tip for installing the module.
Solder the wires!!! Those snap on clips are junk and will f'up your connections, they will cut the strands of your wire. I should have known better.
Almost two years after the install the connectors where not making good contact anymore. At first I thought that my module went bad, but the wire was oxidizing and vibrating creating opens. I had bad contacts at the fog light connection and then at that cheap-ass fuse clip.
I finally took all the old shit off and soldered the wires and replaced the in-line fuse with a quality one. Oh, the module wire does not solder well, so I used a copper wire to the auto harness and then crimps to the module wires. Everything now works great again!
On a side note, autobarn (where I originally purchased the daylight running lights) told me to call the manufacturer (there was a 2 year warranty), who doesn't answer the phone and won't return voice mails?!? I am glad that it wasn't the module.
Old 05-30-2008, 09:16 AM
  #183
my DRL stopped workin this morning. i did all the checks with all the wire and fused and still not workin...
Old 05-30-2008, 09:28 AM
  #184
信是寶
The only way to check is to cut into the wires and take a voltage and or ohm reading ... recheck the connections. The inside of the module is soid state and sealed, so it should last ... the only weak link are those damn connections. Turn the key to where the lights should come on and mess with the connections again (waiting for the turn-on delay) and see if you can find the problem. Good luck ... be careful with those clips, as they can cut your harness wires.
Old 05-30-2008, 10:56 AM
  #185
..Mark..'s Avatar
Originally Posted by tdelta
Cool mod but I prefer the OEM setup.
Gotta agree.
Besides i drive like an asshole so i would rather not intentionally light my car up 24/7 and make it easier for popo to see me.
Old 05-31-2008, 04:19 PM
  #186
izmyttz's Avatar
Nice
Originally Posted by ..Mark..
Gotta agree.
Old 06-04-2008, 11:46 AM
  #187
okay so i called autobarn up and i told them about my problem with my DRL lights messing up... anyways they told me to call the tech people that they buy it from and they told me that the module is prob burnt up and cant handle the HID lights on our cars. soo wat the hell am i suppose to do now? oh yea i replaced the fuse and check all my wiring...
Old 06-06-2008, 11:36 AM
  #188
bhelsdon's Avatar
They don't know what they are talking about. The module is not lighting the hid bulbs.
Old 06-07-2008, 06:52 PM
  #189
skd2k1's Avatar
You're right...I just installed mine and had to redo because those connectors they provide are sh*t!
If the white wire were not connected to the headlights would the fogs stay on at 75% even with the headlights on?
Old 06-27-2008, 07:49 PM
  #190
1Clean_TL's Avatar
just wondering if we had a confirmation of people having success on being able to cut the green wire inside the new version of the module, that will take out the delay?
Old 07-01-2008, 03:23 PM
  #191
Rick-H's Avatar
I just installed a newer version 20013VA -- ther was NO green loop of wire. There is about a 10-15 second delay to come on (good while you crank the engine to start) and a similar delay when you turn the key off.
Also I ordered mine at www.accessconnect.com for $22.90
Old 12-16-2008, 06:03 PM
  #192
LiQuiDFleX81
Liquidflex81's Avatar
Question
Originally Posted by n1976jmk
one question, when i turn my headlights on, will the drl's automatically go off?
thanks,
Jon
if this is true,, will the OEM foglight switch still function normally,, or does it become a dead switch in the car?
Old 12-16-2008, 06:21 PM
  #193
LiQuiDFleX81
Question
Originally Posted by bhelsdon
Yes, you are right, that would make the drls(fogs) come on with the parking lights.
i like this setup the best, but i only want to do it so when i eventually turn on my headlights as it gets darker, all i have to do is turn off the OEM fogswitch and they will turn off and on no problem...
can this be done?
if so, how,, thanks?
Old 03-21-2009, 09:53 AM
  #194
vicgreen19142's Avatar
Hey guys I just got the newer version 20013VA... How do you wire them compare to the old one?? All of the wire colors are different, the new one don't have any green wire.. So what go to what?
Old 04-09-2009, 10:47 PM
  #195
rockstar143's Avatar
Did you install yours yet? Any issues? I'm thinking about doing this...
Old 04-10-2009, 11:17 AM
  #196
bhelsdon's Avatar
Just an update. My drls have been installed for about 4 years and alomost 90k. In that time I had to replace the fuse holder to a better one and I had to solder all the connections that I had t-tapped orginaly. Other than that the module is still working as designed.
Old 04-10-2009, 02:04 PM
  #197
sweet deal...i'll have to give this a shot...thinking about the accord fogs for the bottom and just use the OEM's for DRL period.
Old 04-20-2009, 09:09 AM
  #198
Missing My CL-S
SG81's Avatar
nice job. that was an excellent write up!
Old 05-10-2009, 06:20 PM
  #199
dwb993's Avatar
Thank you very much for this DIY---I had the laptop open right next to me while I installed my module (from AutoBarn).
I drive a LOT of highway miles and I like the idea of DRLs---anything I can do to make it easier to be seen in the Soccer Mom's mirror is a good thing to me.
The supplied connectors are pure shit--if you hold them up to a light, you can see right thru the butt connector part. No wonder they failed for everyone with all the water and crap that must get into them. Go to Radio Shack and buy a decent set, or go the soldering route.
I installed the 20013VA and the wire colors were the same on mine. The green loop must be internal to the unit now, as I did not have one on mine and did not take it apart to check. Follow the enclosed instructions for a Positive electrical system (or follow this DIY).
When I first fired the unit up, it seemed to blink a few times then light up solid---maybe something doing an initial charge up and then run?
It turns on the OEM fogs at 75% about 15secs after starting the car. They remain on when you turn on the parking lights and turn off with the headlights. The factory switch for the fogs works normally. They remain on for about 15secs after turning the car off.
I'm happy and will post any problems or lack thereof in the future.
Thanks again to AZ for the assistance!
Old 05-10-2009, 06:33 PM
  #200
Rev High; Drive Happy
o4Komodo's Avatar
Hmn.....
How about doing the opposite?
Is there a possible way to get the DRLs to turn on with lowbeam as if they were fogs?
[for the TLs that came with DRLs -- such as the newer TLs or the Canadian TLs]
Quick Reply: DIY installation of Daytime Running Lights**with detailed pictures** 3G Garage #G-067
