What's the mileage on your 3G? Still going strong?
Old 02-06-2013, 04:16 PM
  #361
TexanAttorney's Avatar
For those of you with the 2004-2005 TLs and higher mileage (100k+) do you use the sport shift often?
I have a 2004 and try to limit how much I use sport shift to save the tranny. Just wondering if anyone else does this, or how often you all use sport shift.
Old 02-06-2013, 05:11 PM
  #362
I hate cars's Avatar
Sport shift by itself won't affect trans life. Avoiding the automatic 4-2 downshift will save lots of wear on the 3rd gear clutches as will replacing the pressure switches every 2-3 years and running a DexIII equivalent fluid.
Old 02-06-2013, 07:26 PM
  #363
GKinColo08TL's Avatar
4-2 downshift? The TL really goes from 4th to 2nd when in auto?
Old 02-06-2013, 10:38 PM
  #364
jammoye2's Avatar
2005 6 spped original owner. I have 173k on the car with original clutch. It is still going strong!
Old 02-08-2013, 01:03 PM
  #365
That's what I thought when I read that.
How do we avoid 4-2 downshift? By using sportshift and doing it manually?
Old 02-08-2013, 01:27 PM
  #366
If you're rolling along at light throttle and moderate speed, say 40mph you'll probably be in 4th. Punch it and it's probably going to hit 2nd. When this happens it briefly energizes the 3rd gear circuit and there's not enough exhaust capacity to release the 3rd clutches before the 2nd gear clutches engage. 2nd gear has the mechanical advantage so those clutches lock in as they should, 3rd gear slips. The driver may or may not feel a quick forward lunge.
Avoid it by not being in 4th when it downshifts to 2nd either by manually shifting or by "driving around" the problem.
Old 02-09-2013, 09:11 PM
  #367
takin care of Business in
swoosh's Avatar
^^^ manual shifting FTW !!!
Old 02-09-2013, 09:18 PM
  #368
ArthurL's Avatar
This past thursday I hit 150K! Still running strong
Old 02-09-2013, 10:49 PM
  #369
One on the right for me
subinf's Avatar
Life expectancy on clutches? I'm at 190k now and still on the original one.
Old 02-10-2013, 08:28 PM
  #370
GO DAWGS!! SICK'EM!!
TL1999's Avatar
117k and still going...
Old 02-10-2013, 09:17 PM
  #371
ggesq's Avatar
I have 147k on my 05, and I've never used the sport shift. Original tranny and original owner. Changed tranny fluid regularly with OEM fluid and have changed the pressure switches once. I'm due for the switches again though.
Old 02-11-2013, 11:37 AM
  #372
swoosh's Avatar
I have 168K on my 05 TL and I always use sport shift....I even shit down when am coming to a stop...
the only thing about shifting which I have heard is the 4-2 downshift....looks up IHC's explanation on that
Old 02-11-2013, 01:37 PM
  #373
Two Words, Get Paid!
ZonerYang's Avatar
3rd Owner, 2004 TL with 101,600 Miles. Still runs great. Just common small changes need to be made so far.
Old 02-11-2013, 01:57 PM
  #374
StephTL2580
LAGS8005's Avatar
2007, Base Model, Auto, 58,125 miles. Just bought it in December 2012 with 57,125 miles.
Old 02-11-2013, 03:36 PM
  #375
dwb993's Avatar
125K. My new Timing Belt should allow me to double that!
Old 02-11-2013, 03:45 PM
  #376
BANNED
SharksBreath's Avatar
07 TL-S, AT, just hit 57k, constantly using SS.
bought in june 2010 with 35k
Old 02-11-2013, 05:09 PM
  #377
RaviNJCLs's Avatar
That poor car needs to be driven.
Tomorrow I'll pass 139K.
Old 02-11-2013, 05:31 PM
  #378
I like turtles
Redsand353's Avatar
76k on mine....havent even broken the car in yet. Does the MID regulate tranny fluid and pressure switch changes? Or is that something I should just do at this point?
Old 02-12-2013, 07:37 AM
  #379
BANNED
no way!
i gotta keep them miles down!
you'll just have to decide at which intervals you want to do the 1x3's and switches. i do a 1x3 every oil change, some may say its a waste, but i'd rather be safe than sorry and since i'm already down there doing the motor oil why not. i plan on doing my switches again before i reach 100k...so, at this rate, in the next 4-5 years.
Old 02-12-2013, 10:42 AM
  #380
Thanks for posting SS usage. I think this is a great metric for all of us to track. If everyone can post that, it would be valuable information.
Old 02-12-2013, 05:52 PM
  #381
abirvalg's Avatar
05' 133K Amsoil ATF every other oil change
SS when drag racing off of traffic lights
otherwise casually fast driving (30 mph over speed limits )
second tranny, due to the failed stock ATF filter at 120K (way too much grief for $11 part)
Old 02-12-2013, 06:58 PM
  #382
8th Gear
sn3511's Avatar
05 TL auto with 91K Miles on it. Had to change Oxygen Sensor - Check Engine Light reading. Other than that only regular maintenance. Two tires always wear out quicker ( alignment check, balance and rotate tires regularly)
Old 02-12-2013, 10:32 PM
  #383
JohnnyWayne's Avatar
Currently
2004 with 225k
also have another 2004 with 170k
Both are still trucking
Old 02-13-2013, 08:24 AM
  #384
masterstone's Avatar
07 with 77,000km, a little bias opinion since the "newest" car I've owned until now was a 96, but it runs like brand new.
Old 02-13-2013, 09:18 AM
  #385
alexb92's Avatar
'06 5AT w/ ~122k miles. Occasional SportShift, also when I want to hold 4th gear when I'm not going to stay in 5th gear for a while, and to hold lower gears to drive "spirited" down curvy back roads.
Old 02-13-2013, 10:14 AM
  #386
08 MDX, 04 TL (sold)
jhumbo's Avatar
190k miles on mine. It no longer runs "like new". It now feels like a car with 50k miles. This vehicle has just been truly a beast and I am constantly impressed with how well it holds up.
Old 02-13-2013, 10:25 AM
  #387
the overexplainer
ez12a's Avatar
someone has been to 230k or something. i believe he's in the "highest mileage TLs" thread.
Old 02-13-2013, 01:45 PM
  #388
How often do you all use SportShift?
Originally Posted by JohnnyWayne
Currently
2004 with 225k
Old 02-13-2013, 05:07 PM
  #389
revel_one's Avatar
2007 TL-S currently at 58,000 - purchased in 2009-10 w/ 34,000
running like new?
Old 02-13-2013, 05:59 PM
  #390
jhumbo's Avatar
Rarely. I only occasionally use it to downshift from 5th to 4th, but it is certainly not a daily thing or even a weekly thing. I'm still on the original trans by the way. Shifts smoothly and I have been using a cocktail of Redline oils (D4+Racing+LWR) in the trans for a few years now. Plenty of threads on that topic, but it certainly worked well for me.
Old 02-14-2013, 09:24 PM
  #391
Legit Member
Legitka9's Avatar
mcmguti (02-18-2013)
Old 02-15-2013, 10:25 AM
  #392
swoosh's Avatar
someday !!!
Old 02-15-2013, 10:28 AM
  #393
MEKO's Avatar
Received 2,321 Likes on 1,600 Posts
Me too
Old 02-15-2013, 10:33 AM
  #394
swoosh's Avatar
I wish your Trip computer read 117 instead of 119
Old 02-15-2013, 10:37 AM
  #395
MEKO's Avatar
I would've done that but I totally forgot about it
Was waiting for my brother, and saw it the last minute
Old 02-15-2013, 10:41 AM
  #396
swoosh's Avatar
dont make excuses young man....
go to your room and think about what you did....
Old 02-15-2013, 10:43 AM
  #397
MEKO's Avatar
Old 02-15-2013, 01:22 PM
  #398
Rock2534's Avatar
07 TL-S, just turned 52k miles. I rarely use SS, I am used to driving stick, so when I go to use SS I can't help but lift my foot from the gas pedal when I shift. Makes for some odd reactions from the car!
Old 02-15-2013, 03:58 PM
  #399
ajelder01's Avatar
Just bought an 06 TL with almost 80,000 miles on it. Runs great!
Old 02-18-2013, 06:56 AM
  #400
TL = True Love
mcmguti's Avatar
Originally Posted by Legitka9
Ok we have a winner.
Quick Reply: What's the mileage on your 3G? Still going strong?
