Will '06-'07 transmission fit in '04 TL?????
Old 07-29-2012, 07:44 PM
poody's Avatar
My auto transmission just gave out. I found a 07 accord v6 trans with good miles for 800. My question is will it work for my 04 tl and is it easy swap with out mods???? If anyone can help i would appreciate the help im suck and need my car back on the road.
Old 07-29-2012, 09:25 PM
truonghthe's Avatar
Accord tran won't work on the TL because TL has SS mode while Accord just a regular AT with no SS mode.
Old 07-30-2012, 05:56 PM
poody's Avatar
There was a thread I seen a guy put one on his 2 gen type s.... And he said it works I dont seen big difference between 2 gen and 3 gen...
Old 07-30-2012, 05:59 PM
simran4h's Avatar
it will work i was about to do the same for my 2nd gen tl type s when mines was done but i sold it instead.......just the gear ratios are a little different......shouldnt have ni problem from where i see
Old 07-30-2012, 06:37 PM
6SPEED FEVER
EATSLEEPRACE's Avatar
Ive seen it done on the 2g....have yet to hear about it on the 3g
Old 07-30-2012, 08:39 PM
poody's Avatar
Well just bought the accord trans today so will be in by weekend. I hope everything goes smooth. Ill keep yall updated..... I guess ill be the first on here with a 3 gen with 06-07 accord trans..... Hope it works its alot cheaper then tl trans and from what I read has no problems..
Old 07-30-2012, 09:42 PM
mindanaomoro's Avatar
This will be interesting .....
rockyfeller (04-22-2014)
Old 07-30-2012, 09:45 PM
truonghthe's Avatar
well then let us know how it gona turn out and don't forget to post any mod need to be bolt onto the TL.
Old 07-30-2012, 11:11 PM
simran4h's Avatar
yea good luck let us kno how it goes.....and yea tht yr trans is alot more reliable
Old 07-31-2012, 08:48 PM
poody's Avatar
when I swap it in I will keep you guys updated........... Ill have it in by weekend didn't have a chance to mess with it today... Also have to get new seals and get trans fluid...
Also what trans fluid should I use???? I've used amsoil but its hard to get it my way with out ordering it so any kind that would be easy to get?
Old 07-31-2012, 09:08 PM
2007 Type S WDP 5AT
wojo1988's Avatar
just use dealer dtw 1 atf i believe??? bought right from the dealer
Old 07-31-2012, 09:21 PM
csmeance's Avatar
The 07 I doubt will fit and work properly since the ECU and the case was changed a bit in 2005 or 2006. As well the TL-S's won't work since it has a different housing + mount points.
I would be wary of the accord as the accord has less power than the TL and perhaps lighter duty components.
DW1 is the new ATF fluid that acura uses instead of Z1. I suggest you use this to break in the trans and switch over to a better fluid in a few thousand miles.
^ see above post.
Old 08-04-2012, 10:22 PM
poody's Avatar
Installed trans today... I will finish up tomorrow and let you guys know how it drives. The trans was almost identical to a tl. The only thing I had to swap was range sensor mini harness. The plug on harness that plugs to tl harness was a little different but where it plugs to range sensor was the same. So just swap harness and thats the only difference.
Old 08-04-2012, 10:29 PM
2007 Type S WDP 5AT
wojo1988's Avatar
hopefully thats the only difference and when you start the car it runs and shifts properly! well done
Old 08-05-2012, 04:19 PM
poody's Avatar
ok guys finished trans job today!!!!!!!!!!! Im so happy with the results trans shifts so smooth and ss mode works great. Everything was the same minus mini jumper harness that you just swap out. So if anyone needs a auto trans you now have the option to get 06-07 accord trans for your 3gen tl.
The following 6 users liked this post by poody:
9.del (12-29-2019), comkb (10-18-2021), firebolt (05-21-2020), ggesq (02-08-2014), KingPhoenixBeats (05-26-2020), paperboy42190 (02-06-2014) and 1 others liked this post. (Show less...)
Old 08-05-2012, 04:30 PM
poody's Avatar
ss mode works!!! ss mode works off ecu when you shift up or down your sending ecu signal to shift.
Old 08-05-2012, 07:10 PM
Fatfrii's Avatar
stupid 04 Tls only accept tranny from 04. i tried to get a new one when my tranny blew but it wont work. you have to either get and 04 tranny or swap to manual. goodl uck finding the part for that tho
Old 08-05-2012, 08:49 PM
pohljm's Avatar
^? OP's vehicle is an 04? what r u talking about?
Old 08-06-2012, 05:13 AM
poody's Avatar
lol.... yes i have a 04 tl if im not mistaking 99-06 and early 07 tl all bolt up same... 06-07 accord v6 the same not sure about 03-05 accord tho.
Old 08-06-2012, 05:42 AM
Poody did you take any pictures ? So all of the transmission mounting are the same? This is good to know. Give us a long term report after you run many thousands of miles.
Old 08-06-2012, 08:22 AM
dirtyMETHOD's Avatar
I'm about to do this swap in a few weeks for my wife's 02 TL-S .
She's on the second AT that was swapped out by Acura under warranty at 107k miles. Funny part is that she's only put less than 25k miles on the new Acura transmission and it's starting to have the 3rd Gear shudder under moderate acceleration or while going up hills.
Quick question:
Is it any 06-07 AV6 Transmission that will be compatible? Coupe or sedan alike?
tee_el's Avatar
Subscribed... Waiting for pics and long term report.
Old 08-06-2012, 08:37 AM
truonghthe's Avatar
awesome, I am glad it work out for you BTW did you did the 3rd and 4th pressure switch while the trany was out?
Old 08-06-2012, 02:43 PM
poody's Avatar
I have a couple pics of trans side by side they are identical. Yes all of the mounting brackets are the same,even the ones under trans that bolt to cradle. I've put about 150 on it today work a hour away. Its shift like butter so happy with it and it was so much cheaper then a tl trans. I will update when I put a few thousand on it.
Old 08-06-2012, 02:46 PM
poody's Avatar
Thanks!!! To be honest no I didn't ,I will when I get paid next week.
Old 08-06-2012, 02:51 PM
poody's Avatar
Quick question:
Yes coupe and sedan are the same. EXCEPT HYBRID SO MAKE SURE ITS NOT FROM A HYBRID..... I'm not 100% sure if hybrid wont work but ill stay away form it...
Old 02-05-2014, 10:53 PM
9th Gear
lost's Avatar
Reviving an old thread for a status update.
Also can you explain the below statement further? Did you buy a new range sensor harness from Honda or was this something that came with the new Accord tranny?
Old 02-05-2014, 10:58 PM
Stephen00TL's Avatar
You have to swap it over from your old transmission.
Old 02-08-2014, 10:54 AM
rodan's Avatar
Is any of this info from the OP true about the Accord trans fitting a 3rd Gen TL? He never posted any pics or udates after 150 miles!
Old 02-08-2014, 11:55 AM
I think he put at least 10k miles minimum, then I think he had other/issues.
Old 02-08-2014, 12:08 PM
I have done this swap in my 2000 and now have 25000 miles on the swap. There is another second gen member with around 50000 on his second gen. I know a person that swap the av6 transmission into his 05 tl and he is probably around 15-20k miles in his with no issues
CaliBud916 (07-25-2014)
Old 04-21-2014, 09:13 PM
ATL_FlyBoi's Avatar
Any updates on this??? I'm looking at either rebuilding my tranny in the '04 TL or swapping out for the 06-07 AV6 tranny. Any updates or advice are greatly appreciated!
Old 04-24-2014, 11:24 AM
If you have the early 04 tran I would get a good reliable 06 tranny cause it would have the updated casing for better fluid channeling for lube and better "cooling" supposedly. The early 04 trans had that oil jet retrofit thingy.
Old 07-25-2014, 06:17 PM
CaliBud916's Avatar
I might be doing this on my 04 TL. Other than the range sensor harness, is there anything else you need to swap over? Should I change the 3rd and 4th gear switches or just leave the honda ones??
Old 02-02-2016, 04:19 PM
04tl808's Avatar
my 04 tl is starting to slip and found an 05 tl transmission. Will this fit on my 04? Please get back to me
Old 02-02-2016, 05:10 PM
Received 8,585 Likes on 6,631 Posts
Did you read this thread? Are you sure you want to throw in an 05 that may fail as well?
Old 02-02-2016, 05:21 PM
Exactly! C'mom from 2005? You're gambling on the loosing end.
Just have it rebuild, I'm sure by now many updated clutch material and etc... And rebuild process are available.
Old 02-03-2016, 01:46 PM
Confusing Name Guy
N1h1l1ty's Avatar
Actually no, we are still very limited in terms of durable clutch frictions and steels. Raybestos GPX is pretty much the only option AFAIK that would be an "upgrade" per se, and I don't think we even have a better steels option.
HONDA '05 BAYA MAYA & ACURA 04-06 BDGA TRANSMISSION REBUILD KIT WITH RAYBESTOS GPX FRICTION CLUTCHES - The American Powertrain Warehouse
Also a high stall torque converter built by IPT performance would probably be beneficial. They're the ones that did Libert's TC on his turbo 5AT TL.
Old 02-03-2016, 04:39 PM
Cool
Good info
Old 02-26-2016, 12:13 PM
Thomas Gonzales's Avatar
Need help got a 05 TL base transmission went out need to find cheaper transmission that will fit and work good
Quick Reply: Will '06-'07 transmission fit in '04 TL?????
