New Osram Headlight Bulbs (pics inside)
Old 07-20-2014, 06:29 PM
bbergero1181's Avatar
I ordered Osram Xenarc 66240 CBI bulbs from The Retrofit Source and I love them. If any of you are contemplating these bulbs or replacing your bulbs in general check these out! http://www.theretrofitsource.com/com...#.U8xJ_PldV8E\
I believe they even offer a coupon for Acurazine.
The bulbs are much brighter and whiter that my stock bulbs, they have a cleaner cutoff and slight hint of blue. They throw light further and have a better contrast to the road and reduce the nasty glare from street lights.
I am no the most mechanically inclined and in order to install these I removed the bumper and removed the headlight housing from the car to have the easiest access to the bulbs. Removing the headlight housing isn't necessary but i felt that it made the bulb change easier. I recommend removing the bumper to change them because it is not that hard and much easier than going through the wheel well.
These bulbs have only a few hours of burn in and they are already brighter than the old bulbs and will only get brighter over the next few hours of use. These bulbs match my 5000k fogs perfectly. (I couldn't get a picture of the front of the lights that did these bulbs justice since i only have a cellphone camera). If your stock bulbs have a few years on them sometimes its hard to tell that they re dim until your replace them, my old OEM bulbs started to color shift so i decided to replace them.
Before:
After:
The following 3 users liked this post by bbergero1181:
Acura_Dude (07-22-2014), ggesq (07-20-2014), MySoCalLife (07-21-2014)
Old 07-20-2014, 06:57 PM
iHeartmyHonda's Avatar
the cut off is much sharper. looks good !
Old 07-20-2014, 07:16 PM
rossv1's Avatar
Did you change the lenses to get that sharp cutoff or is that with just a bulb change? Either way it looks good.
Old 07-20-2014, 07:18 PM
Steven Bell's Avatar
Wow, very nice.
Old 07-20-2014, 07:35 PM
dezymond's Avatar
Wow what a difference.
Old 07-20-2014, 07:38 PM
The Boss
Nick216's Avatar
Cutoff looks sharper but not as sharp as zkwr. Either way CBI is awesome
Old 07-20-2014, 08:11 PM
Thanks,
I did not change the lenses but I bet if i did it would be even more amazing, but i'm not comfortable opening up the headlights. There is too much risk with my inexperience in doing it where moisture could get trapped. I would love to do the ZKWR lenses though. I also need to recondition the headlight housing exterior soon, its got some pitting and wear from a lot of highway driving and the road salt etc in the winter.
Old 07-20-2014, 08:37 PM
TurnerDan's Avatar
Those look great!! Are they worth the price tag?
Old 07-20-2014, 08:56 PM
JTS97Z28's Avatar
Looks great thanks for sharing. IMO the cutoff doesn't look any different from the original bulbs. The reason it appears sharper is because the brighter output of the CBI bulbs. It looks great don't get me wrong, but I think it's an illusion that the cutoff is sharper. If the lens or spacing hasn't changed then there is nothing that could have changed the cutoff....assuming the bulbs arc is at identical location as the original bulbs.
I like the color and output though, makes me want to consider the bulbs.
I know some people say it's supposed to be that way, but I don't like how your headlights are aimed in that step fashion. I like when both sides are aimed in sync with each other. Just looks more consistant to me, which is how I have seen every car come from the factory. Actually now that I look at the before and after pics again, the first picture with original bulbs is aimed good, but then after you put the CBI's in somehow your left side ended up lower (or your right side went up).
Old 07-20-2014, 09:01 PM
So far so good. They usually take a few hours of use to get brighter so i think these will get even a bit brighter since they only have 3 hours on them tops. I got them on sale for the 4th of july. Shipping was like $4 for the cheapest option i got them for around $150. But they have an acurazine coupon.
If you notice your bulbs getting yellow or color shifting i would get these no doubt. I love bright headlights and being able to see as much as possible at night.
These bulbs are German engineered and manufactured(i think) and German things are usually the cream of the crop.
Old 07-20-2014, 09:05 PM
I have always seen the cutoffs have a step like that. My 04 had a step from the factory. after 80k plus miles of bumpy roads the bulbs can shift slightly and change orientation causing cutoff to change and reduce light output (according to the retrofit source). As far as i know the old bulbs were original so 7 years and change old.
I don't notice a difference in light from the left/ right side due to cutoff. I could be wrong but do they put the driver side lower to keep from blinding oncoming traffic and illuminate the side of the road where signs and pedestrians are?
Old 07-20-2014, 10:37 PM
JTS97Z28's Avatar
Well thats the reason for the step on the cutoff. On the left side it lowers the light output so that it stays below oncoming drivers, and the right side steps up to illuminate the side of the road better and signs. So that feature is built into your headlights and not really dependent on differential aiming between the sides...although proper aiming of projectors is critical. Im one that likes each side aimed at the same height, not left lower than right. And who is they that puts them that way? I have never seen a car come from the factory that way, but apparently people say they do, I just haven't seen it on any car I have owned, or test driven, or was loaned, or driven next to....
sopmodm14 (07-21-2014)
Old 07-20-2014, 11:15 PM
paperboy42190's Avatar
I work with automotive lighting pretty much every day. The correct way as described by the factory service manual is as how jts97z28 said, the slopes need to overlap each other and be at the same height.
I suppose it doesnt hurt to have it as how the OP has it but hes sacrificing visibility on the left side
here is a picture of my cutoff to show what I mean:
JTS97Z28 (07-21-2014)
Old 07-21-2014, 12:33 AM
GOOSEej's Avatar
Wow that looks great did you replace the projector lenses?
Old 07-21-2014, 02:23 AM
sopmodm14's Avatar
some good info here
what are the stock acura bulbs ?
are the OSRAMS a direct fit ?
Old 07-21-2014, 02:30 AM
yes I did, genuine ZKW lenses
GOOSEej (07-21-2014)
Old 07-21-2014, 08:43 AM
JTS97Z28's Avatar
^^^very nice output! Paperboy knows his stuff with lights too. It's funny because after all these years on the forums you pick up on what people know a lot about or what their main interests are in modding ;-)
Old 07-21-2014, 11:24 AM
Sorry I was confused about which step you meant. I thought you were talking about the step in the middle there. But looking back at the pictures I see the second step to the left side, i guess that projector is aimed a bit low. (also that picture is from my driveway which isn't perfectly flat or straight). I had to crop the picture so i could upload it also.
Can that height be changed just by using the Philips head screw driver from the engine bay or do i need to actually get access to the projector?
Old 07-21-2014, 12:17 PM
bla8291's Avatar
My bulbs are due for replacement also. No pink-eye just yet, but they are still the original bulbs from late 2006. I've already decided on the CBIs, but can anyone tell me where can I find genuine ZKW lens? And what's the difference between the genuine ones and the replicas as far as optical quality?
Old 07-21-2014, 12:25 PM
06 WDP/Ebony MT NAV ASPEC
Silva95teg's Avatar
I am waiting on the new philips 85122xv bulbs that i ordered on their last sale, I am hoping they are as good as the CBI's.
Old 07-21-2014, 12:32 PM
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
That's a big improvement from just changing bulbs. I am definitely considering these for when my bulbs die.
Old 07-21-2014, 02:34 PM
JTS97Z28's Avatar
Late 06 isn't all that old, unless your car has a ton of night miles on it then I can see them possibly needing replacement.
As far as genuine ZkW vs zkwr. Don't waste your time and money. A properly "tuned" zkwr will get you 95% of what the genuine ones will do....all for a fraction of the cost and as far as I know they are readily available.
Old 07-21-2014, 03:15 PM
bla8291's Avatar
I always assumed it did, given that I got the car at 175k miles, and that I also drive at night a lot. When I compare my headlights to a brand new car with Xenons, the difference is pretty big. I just don't want to have to deal with one headlight being out...because I hate it when people ride around like that.
Good to know about the lens.
Old 07-21-2014, 04:39 PM
JTS97Z28's Avatar
Yeah thats a lot of miles. Yeah I can see that in your case new headlights would be beneficial lol. My late 06 built 07 only has 14K miles on it and even tho the bulbs are 7 or 8 years old they have very little usage, so I guess it really just depends on mileage.
Old 07-22-2014, 10:23 AM
Land of 10,000 lakes
nate_0022's Avatar
Yes, the projectors can be aimed with a philips screwdriver, you'll see the slots on boths side by the headlights when you open the hood. I believe the OEM bulb for our cars is Osram 66040.
Just need to raise the left side up a little bit so the top lines and bottom lines both line up with eachother.
Old 07-22-2014, 11:06 AM
JTS97Z28's Avatar
^^^amazing cutoff!
pplcrew
01-30-2021 08:59 AM
pistacio
09-26-2015 09:45 AM
njresendez
3G TL Photograph Gallery
09-21-2015 06:32 PM
Greengecko
09-16-2015 08:19 PM
Quick Reply: New Osram Headlight Bulbs (pics inside)
