What Motor Oil Do You Use for your TL?
#322
I use royal purple. 5w-20. After 4 oil changes the valves really quiet down. I used Mobil 1 time only because I was short on cash and it started ticking again. But even I went and changed the oil again and out royal purple it went quiet again. I love this stuff.
#326
takin care of Business in
Received 4,732 Likes
Jeremy if I remember right, IHC was mentioning that most GRP4 oils can go 10K+ interval, its the filter you have to be careful off....
#328
Yup he did....anything transmission or oil usually comes from him and us quoting him/learning from his words haha....
#334
I get mine at Advance Auto Parts...
5qts of Mobil 1 + M1 filter are 32-34 bucks
5qts of Mobil 1 EP + M1 EP Filter is like 36-37 bucks
Those filters are like 12-13 bucks other places...
#336
Isnt Redline's 5w-30 very very thick?
I know he (IHC) was telling me (since I run Mobil1 EP), that Redline 5w20 = Mobil1 EP 5W30 in viscosity...
Here is a little summary from the excel I had made:
For Redline:
SAE Viscosity Grade - Redline 5W20 - Redline 5W30
Vis @ 100°C, cSt ------- 9.1 ---------- 10.6
Vis @ 40°C, cSt -------- 55 ----------- 62
Viscosity Index -------- 145 ----------- 162
Flash Point deg C ------ 251 ----------- 252
HTHS ------------------ 3.3 ----------- 3.8
FOR Mobil1 EP:
SAE Viscosity Grade - M1EP 5W20 - M1EP 5W30
Vis @ 100°C, cSt -------- 8.9 -------- 10.6
Vis @ 40°C, cSt --------- 49.6 ------- 59.8
Viscosity Index ---------- 161 -------- 169
Flash Point deg C -------- 230 -------- 230
HTHS ------------------- 2.75 -------- 3
For Redline:
FOR Mobil1 EP:
#338
I like doing my research
#340
Oh shoot I've never replaced my blinker fluid. I'm going to get this done. Thanks a bunch.
#346
I was just saying M1 5w-40 is known to literally sheer to a 30wt well before it's time to change it. It's a very good oil, the sheering doesn't seem to hurt performance and the HTHT is what matters in use and it's good. Kinematic viscosity is no where near as important as HTHS viscosity.
That Rotella is another badass oil, especially for the price but even without price factored in.
One for you guys to look at if you want a very robust grp IV syn that keeps the engine spotless is Amsoil ACD. It's a straight 30 that qualifies as a 10w-30. Not for every climate but very good stuff. Other than once for a job up in Lake Tahoe and another in Flagstaff where I ran Mobil One 0w-20 and a quick run on SSO 0w-30 I've only had the ACD and Redline in my car.
#347
For Redline:
FOR Mobil1 EP:
For Redline:
FOR Mobil1 EP:
It's the HTHS, Redlines 20wt has a higher HTHSv than most others 30wts. You get decent pumpability and it keeps things separated when the going gets tough. The HTHS is the best indicator of how the base oil is going to perform under stress. Will it give up and sheer down a few weights or will it retain it's viscosity while in a bearing or a ring pack.
Their 0w-20 has almost an identical HTHS as Mobil's 5w-30 which is amazing because the 0w oils are where most oils HTHSv goes down quickly. This is why you can usually run one grade thinner in Redline.
#349
Don't get me wrong, it's a very fine oil, and as I said, the detergent additives may indeed be superior.
#351
^Nothing. We could all use dino at 3/5k intervals.
Doing oil changes this weekend and finally going to M1 EP in the TL. 99,890 miles this morning.
#352
Thats exactly what I posted last week on Page 8...
#353
Again am not sure if Seafoam does anything (many people praise it and a lot of people call it a simple myth)....
But I have been running M1 EP/PP/Valvoline and ran Redline only for 2 oil changes (maybe 3) but thats about it....certainly not enough times to keep the heads clean from the detergents in the Redline oil....
I have run Seafoam every 15K miles....1/2 can in gas tank (with about a gallon and half in the tank), 1/2 can in through vac port and a full can in the crankcase....
let the gas run out almost completely....get some new gas in....change oil within 100 miles of putting seafoam in the crank case
#354
So not a sociopath
However, the crank case, I put it in the 98 accord I had with 200k miles (40 of them mine), it soon began leaking oil, not a lot, and I don't know if it was caused by the Seafoam, but I'm confident after a few changes with Rotella for the TL, if anything was built up, it will be on its way out.
#355
The Boss
I too, buy into the Seafoam affect, I got my TL with 152000 miles on it, did the Seafoam in the tank and vacuum line and took her out for a spin, a friend behind he said he wishes he would have recorded it, light gray smoke for a while.
#356
haha yeah the first time I seafoamed, I was scurrred....
smoke everywhere LOL....
#357
If I'm not changing the plugs I don't like to SF. :/
#358
^^^the first time I did seafoam in the crankcase, I switched out the plugs...
I switch my plugs every 75K miles (which is a very short time since the NGK's can go to 110-125K miles)....I didnt see much fouling, so next time when I seafoamed, I did not change the plugs out
#359
Just old habit I guess. I used to SF/plugs every 3 oil changes on the H22.
#360
What happened to this thread? Seafoam in the vac port is not only a worthless waste of money, it's dangerous. I just replied to a thread last night where someone hydrolocked their engine and blamed it on all if the stuff it must've been cleaning.
There is nothing to clean in our engines that would help performance. Anything in the intake manifold is superficial. The combustion chambers stay extremely clean on their own. If you've ever looked at an intake manifold before and after Seafoam you would be hard pressed to see a difference anyway.
I just wrote the mechanism in which Seafoam makes people believe it works but I'm not going to type it up again.
In the crank case it's dangerous. It's a solvent. It thins the oil, lowering it's ability to protect and it can even hurt seals.
Again, I ask for any reasonable explanation of how any performance can be realized from this over hyped crap. I'm the guy that runs a very expensive oil and changes it too often, same with the trans fluid. I change my coolant every 2 years. I do a drain and fill on the power steering with Redline ATF and I get some heat for wasting money on these products but I'm not about to throw my money away on sucking a solvent through a vacuum port. Water is a much better material for combustion chamber cleaning if you just can't help yourself.
Again, anything in the intake manifold is superficial. There would have to be 100x more crap I there before a measurable performance increase could be seen. The combustion chambers stay very clean and you don't get the constant buildup as we used to with leaded gas and carburetors which is the only combo that might require a top engine cleaning.
The DI engines that have extreme bowl area deposits are recommended to be torn down to the heads for cleanings, not to stick a liquid down the intake manifold that has the potential to not only hydrolock but to wash down the cylinder walls. It's a lot of risk for zero gain.
All you ever have to do is run premium fuel, use a decent oil and change it regularly. There will be nothing to clean.
If you want an amazing product for the crank case, Auto-Rx is the best there is. It's a mix of esters and it cleans the crank case over a 3,000 mile interval. It lubricates as well or better than the oil. It's gentle since it's not a solvent. It's not going to break big chunks of crap off. It's not necessary either if you have taken care of the engine regardless of the mileage.
CrazyEights (07-11-2014)
