TSX Dynos
Old 03-17-2006, 04:29 PM
  #281
JTso's Avatar
Having a baseline is good. Do you also have the dyno file?
Old 03-17-2006, 04:35 PM
  #282
Guinea Pig
CJams's Avatar
Yep! I got the file, unfortunately this new fandangled computer I bought for the shop doesn't have a floppy drive. I will have to upload it from home. I got to see some of your dyno's JT. Do you own stock in Intec?
BTW-You're still the reigning TSx champion
They have a K24 in a civic that pulls 220+hp
Old 03-17-2006, 04:37 PM
  #283
CGTSX2004's Avatar
Originally Posted by CJams
Just got back from intec
Outside Temp=47deg
Gas= Chevron 92 Octane
Max Power=154.2
Max Torque=138.2
Here is a link to the Dyno Pic. I would post it, but it's huge and I can't resize it right now.
http://i9.photobucket.com/albums/a59...2006_00001.jpg
I think I have a pressure washer that's got more power than this car. JK! I can't wait to slap the next Acura salesman that tells me this thing pushes 205horsies.
Was that an 06 on a dynojet?
Old 03-17-2006, 05:21 PM
  #284
Guinea Pig
CJams's Avatar
05 AT on a Dynojet. One of the other TSXs they dyno'd pulled 149hp. Mine was around average for the TSX's they dyno'd.
Old 03-17-2006, 05:29 PM
  #285
Rep'n Taxbrain.com
Tsx536's Avatar
on getting a baseline.
I wouldn't worry about your numbers compared to others. IMHO, it's more about how much your numbers go up as you put mods on.
Old 03-17-2006, 05:30 PM
  #286
CGTSX2004's Avatar
Ah...got it.
Old 04-06-2006, 09:18 AM
  #287
Drives With Hands
rmpage's Avatar
5AT guys, did you do your pulls in 3rd or 4th gear? Final drive ratio in 3rd is almost exactly 1:1, so that's what we should be using. I used 4th on my last posted pull so it is assuredly inaccurate.
Old 04-06-2006, 12:15 PM
  #288
Reach's Avatar
I did the 2006 AT + CAI in 3rd.
Old 04-06-2006, 06:51 PM
  #289
Photography Nerd
Dan Martin's Avatar
I understand that people want a 1:1 ratio or as close as they can get it, but that's only within the transmission. The final drive is 4.70:1 for the MT and 4.44:1 for the AT. I've never seen how they set up the dynos, but do they enter this ratio into their computer? If so, why couldn't they just enter the transmission ratio as well?
Old 04-06-2006, 08:32 PM
  #290
Drives With Hands
rmpage's Avatar
The Mustang derives final drive ratio by conflating roller RPM with crankshaft RPM so it all works out. There isn't any error with them, regardless of what gear you're in. Not sure how Dynojets work.
Old 04-16-2006, 09:13 PM
  #291
T.DoT P.I.M.P. lol
chuson's Avatar
Hey Dan~
Do you know where and how much to Dyno in Toronto???? And which is your favourite one??
Old 04-18-2006, 06:09 PM
  #292
NJTSXMan's Avatar
I'm trying to find a shop with a dynojet here in the NJ/NY area.. the only thing I can find is mustang dynos. Anyone know?
Old 04-18-2006, 08:15 PM
  #293
Drives With Hands
rmpage's Avatar
Why? Mustangs are far and wide superior test equipment.
Old 04-18-2006, 11:09 PM
  #294
JTso's Avatar
How does the Mustang dyno handle temperature changes and apply SAE correction?
Old 04-19-2006, 05:32 AM
  #295
Drives With Hands
rmpage's Avatar
It's all done by the software. Being able to dynamically vary the load it puts on the wheels (the rollers use eddy current brakes rather than simple inertial resistance) makes for a very flexible platform. Also with a Mustang you can tune the engine under load, rather than having to adjust a setting, do a pull, adjust it again, etc.
Old 04-19-2006, 10:11 AM
  #296
JTso's Avatar
I know the Mustang dyno can load the wheels during runs to simulate road condition. But I don't ever remember seeing any SAE corrected dyno output using a Mustang dyno. The auto manufactures and DynoJet use SAEJ1349 standard to measure outputs, which means the output of a car tested under one temperature condition is the same as testing the same car under a different condition by using SAE correction. By not using SAE correction, the output is for that particular day and condition and can not be used for proper comparison. Many people intentionally used non-corrected numbers to brag about outputs, but SAE numbers are more meaningful.
Some SAEJ1349 info... www.sae.org/certifiedpower/details.htm
Old 04-20-2006, 08:37 AM
  #297
Drives With Hands
rmpage's Avatar
Doh, now I know what you mean. I'm not sure about that. I'll ask next time I'm down there.
Old 04-21-2006, 04:33 PM
  #298
NJTSXMan's Avatar
I finally found a dynojet to dyno my car. Is that slight dip and increase at 5,000 rpms normal for an hondatafied ECU?
2005 - 5AT with Comptech Header, Comptech Icebox, Random Cat, Hondata,
and stock exhaust.
My best run:
Old 04-22-2006, 11:14 AM
  #299
Drives With Hands
rmpage's Avatar
Mine didn't show any sort of dip; torque at VTEC was perfectly flat. However the little corkscrew artifact at 6900 can be ignored - that's the torque converter unlocking in preparation for the next shift. Actual peak hp is probably 4-5 less.
Old 04-22-2006, 11:30 AM
  #300
NJTSXMan's Avatar
Interesting... any reason why there would be an hp/torque dip at vtec? or the cause of it? thanks.
Old 04-23-2006, 02:57 PM
  #301
Member
hondata's Avatar
Yes. The cam angles on each side of the VTEC point are about 15 degrees apart. The cam takes time to rotate, so just before VTEC we rotate the cam into position needed for the high cam. This decreases power just before VTEC, but the result is a better powerband above VTEC, ie it is a compromise.
Looking at your torque curve I can tell you have good breathing and a low restriction exhaust by the way your torque jumps after VTEC. Your setup would support a lower VTEC point.
Old 04-23-2006, 03:35 PM
  #302
JTso's Avatar
Good inf hondata. I see a SC setup in his future with a lower vtec point.
Old 05-07-2006, 07:06 PM
  #303
andrew4037's Avatar
edelbrock is making manifold for 24 k with wicked throttle body get reflash they say
Originally Posted by RogerPodacter
I have a question about the torque. At 5,500 RPM the torque starts to drop off. IMO this is where vtec should kick in. Isn't there a way to reprogram the ECU (C'mon handata) to keep that level of torque flat all the way to 6,800 RPM?
edelbrock is making manifold for 24 k with wicked throttle body get reflash they say v-tec will pop in the 3,000 to 4,000 range cant wait
Old 05-07-2006, 08:34 PM
  #304
CGTSX2004's Avatar
Can we get that one again in English?
Old 05-07-2006, 09:37 PM
  #305
Reach's Avatar
OK, that piqued my curiosity enough to warrant an email to edelbrock. Not that the above guy knew what he was talking about at all, but I hit their website and they have a section marked "New" for Honda/Acura.
Old 05-20-2006, 02:54 PM
  #306
JTso's Avatar
UR Pulley dyno
Before and after results.
Old 05-20-2006, 02:57 PM
  #307
Bye TSX, hello domestic?
xizor's Avatar
nice low end gain there, and gains all the way through
Old 05-20-2006, 04:12 PM
  #308
Photography Nerd
Dan Martin's Avatar
Nearly 200whp
Old 05-21-2006, 03:43 AM
  #309
oem tsx's Avatar
time for an update...
that is my lastest dyno and here is all the data i have collected on my car over the last 3 years:
1/4 mile best time stock - 16.5s california speedway
1/4 mile best time full mods - 14.7s
1/8 mile best time full mods - 10.02s irwindale drag
mpg: 24 avg
mods:
04 mt w hondata
injen cai
comptech header
custom single exhaust
carbon fiber hood
hankook RS2
kosei k1 ts
buddy club N+ spec
comptech rear sway
ingalls camber
i tried really hard to take off as much weight as possible. For every part i replaced i weighed the stock and the new. so far i've calculated my car to be approx 3230lbs - 96lbs = 3134lbs w 207 whp dynapack
Old 05-21-2006, 04:02 AM
  #310
oem tsx's Avatar
here is a resized dyno
when launching im still gentle with my car, so launches are only @ 2-3k rpm
hardly launching at all, but its just my stomach churns if i jolt my car violently.
i want to see if i can i drive it 100k + miles with all my mods + hondata.
I know my car is capable of faster times with a better launch.
also, am i the only one in the USA who sacrificed the super powerful dual exhaust look of our slow stock tsx and went w/ single exhaust for max performance?
i think dual exhausts on slow cars is a parody
Old 05-21-2006, 04:18 AM
  #311
oem tsx's Avatar
tip: my single exhaust added 10lbs of torque and saved 30lbs off car
Old 05-21-2006, 04:19 AM
  #312
Drives With Hands
rmpage's Avatar
I agree duals on engines with one exhaust manifold are a bit silly, but nobody's ever really done a comparison between single and dual-muffler performance exhausts on this car. Given that the Y pipe is so far back on the car, I don't imagine it making a difference. What is important to remember is that heat is what makes exhaust gases move quickly down the pipe, as when the exhaust is hotter, pressure is higher, the compressions and rarefactions are more pronounced, ergo everything is moving faster (thus the reason for coated manifolds, especially on turbo cars). By the time the exhaust hits the Y pipe it is back at the rear wheels. It has cooled considerably, and the pulses have combined into a steady stream somewhat. So from a thermodynamic standpoint it doesn't seem like that would make a big difference, but I'd be interested in any related testing data.
Nice output by the way.
Old 05-21-2006, 12:15 PM
  #313
JTso's Avatar
I would be interested to see a single vs dual exahaust comparison, but I doubt it makes much difference like rmpage has mentioned. Unfortunately, we might never find out so all the speculations remain. However, if anyone is willing to send me a single exhaust for testing, I will cover the dyno fee.
Old 05-21-2006, 02:28 PM
  #314
oem tsx's Avatar
i think those aftermarket exhausts people get may be heavier than stock exhaust. They may actaully be going slower for the big dual exhaust look.
fyi: the stock dual exhaust weights in @ 61lbs.
also ne1 need stock intake, header, exhaust, springs and shocks, and sway bar pm me.
Old 05-21-2006, 02:52 PM
  #315
NJTSXMan's Avatar
14.7s 1/4 mile.. impressive... I believe you have the fatest recorded time for a TSX 6MT.. The second fastest was 14.9s for a 6 speed.
mpg: 24 avg
mods:
04 mt w hondata
injen cai
comptech header
carbon fiber hood
hankook RS2
kosei k1 ts
buddy club N+ spec
comptech rear sway
ingalls camber
Old 05-21-2006, 02:59 PM
  #316
oem tsx's Avatar
i think 14.5s 1/4 mile is possible with better launch
Old 05-21-2006, 03:50 PM
  #317
JTso's Avatar
The two aftermarket exahust systems I tested weight less than the stock system. The entire package including the big shipping box and packing material is under 60 lbs.
Old 05-21-2006, 04:38 PM
  #318
Special-K
PrecyseStylez's Avatar
Where did you run that 14.7??
Old 05-21-2006, 07:56 PM
  #319
Chris_F's Avatar
well a single exhaust wont have any negative effects thats for sure. The exhaust Im still waiting on (j's racing) weighs about 5kg flat. That's a saving of over 15kg over stock.
Old 05-21-2006, 08:39 PM
  #320
JTso's Avatar
The weight saving is definitely good. Let us know how loud it is once you have it on.
Quick Reply: TSX Dynos
