F-168 Steering wheel removal???????
Old 07-30-2014, 08:01 AM
under renovations....
CubanLynx84's Avatar
PB make sure you're careful with the cable reel!
Old 07-30-2014, 08:55 AM
aIRpeACE's Avatar
great write-up
Old 07-30-2014, 12:22 PM
Thanks bro!
Old 07-30-2014, 05:37 PM
paperboy42190's Avatar
I was very careful during the install. all the buttons still work and the cable reel still spinning like it should. thanks for the diy
Old 09-02-2019, 02:28 PM
fcasteve's Avatar
I used your instructions to help me remove the steering wheel on my 2008 Acura TL w Navi. I needed to fix the Cruise Control switch which had stopped working and would not stay in allowing cruise control to function. I was trying to follow another post that said you could remove the back screws holding the cruise control module to the steering wheel. I found that to be impossible with the back cover on, so I removed the wheel and the rest was easy. I was able to replace the white plunger in the switch from Mouser part#: 688-SPPH120400 without having to desolder and replace the whole switch. There are other posts that describe how to do this. So, for $12 including shipping for 2 switches (I screwed up the 1st try and had to resort to using the white plunger from the 2nd switch), I now have a functioning cruise control switch!
Old 03-09-2020, 02:19 PM
wusty23jd's Avatar
Okay, I'm bumping an old thread here as I will be removing a 2005 steering wheel this weekend. I'm seeing mixed reviews about needing a steering wheel puller or not. How many people have been able to remove without one?
james357
02-13-2016 02:37 PM
IIDXholic
09-19-2015 10:18 AM
SpraykwoN
ILX
09-11-2015 08:45 PM
MyKids&Cars
09-02-2015 12:03 AM
Quick Reply: F-168 Steering wheel removal???????
