Axle nut, reverse thread?
AzN-SoLjA
I've taken off the tire and the cover plate, but the axle nut is stuck and a friend said it could be reverse thread. Any immediate help would be appreicated. 97' CL
have u taken anything else but the nut off? balljoints, tie rod anything? well, first get it to go in alittle so u can breake the rust then u have to take off the ball joints upper and lower and tie rod to remove the axle. wait what the hell r u doing ne ways?
AzN-SoLjA
lol thx for the help im just replacing my bearings because my front left one is dying and is making really grinding sounds and i havnt drivin it for a while xcept today to this house to get it fixed. we got to the axle hub thing it should slide right ( with a little muscle ) off and i should be able to take the rotor off shouldnt i? we cant get this little hub off and weve used a puller with no success. so tommorow we are using a torch to heat it up and the puller to get it off. but any advice is appreciated.
AzN-SoLjA
Originally Posted by baka_t
1000lb 3/4 impact gun will do the trick.
navtool.com
31
11-16-2015 08:30 PM
