Changing HID bulbs without removing front bumper?
#41
replace everything with NEW/USED OEM parts.
did you find the correct harness yet?
search for the correct harness at (link) www.acuraoemparts.com (/link)
then you will need to solder the connection and then wrap it.
#42
I am going to order these
http://www.ebay.com/itm/321239492685?_trksid=p2060778.m2763.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/200619668933?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
which i will replace the harness and the ignitor....
#43
Trace the wiring back to where it was butchered. Replace everything from there forward with OE parts. I'm sure the headlight assembly isn't OE either and you'll have wonky grounds.
Any evidence of an intentionally botched repair to save money is a promise of future problems. The electrical systems in modern cars is very fragile anyway and even simple mods can cause problems.
Here, you know that the electrical system has been butchered. There is a reason the car had a salvage title - because it couldn't be repaired economically if done correctly.
My advice is to fix it properly and sell it. Don't go looking for other problems because you will find them and your wallet won't like what you find. If you find them then you'll have to fix them properly.
Sorry, but you have to face reality. This car will leave you (or your wife and child) stranded on the LIE one day.
soupi (09-22-2014)
#45
Acura Mazda Honda Xenon HID Igniter Inverter Control Unit Ballast Module | eBay
07 08 11 Acura RDX ZDX Xenon Headlight HID Ballast | eBay
Do you own a 07/08/11 RDX or ZDX? If not, then that probably isn't the correct part either.
Fixing that car will cost lots of money, take lots of time and require a good mechanic who really understands the car. This isn't meant derogatory (because the same applies to me) but that isn't you or me. You need to understand your limitations - I (and many others here) have learned that the hard way.
soupi (09-22-2014)
#46
This past weekend I got a chance to replace the ignitor and ballast with the OEM parts. Also while I was at it I converted my fogs to 5000k HIDs.
Thanks for your guys help and input...
#48
Notice the excessive glare of the foglights? You'll also want to get the headlights aligned properly.
#50
opboarding (09-29-2014)
#52
Graphite Ghost
more ceb overkill
half tank of gas.
find a flat place with a wall.
like a home depot. stop in a get a tape measure and some tape.
also make something to block one headlight a piece of cardboard will work.
for the height there is a mark in your headlight lens looks ike a O that marks the height.
measure that from ground.
then place that location 25 feet back from wall.
put bottom of tape even with that mark on headlight.
using the up down move the high mark or CUT OFF of your headlight even with the tape.
done.
actual US code is 2 inches below at 25 feet but I like the EU standard better.
just like you did with the igniter and ballast, ignore ceb and find a comparable solution.
sure if money is no object then we pull the tsx in to stealer and say here is a blank check and dont forget to bend over too/
half tank of gas.
done.
bagwell (09-30-2014)
#53
more ceb overkill
half tank of gas.
done.
half tank of gas.
done.
As usual, you have oversimplified the process. Here is the correct procedure for visual aiming. The difficulty will be finding a perfectly flat area where you can pull back the 25ft and still have room for the car - so about 50ft or so.
#56
Of course he doesn't have one - a decent shop would have one and the point was that the normal shadetree methods of adjusting headlights works poorly with HIDs.
He'll be the guy that oncoming traffic hates because the one headlight it pointed up in their direction.
#58
I can pick out a car with accident repair from 50 feet at night - not by the bodywork but by the headlight alignment.
#60
TSX AMG Type //M i-VVT
all i see at night is dumb fucking retards driving around with highbeams on.
iCrap (10-01-2014)
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
