clock problem
Old 10-03-2005, 08:36 PM
merkin110's Avatar
clock problem
Does anybody know how to fix this problem with my clock?
Old 10-03-2005, 08:49 PM
NiGhT rIdEr
bkzjimmy's Avatar
im pretty sure that cant be fixed....it might have to be changed.
Old 10-03-2005, 10:03 PM
merkin110's Avatar
Well yea I am sure of that also. Anybody know if this is a good DIY?
Old 10-03-2005, 10:21 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Its very easy to get to teh clock. replacing it is just a few screws
Old 10-04-2005, 12:39 AM
merkin110's Avatar
How about getting to the clock? You know like taking off the panel and stuff.
Old 10-04-2005, 01:21 AM
merkin110's Avatar
And do i need to replace the entire clock unit?
Old 10-04-2005, 09:15 AM
fsttyms1's Avatar
LIke i said do a search for Indaglo Gauge DIY's. There will be instructions to getting the dash apart (very easy) then you will see the clock. Odds are you will need a new clock
Old 10-04-2005, 09:24 AM
NiGhT rIdEr
bkzjimmy's Avatar
heres the diy....... http://files.subtledream.com/TL/reve...low_gauges.htm
Old 10-04-2005, 11:01 AM
merkin110's Avatar
Sorry but you didnt say anything like that at all.
Old 10-04-2005, 12:02 PM
fsttyms1's Avatar
Sorry. thought i added that in my last post.
Let me search for you
Originally Posted by bkzjimmy
:edit: looks like he beat me to it
Old 10-04-2005, 12:52 PM
merkin110's Avatar
Thanks for the input everyone
Old 10-04-2005, 08:25 PM
woooo!!
subtledreamer's Avatar
you know what, last time i opened up my dash i happened to be tinkering around with the clock... once you open it up you'll likely understand how it works. i think basically the components have slided around causing the PCB to make full contact with the electric source which causes the screen to become black.
damn i just realized how bad the wording is... but yeah open it up and you should be able to fix it ok. GOOD LUCK!
Old 10-04-2005, 09:57 PM
merkin110's Avatar
So basically i just replace the clock unit? There is no way to just fix it right?
Old 10-05-2005, 08:15 AM
crazylokko
Afro TL's Avatar
Can i replace the bulb for the clock also this way ?
thanks
Old 10-05-2005, 08:32 AM
fsttyms1's Avatar
Well subtledreamer said you can look at it and see if its fixable, see if every thing is making contact. But if not its not like a bulb went out and you can replace it.
thanks
Yes
Old 10-05-2005, 11:57 AM
merkin110's Avatar
Yes
Man you know everything.
Old 10-05-2005, 12:35 PM
fsttyms1's Avatar
Almost every thing. If i knew tonights powerball #s id be real happy
Best bet for your clock is to pull it out and look at it. Maybe check around a few salvage yards to see if they have one you could get?
SidhuSaaB
05-30-2020 12:40 AM
12vancover
10-16-2015 12:04 PM
Skirmich
10-01-2015 12:59 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
2Quik
09-23-2015 01:03 PM
Quick Reply: clock problem
