Random sensor cable hanging after going to mechanic?
Old 09-18-2022, 12:00 AM
Gold3.2's Avatar
Hi All,
My 3.2 TL had been overheating and when I went to look at the engine bay I saw this loose connector and can't figure out what it's for or where it goes? Can anyone provide any idea of where it should go and what it does?
Maybe it's related?
It's the gray thing sticking out next to the hose.
Old 09-18-2022, 06:56 AM
Received 1,736 Likes on 1,392 Posts
Best guess is a fan motor connector (red)?
Look deep down the side of the A/C cond. fan (purple) there may be a connector end to plug to.
Old 09-18-2022, 09:19 AM
USAF Veteran
Saudade's Avatar
Well don't think it's the fan, but Zeta is on the scent!! Here's my '01 with the fan connection and bundles. Can't see over enough to tell on yours. However, like Zeta said, it you look down along the fan shroud, you should see the small connector that, I believe, goes to the AC clutch. So does your AC work?
Top of fan
Note small connector circled in red
Old 09-18-2022, 04:08 PM
Gold3.2's Avatar
Going to check the ac, but first this is the inside of the connector
Inside of connector
Old 09-19-2022, 05:42 PM
Gold3.2's Avatar
Nope ac doesn't work and got a scan tool - P1486 - cooling system malfunction
Top of fan
Old 09-20-2022, 02:36 AM
Jon M's Avatar
That connector looks like if has been off for a while. I hope you cleaned it well (both ends) before reinstalling.
Old 09-20-2022, 10:14 AM
Received 8,584 Likes on 6,630 Posts
Take it back to the mechanic fool!
Old 09-20-2022, 10:59 AM
Gold3.2's Avatar
I would have, the sold the business they told us after working in the car or I'd go back.
Old 09-20-2022, 01:18 PM
Unregistered Member
Karanx7's Avatar
It's the A/C Compressor connector. It won't fix your overheating problem, but you won't have A/C without it.
Old 09-20-2022, 01:22 PM
Gold3.2's Avatar
After reviewing the photo kindly provided and spending an hour with a flashlight I figured it out. The mechanic broke the other end of the connector and that's why I could find it anywhere, found a random green wire tucked away. So this car won't have ac without someone fixing the connector. Overheating issue I realize the gauge doesn't work and no data in the Obd2 read out so they definitely screwed something up. Thanks everyone for helping me out with this mystery.
Old 09-20-2022, 01:42 PM
Explains why they sold the business..
Old 09-20-2022, 01:43 PM
Gold3.2's Avatar
I spent so many hours looking up YouTube videos and looking up used ac compressors trying to wonder where they moved the cable as I should see a big gray clip. Feel like an idiot now. Time for it to be donated.
Tidy Whitey
03-01-2019 10:55 AM
noynek
1G TL (1996-1998)
05-21-2018 03:05 PM
FreeIsGood
09-14-2017 11:32 AM
TheSauceBoss
04-20-2017 10:29 AM
filthycasual69
1G TL (1996-1998)
02-26-2017 07:16 PM
Quick Reply: Random sensor cable hanging after going to mechanic?
