Wipers not consistently sweeping the entire windshield?
Old 10-17-2011, 11:48 AM
Severin's Avatar
Question Wipers not consistently sweeping the entire windshield?
Hi All. I've noticed over the last week or so that my PIAA beam blades are not always traveling fully and not always parking fully; they are sometimes up to 2 inches off of the full throw of the wipers. Of course, this is on a fully cleaned and wet windshield.
If I pull the stick in hard to manually wipe the windshield (this makes it go full speed), it has a much better chance of making the full sweep of the window (though I think it sometimes goes too far then and bangs).
When the blades are parked, I can easily move the top tip of both blades simultaneously in and arc of about 3 inches - that is how much play I have.
I don't remember what the normal play should be. Since both blades move at the same time, the splines aren't an issue.
Could the linkage assembly be worn or is the motor tired?
Old 10-17-2011, 01:34 PM
TLer trash's Avatar
It's most likely wiper linkage. There are two pieces with nylon caps at each end that get real loose at the ends. There's a diy on here somewhere with part #s, and pictures, if I remember correctly.
Old 11-04-2011, 09:49 AM
Every porn dvd in a
FireNation23's Avatar
your "play" is not normal. I can't move mine at all. I can't stand how acura downgraded their oem wiper blades and I have been going with the latitudes by rain x and they suck in about a couple of months. Has anyone tried using the tsx blades on the 2nd gen TL
Old 11-04-2011, 12:16 PM
2000 TL Black on Beige
Sperry's Avatar
I recommend putting the following search words into google: banging wipers acura tl
The very first hit will take you to a particularly well-written DIY.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 04:35 PM
MrHeeltoe
09-28-2015 05:43 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: Wipers not consistently sweeping the entire windshield?
