Looking for low mileage 06-07 accord 3.0 tranny
Old 05-16-2015, 01:18 AM
ttvegas2002's Avatar
Hello all, does anyone know where I can get a low mileage 3.0 auto accord tranny? Mine 2002 type s has no 3rd gear, going to do a swap but need to get the tranny first. Thank you in advance
Old 05-16-2015, 06:09 AM
MarcDavidoff's Avatar
Look on car-part.com
Old 05-16-2015, 02:38 PM
What is the difference between jdm av6 tranny and usdm sv6 tranny? Can anyone help me out?
Old 05-17-2015, 03:14 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
welcome, Please read the thread titled `AV6 swap` for info you need
its near the top of gen2 thread list
the obvious difference in numbers you gave are Japanese's Domestic Market and US market
someone installed a JDM trans the other day - on here- and has issues with it running higher rpm
Note: that person re-used the stock torque convertor which may be loaded up with crud from last trans failure!
Old 05-17-2015, 03:16 AM
01tl4tl's Avatar
try your local junkyard (auto dismantler), They will use the connected radiophone system (pre-internet communication method) to locate one for you from other place if they are out of stock
There are many (iirc) 06-07 trans avail from crashed accords
750$ is max you should pay
Old 05-24-2015, 09:26 AM
Thank you 01tl4tl, I found one from LKQ, has 64k miles from sn 2007 with shipping and everything I got it for $1200. Should be delivery within the next couple days
Old 05-24-2015, 10:58 AM
01tl4tl's Avatar
please spend the money on a rebuilt torque convertor, the old one is plugged with clutch particulate matter and will ruin the new trans!
plan on a few times of drain and refill fluid change to get all the old stuff out of trans and be on the Honda dw-1
Guessing the accord trans has external atf filter like ours, replace that as well!
ck the shift/pressure switches solenoids whatever they may be called. Much easier to clean or replace while trans is on the bench
Don't forget the front and side motor mounts inspection, the front can fail every 70kmiles! Its way easier to replace with trans removed,,15 minutes
Old 05-24-2015, 12:23 PM
The av6 tranny come with the torque converter as well, do you think I can use the one that's is gonna come with the tranny or buy a rebuilt one? For sure I'm not going to use the torque converter from the old tranny that I just pulled out from the tl's
Old 05-25-2015, 10:10 AM
01tl4tl's Avatar
you have ZERO reason to believe the used TC with the used trans is going to be in like new condition!!
Assume its fluid was never changed and its holding a lot of crud, just waiting to ruin your trans!
Spend the money now, or do the whole job again later, hmmmm you have vegas in your name,,do you think the casino is going to win?
If you stay with the old unit and come back here in a month saying trans wont shift,,
do we get to give you a bunch of %$* about it?
Old 05-25-2015, 12:00 PM
I'm going with your oppinion 01tl04tl, I'll get a rebuilt torque converter. Now my question is am I going to get the one for the tl's or the av6 torque converter? Is it 22 spine? And yes I live in Las Vegas and don't like to gamble or raking chances, I want to get it done and doing right the first time.
Old 05-25-2015, 11:30 PM
01tl4tl's Avatar
Im not informed enough about the two trans to offer advice beyond get a rebuilt TC
I know,, can you believe it, something I don't know!!
Guessing you would use the one that's made for the replacement trans
What does our DIY on the swap have to say? changes in rpm and shift points?
If still in doubt PM fsttyms1 our guru of mods and swaps
TRANS SWAP GURUs- help us out!!
Old 05-25-2015, 11:33 PM
01tl4tl's Avatar
I have heard you need to pre-fill the new TC with Honda dw-1 atf as much as possible
Many problems getting fluid in once its installed and it holds about half the total capacity
(not certain of capacity on accord trans, TL was 7.3 qts)
shoot! 2 things I don't know! I better get off the internet~
engine rear main oil seal is a good replacement now- with trans out.
any trans seals, shaft seals etc that can be replaced should be, and cleaning or replacement of pressure switches/solenoids
Call it insurance
Old 05-26-2015, 12:19 AM
As far as my swap goes, ordered used 2007 av6 tranny with torque converter from LKQ and has about 64k miles on it, don't know if that's actual mileages on it or not. Heard from a friend today and he's said all of the recycler marked their mileage down by 40% of their actual mileages. The tranny will be delivery tomorrow, ordered rear main seal, new external aft filter, two new axle shaft seals, all new solenoids exception of the speed sensor and gear position sensor and also in the process of ordering a rebuilt TC ($150) for a rebuilt TC. Anything else that I might have left it out?
Old 05-26-2015, 09:58 AM
01tl4tl's Avatar
Honda dw-1 atf!
Old 05-26-2015, 11:38 AM
MBP 03's Avatar
New o-rings for the oil warmer assembly.
New gasket for the spin on filter housing (goes between the housing and trans).
Torque converter o-ring for the trans input shaft.
Trans input shaft seal.
01tl4tl (05-26-2015)
Old 05-26-2015, 12:41 PM
Good to know to filled up the TC before installing. I did manage to get the TC seal and the aft warmer gasket as well
OculiAquilae
11-19-2018 02:24 PM
justin7779
12-25-2015 10:33 PM
mugen_kid
11-13-2015 10:38 PM
PortlandRL
09-14-2015 12:01 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Looking for low mileage 06-07 accord 3.0 tranny
