Dimmer switch has no effect on dash. Need help please
Old 10-09-2015, 01:19 AM
ttvegas2002's Avatar
Hello everyone,
Installed aftermarket headunit on my 02, everything is wired up. All the lights are working, grounded connector 19 ( red wire ) and taped the red/black wire. Any way my dimmer switch seem not adjusting the dash lights when turning the switch back and forth, checked the switch with the ohm meter and seem like the switch is working. Is there any way I can get my dimmer and brightness adjustment back with he dimmer switch? Does anyone had an electrical wire diagram for it?
Old 10-09-2015, 02:06 AM
01acls's Avatar
Double check to make sure that the connector didn't fall off.
Old 10-09-2015, 08:08 AM
I did the the resistance on the switch and the resistance is within the specs, i thought the driver side mcu could be bad so I did replaced with the used one bought it from eBay. Is there any wire diagram running from the switch to the mcu and from the mcu to the dash?
Old 10-09-2015, 09:07 AM
01acls's Avatar
If it's not the mcu then it's a bad switch.
Old 10-09-2015, 11:34 AM
Checked the switch seem okay, voltage at 0v when turn off and goes up as turning the control knob, I really don't know what else could it be. Dash light just stay at one setting brightness when combination switch is on.
Old 10-09-2015, 11:46 AM
MilwaukeeDave's Avatar
With our cars it's either dim or bright. You only hook up one of the wires out of the 2 for dimming. I think it's orange/black you use and plain orange just sits.
Old 10-09-2015, 11:47 AM
01acls's Avatar
Seems like you got the wires crossed or a short to a hot wire therefore its at full power all the time.
Check your connections- undo what you did and see if the dimmer works.
Old 10-09-2015, 12:06 PM
I know the head unit has nothing to do with the dash dimmer, but on the 20pin stereo connector I did ground the red and left the red/black alone.
Old 10-09-2015, 12:08 PM
You said hook up 1 out of two wires? Is it at the 20pins radio connector? Where does it located at?
Old 10-09-2015, 12:13 PM
01acls's Avatar
That could be the problem bc thats the ground side.
Old 10-09-2015, 12:25 PM
01acls's Avatar
[/QUOTE]
That is your problem bc by grounding the red wire you just completed the circuit.
You see the light in the diagram? That is powered. By grounding it you just turned on all the lights on that circuit... master controlled by the light switch.
Old 10-09-2015, 12:45 PM
You see the light in the diagram? That is powered. By grounding it you just turned on all the lights on that circuit... master controlled by the light switch.[/QUOTE]
Where or what should I do with the red and the red/ black wire?
Old 10-09-2015, 01:04 PM
01acls's Avatar
The correct way is to wire the stereo light parallel with the lights in the diageam.
See diagram.
ST= Stereo illumination lamp.
Old 10-09-2015, 02:48 PM
RDX-Rick's Avatar
See diagram.
I agree with this.
The red/blk wire is connected to fuse (i.e. +12v). The brightness is controlled by how much current is allows to flow to ground through the red wire. Since you grounded the red wire you have maximum current flowing to ground and therefore maximum brightness.
Old 10-10-2015, 04:12 AM
Originally Posted by RDX-Rick
I agree with this.
How do I rewire the red and the red/black wires back in order the the dimmer switch to work on the dash? If my stereo does not have the illumination or dimmer?
Old 10-10-2015, 08:06 AM
RDX-Rick's Avatar
Based on the information in your original post, the factory head unit (HU) had both the red/blk and red wires connected to it. I also assume from your description, that after you grounded the red wire that all the dashboard lights went to full intensity and not just the lights on the HU.
I don't know if your new HU also requires 2 wires for illumination, or only a single wire. If you could post an image from the installation instructions for your new HU I could give better advice. You could also provide the model of HU and I could search for the installation manual using Google.
If your new HU requires 2 wires for illumination (often labelled illum+ and illum-), then connect the red wire to the illum- terminal and connect the red/blk wire to the illum+ terminal.
If your new HU only has a single connection for illumination (often labelled illum+) then connect the red/blk wire to this terminal and tape the end of the old red wire so that it cannot accidentally contact anything under the dash.
If your HU uses both wires, then the brightness of the HU will vary as you turn the dimmer control. If it only uses one wire the HU will always be at full brightness.
Either way, the remainder of your dash should return to it's normal status, and once again allow varying brightness.
Old 10-10-2015, 08:06 PM
Thank you everyone for helping me out, finally I got it to working. I disconnected all the wires and check one by one out and left the red and re/black alone. Now my dimmer switch is working. Thank you very much for the helped
Old 10-10-2015, 09:21 PM
RDX-Rick's Avatar
Do you have any nighttime illumination of your new HU with those wires not connected?
Old 10-10-2015, 09:58 PM
I got a cheapo HU with no input for the illumination, just straight bright provided by the power wire.
Old 10-13-2015, 11:41 AM
This is the cause. Dash illumination passes thru the HU.
hrothgar02
09-28-2015 11:08 AM
lowgrowl
09-26-2015 05:18 PM
2Quik
09-23-2015 01:03 PM
Ty-Sama
09-21-2015 05:45 AM
Greengecko
09-16-2015 08:19 PM
Quick Reply: Dimmer switch has no effect on dash. Need help please
