99 tl short ram question
Old 07-19-2015, 08:24 PM
skinnyBEAN's Avatar
Cheapest short ram I could find is here... 99-03 Acura TL / CL 3.2L Performance Short-Ram Air Intake - Polished Was wondering if this is a good one and if the site was trusty.. Thank you
Old 07-21-2015, 10:47 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
just remove the intake resonator box below air filter- hiding inside lower panel of engine cover, see DIY section for help, 1st mod by many ziners!!
It has to come out to do a short ram conversion anyway- so just remove the box and now air gets thru 2 large holes on bottom of the airbox and in a protected area!!
Stock filter still works fine and where it is. Some prefer K&N or similar re-usable filter.
Try that before going for bling, unless you really need shiny~
Old 07-21-2015, 10:58 AM
Received 16,260 Likes on 11,971 Posts
short rams are not really an upgrade....
short rams are just a product to get you to spend your money, as all it does is provide hot air to your engine....which is the opposite of what you want to do.
Old 07-22-2015, 10:00 AM
01tl4tl's Avatar
while resonator box removal adds to the stored air capacity for `on-demand use`
by the engine. And doesn't use hot air from inside the engine compartment!
Old 07-22-2015, 12:57 PM
Former Sponsor
ExcelerateRep's Avatar
I definitely recommend looking into a cold air intake. It will pull cold air from the fender to lower intake temperatures and give you better power gains. We have the aem col air intake available for $257.44.
AEM Cold Air Intake - Excelerate Performance - Japanese and European Performance Specialists!!
06TLMatt
10-02-2015 08:14 PM
navtool.com
09-25-2015 05:15 PM
datadr
09-12-2015 09:12 PM
MyGuti
09-12-2015 06:52 PM
Quick Reply: 99 tl short ram question
