06-07 accord trans swap
Old 10-05-2016, 02:46 PM
  #521
Iggy's Avatar
Just finished this project. I've only had it out for a few miles but I'm definately impressed. Smooth crisp shifts and no whine that has plagued me for the last 170k.
The donor was an 07 accord with 54k that I snagged for $1,100.
quick question:
Do I grind out the ribs inside the new range selector cover to make it fit?
Thanks to all!
Iggy
Old 10-05-2016, 05:48 PM
  #522
SuperGreg's Avatar
quick question:
Thanks to all!
Iggy
Same here! That stupid whine is gone. My brother did the range switch cover so I didn't see exactly what he did, but basically he took some angle cutters and just snipped away any bits of the cover that got in the way so it would fit.
Old 10-10-2016, 01:50 PM
  #523
7th Gear
TensorWorld's Avatar
Thanks SuperGreg. I felt really stupid after posting about the neutral switch because despite searching for an hour for an answer I didn't look at the end of this thread where it was described. And you didn't flame me which was very nice.
I just noticed one of the solenoids had it's sensor broken off on the Accord trans and the one for the TL is still good. I checked and the part numbers are the same but I don't know if it's likely to be contaminated and shouldn't be used. Any input would be appreciated.
I will also be sure to post up when I get it started and updates on how many miles I get out of it so that everyone has one more data point. Thanks for everything y'all
Old 10-10-2016, 06:41 PM
  #524
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
^^ Mine also had one sensor broken and I just swapped from my TL without bothering to check for numbers..
They looked identical and it worked flawlessly.
TensorWorld (10-13-2016)
Old 10-15-2016, 03:09 AM
  #525
7th Gear
Okay, update for anyone who want's another data point. Got everything in, filled up the trans, turned it on and it started right up and had no CEL or anything. I was kind of amazed. Then I took it for a drive and one of the CV axles popped out cause I didn't push it all the way in. Fixed that and did a 3x3 change and it seems to run like new. I've bled the brakes and fixing to get it ready this weekend to go for a test drive on the freeway and check high speed but it seems to be just as easy as it's described on here. Didn't even have to adjust the neutral switch. Thank you for this swap DIY and good luck to everyone else.
MarcDavidoff (10-17-2016)
Old 10-15-2016, 06:16 PM
  #526
SuperGreg's Avatar
Nice, congrats!
Old 11-29-2016, 08:09 PM
  #527
WheelD's Avatar
Resurrecting this old thread, I have a 03 TL with low miles thats not going to 3rd gear. Already tried the basics, fluid change 3x, replace tranny filter, clean solenoids & screens, etc. It didnt help
I noticed in this thread all its talked about is 06-07 Accord V6 tranny swap.
My question is will a 2005 Accord V6 tranny work? I can get one considerably cheaper locally rather than ordering elsewhere.
Appreciate an answer.
Old 11-29-2016, 08:42 PM
  #528
MarcDavidoff's Avatar
No sir- only 06/07 V6 non-hybrid
Old 11-29-2016, 09:31 PM
  #529
WheelD's Avatar
any reason why not 2003-2005 Accord V6?
Old 11-30-2016, 12:36 AM
  #530
Skirmich's Avatar
Too close to the same years with defective units, They are running the Blue Bolt transmissions which are the old 3 shaft trans but with a band aid..
06 and 07 are Running the latest 4 shaft design of the 5 speed in comparison.
Old 11-30-2016, 06:30 AM
  #531
WheelD's Avatar
Ah I see, appreciate the replies.
well this 05 v6 Accord tranny came out of a wrecked car with 94k miles, for $200 I might take a chance , can't be any worse than my non working TL tranny right?
Old 12-06-2016, 11:11 AM
  #532
SuperGreg's Avatar
I don't think the 4-shaft was introduced until 2008 for the Accord (2006 for the hybrid model, which we can't use), and as far as I know differs in the solenoids and sensors/etc and is not compatible with our ECU.
BAYA, three shaft (main, counter, secondary) spans 2003-2007. We assume the later years, 2006-2007 have the bugs worked out.
http://www.makcotransmissionparts.co...df/Honda-5.pdf
B79A, four shaft (main, counter, secondary, third) 2008
http://www.makcotransmissionparts.co...g-pdf/BDHA.pdf
Please correct me if I'm wrong, but I don't see how the 4 shaft would be a direct bolt-on.
Old 12-06-2016, 11:17 AM
  #533
SuperGreg's Avatar
I think it depends on how easily you can DIY the job. If you are paying someone to do it, it would make sense to find a newer unit. If you can bang it out in your garage without too much trouble, it's a cheap option that might last a while. Probably would be a good idea to get a new torque converter with the miles on that tranny (get the one for the Accord, not the TL). Just be prepared to replace again.
Old 12-06-2016, 01:54 PM
  #534
Kris9884's Avatar
I read the first several pages but didn't see anything about it. Is there a way around losing the easy fluid steering after the swap? Like, can I ground the sensor or trick it with a solenoid or something? I already have a sports car, I'd rather not have to strong arm the wheel on the comfy daily. Or is it exaggerated and not that bad?
Old 12-06-2016, 07:22 PM
  #535
WheelD's Avatar
yea definitely doing it myself in the garage and dont plan to keep it too long just trying to keep the car for the winter then will be selling it in the spring/summer next year
Old 12-08-2016, 12:17 AM
  #536
Skirmich's Avatar
I cant say either, I was under the impression the 06-07 had the 4 shaft design.
Old 12-08-2016, 12:06 PM
  #537
Kris9884's Avatar
Originally Posted by peewizzle
i like the sportier tightness of the steering but there is no replacement for power steering assist when u are drunk, tired, and driving home hungover from the casino @ 7AM after a long night of shenanigans haha
Drunk driving lol, nice...
But anyway, why does everyone tell the shop its from a different car and scare them off like its a custom one off job? If it's a bolt-on affair they'll never know. It's your own fault for telling them its from a different car and having them turn you away. Just my .02
Old 12-31-2016, 09:43 AM
  #538
WheelD's Avatar
so got the 05 AV6 tranny swapped in, BAYA transmission. Used the Accord torque converter and all, bolted up fine except one small problem. Torque converter bolt holes are off to the TL engine flex plate, looks like the torque converter is physically smaller. I can just see the edge of torque converter threaded holes through the flex plate but they arent lining up fine. I know the torque converter seated in fine.
I should have measured before installing it, now tranny has to come out again.
Anyone else experience this?
Old 12-31-2016, 11:15 AM
  #539
Received 8,584 Likes on 6,630 Posts
Every FAQ I've read says to use the 06-07 transmission. You took a risk using the 05. Aby reason why?
Old 12-31-2016, 12:29 PM
  #540
WheelD's Avatar
it was $200 and only planning to keep the car until may
Old 12-31-2016, 01:34 PM
  #541
SuperGreg's Avatar
I had a weird situation where I thought the holes didn't line up at first when I first got the tranny in, I have no idea what was going on but after rotating the flex plate and torque converter around a bit I found that the holes did line up fine.
Could you post a pic?
Old 12-31-2016, 04:29 PM
  #542
WheelD's Avatar
yeah i've been rotating both as well but it won't line up
see 2 pics
Old 12-31-2016, 07:51 PM
  #543
Iggy's Avatar
That's certainly not a small problem. wonder if an 05 accord flex plate would bolt onto the crank or if an 06-07 TQ will work in that tranny
Old 12-31-2016, 08:16 PM
  #544
WheelD's Avatar
compared some specs between torque converters on RockAuto between 03 TL vs 05 AV6, (DACCO brand), here is what came up:
03 TL:
Bolt Pattern 11.250"
Converter Codes 8 F,PG,PGK,5GA,RF
Converter Type Lock-up
Hub Type 38 Spline pump Drive
Stud Count None
Pad Count None
Pilot Size .945"
Ring Gear Yes
Ring Gear Tooth Count 121
Spline Count 22
Thread Size 6mmX1.00
Transmission Fitment B7TA/B7UA
Mounting Type Mounting Ring
05 AV6:
Bolt Pattern 10.875"
Converter Codes POG,LJ,5,P8A,P8
Stud Count None
Pad Count None
Pilot Size .945"
Ring Gear Yes
Spline Count 22
Transmission Fitment MPZA
also this one, apparently there are different ones made?
Bolt Pattern 10.250"
Converter Codes EA
Stud Count None
Pad Count None
Pilot Size .945"
Ring Gear Yes
Ring Gear Tooth Count 114
Spline Count 22
Transmission Fitment BAXA, MAXA, MPJA, MDWA
Old 12-31-2016, 08:17 PM
  #545
WheelD's Avatar
I know its not recommended when using AV6 Tranny but should I just throw on the old TL torque converter onto the AV6 tranny to get rid of this problem?
Old 12-31-2016, 08:35 PM
  #546
SuperGreg's Avatar
Someone posted before that using the TL's TC will not work, due to some part mismatch but I don't remember the details. I'm really surprised at the issue, you would think somebody would have run into this by now.
Old 12-31-2016, 09:14 PM
  #547
WheelD's Avatar
wonder if 03-05 AV6 transmissions had different torque converters vs 06-07 that's why nobody else has had this problem..
Old 01-01-2017, 08:00 PM
  #548
WheelD's Avatar
to answer my own question I pulled the tranny out again and compared the AV6 torque converter to the TL one, it IS smaller than the TL one! So if anyone is else trying to do swap in a 03-05 AV6 tranny like I am because it was so cheap, you will run into this. Not an issue with 06-07 AV6 transmissions though.
I will try to run it with my TL torque converter and see what happens. I attached the tranny back to the engine and got the subframe back in place. Tomorrow I will try to have rest of the parts back on to see what happens.
this is not my main car and I would not recommend doing what I am doing if you are trying to fix your main car, I am just kind of having fun with it and seeing if I can make it work.
Old 01-02-2017, 12:27 AM
  #549
Skirmich's Avatar
DO NOT DO THIS... As noted from another Ziner the AV6 TC is smaller in depth so the Transmission Bell Housing is smaller in consequence..
Using the TL TC will fit but will press against the Bell Housing and input shaft, Starting the car with that setup will destroy the transmission bell housing.
The 06-07 AV6 TC should fit no problem, I bought a Remano unit (2007) and it bolted right in no problem.. Looking at both TCs side by side you should see the size difference and why the TL unit should not be installed in the AV6.
Old 01-02-2017, 03:02 PM
  #550
WheelD's Avatar
Replying to your "TL TC will fit but will press against the Bell Housing and input shaft," if that is the case, shouldnt I hear a rubbing noise? I mean I spun the engine over several times by hand after the install and did not hear any noise where the torque converter is interfering with anything nor was the engine difficult to spin as if there was any interference anywhere..
Old 01-02-2017, 05:13 PM
  #551
Skirmich's Avatar
How did the TC spin without being bolted to the flexplate? or You mean the TL TC in the AV6? Beats me, I did it the right way! So I dunno exactly how it gets damaged:
You should go back a couple of pages and look for the Aziner reply, He even posted pictures of the damage.. If it isn't here its in another of the AV6 Swap Threads..
Old 01-02-2017, 05:54 PM
  #552
WheelD's Avatar
When I added the TL TC to the 05 AV6 tranny it spun fine, didn't make contact with anything. Even when I joined the AV6 tranny back to the engine it still spun fine.
What it appears is that 03-05 AV6 is different than 06-07, in which the TLs TC will cause damage. I didn't get a chance to work on it today but so far I don't see it damaging anything
Old 01-12-2017, 09:16 PM
  #553
WheelD's Avatar
I wanted to update everyone and to say that I have successfully completed this project. The car shifts so smooth now there is no comparison to the old TL tranny. I want to thank all of you for answering my questions and all the resources this forum offers.
To sum it all up this is what I am using:
- 2005 Accord V6 BAYA transmission
- 03 TL torque converter
- 03 TL wiring harness swapped over
- 03 TL transmission filter swapped over
- currently running Valvoline Synthetic MAXLIFE ATF
Old 01-12-2017, 11:07 PM
  #554
SuperGreg's Avatar
Great! Good job man.
Old 01-15-2017, 12:29 PM
  #555
4th Gear
vmdigioia's Avatar
Located 2006 AV6 for my 2003 Acura TL
Hello,
I located and purchased a 2006 Honda Accord AV6 auto transmission; my 2003 Acura TL with 138k transmission just started to slip and exhibit all the problems this forum pointed out.
I purchased the Acura from Rosenthal Acura Gaithersburg Maryland for my son last May with 135k and I was assured the transmission was updated; well -- . . .
I have my local shop in Frederick Maryland preparing for the install;
1. I am printing the instructions
2. I am reviewing the parts I need to order or have my shop order -- can I verify these parts?
3. Asking my shop to order a new honda accord AV6 TC and take care of the core deposit
Anything else???
Old 01-15-2017, 02:13 PM
  #556
SuperGreg's Avatar
Originally Posted by vmdigioia
Hello,
Anything else???
Check "what do I need" section here for a pretty full list: Havener Garage: The Definitive 2nd Gen Acura TL AV6 Transmission Swap Guide
Old 01-15-2017, 04:53 PM
  #557
WheelD's Avatar
yes that is a very good guide. But before you begin ordering anything go back to the Acura dealership where you purchased the car the year before and see if they will do anything for your since they did say the transmission was "updated."
Old 01-18-2017, 02:46 PM
  #558
4th Gear
vmdigioia's Avatar
Okay -- I have a hold on the transmission --
These are the codes from the car: P1750 p0505 p1298 (D5 is flashing with the other check engine light on and the TCS light on).
I spoke to Rosenthal Acura -- it is a joke -- no warranty, -- I looked at the bolts on the transmission -- they are not 'blue' -- I asked for a mechanics report -- this is a one owner car -- no help from Rosenthal at all.
Old 01-18-2017, 03:26 PM
  #559
WheelD's Avatar
I hate dealerships like that, it seems you are pretty much on your own. Only one of your codes is transmission related, which, if you are lucky, could just be a dirty solenoid screen.
Other one is idle control issue? Is the car running rough? Last code is concerning your electric charging system, could be a short somewhere or blown fuse? Kind of weird having all these 3 different codes at once, might be something related.
Old 03-16-2017, 02:37 PM
  #560
9th Gear
Willis801's Avatar
Heater swap question
Just picked up my 07 accord trans and i have a question is it necessary to swap the heater on top of the trans to the accord because in one write up it says yes and in the havenergarage instructions it says nothing about the heater being swapped? Thanks
Quick Reply: 06-07 accord trans swap
