00 TL stuck in park!! and no brake lights
hi i am new to this site and thanks for taking the time to read my post.
problem: car will not shift out of park unless i press the override switch next to the shift lever. once the car is out of park i have no brake lights. i have checked the fuses, but all looked good. could it be the brake light switch or something else?
Brake switch most likely.
fuse `looked` good? they either pass electrical test, or you insert a spare
thats how to be sure its working~
the brake switch gets loose or wears out,,easy diy,,aftermarket part ok
assuming ALL- that's each and every bulb in the back is working- its usually the switch at pedal
Can be loose screws and out of adjustment, or simply worn out from 15 years of use
Easy DIY
also when its a bulb failure there should be a brake LAMP warning on the dash
Easy DIY
mada51589
05-03-2022 08:54 PM
