My 2017 RDX Tech AWD has sucked so far....5700 miles.
Old 07-25-2016, 06:30 PM
Fuct in the hed!
Nicky Pass's Avatar
Well.....at 1350 miles, my brakes squealed, they serviced them.
At 4300 miles they squealed again....I took it in at 5300 miles,,the scuffed the pads and resurfaced the rotors.
At 5500 miles i go over a bump and it sound like someone left a couple of wrenches in the engine compartment....the drivers side shock is bad!
Not Acura's fault...I had my two front windows tinted and the dealer swore by this guy and he did a horse shit job! now they have to redo them.
needless to say, the first 3.5 months of ownership has sucked....
Old 07-25-2016, 06:52 PM
Brown13's Avatar
At least Your Street Glide runs fine,with no brake squeal.I have a 14 Limited that rides over cracks in the road smoother than My 2013 Acura RDX Tech.
Old 07-25-2016, 07:38 PM
matman1215's Avatar
I have a 2017 with just over 4,000 miles in 7 weeks. Had it in at 1,100 miles for brakes squealing. They resurfaced my rotors and that night, no noise. Next day, squealing again and have continued squealing since. Haven't brought it back yet but need to. Are yours still squealing?
Also, really annoying rattling noise coming from my dashboard on driver side. Can't pinpoint what it is yet...
Old 07-25-2016, 07:46 PM
Fuct in the hed!
Nicky Pass's Avatar
I had it for 3 days after they resurfaced the rotors before it sounded like the front spring was broke! In those 3 days, they've been quiet....so far.
Old 07-26-2016, 06:15 AM
colt427's Avatar
That sucks when you have issues on a new vehicle.
No brake noise issues on my '16 but a lot of cabin noise with ride quality.
Tire thumping noise over bumps, loud hard suspension (especially the rear) over bumps and some wind noise.
Passenger friends and relatives notice the hard and noisy ride quality too.
I even lowered tire air pressure to 32.
Unless Honda fixes that issue, no more RDX' s for me.
Other than the suspension issues, it's a very nice vehicle.
Old 07-26-2016, 07:41 AM
alexderaven's Avatar
Thanfully no brake squealing on mine. As for your rattling noise, I have that too. It's a known issue they have a TSB out for it. The leather wrap in the steering wheel rattles a bit, their solution is to trim it under the center cover. Think I'll have mine fixed at the next maintenance appointment.
Old 07-26-2016, 01:21 PM
matman1215's Avatar
Good, thanks for the info. on the TSB. Will have them look at it at my first maintenance appointment. It drives me nuts!
Old 07-26-2016, 03:04 PM
chickdr's Avatar
That is one of the most annoying noises ever. What I don't get is why are they still making the steering wheels without trimming the leather per the TSB. Why don't they make a running production change?
Old 07-27-2016, 08:19 PM
Fuct in the hed!
Nicky Pass's Avatar
Well....
The two front windows were retinted and this time it was legal and it looks really good!
the front drivers side strut was bad! That was the horrible noise I was hearing over bigger bumps! I can't believe that a front strut would,go bad at 5500 miles....but I guess anything is possible.
Time will tell if the brake squeal comes back or not....
The next coarse of action is to replace the front pads and rotors, so we will see. I hope I'm done with have issues!
Old 08-02-2016, 06:01 AM
Rolf65's Avatar
2016 RDX 3500 miles: loud thump from rear cargo area when go over bumps in the road; excessive wind noise in cabin when driving on the highway; "hard" ride - feel bumps in road; no brake squeak, however.
Old 08-02-2016, 01:36 PM
colt427's Avatar
Same here!
Old 08-02-2016, 01:47 PM
Received 16,260 Likes on 11,971 Posts
AS soon as a shock recieves load, it's life starts to decline.
you will also have blown shocks from the factory. its hydraulic.
It can happen.
Ive had hydraulic jacks fail on me before. luckily i've always used jack stands
Old 08-04-2016, 07:18 PM
chickdr's Avatar
Our "adventure" continues. After having to take it back twice to get the steering wheel creak addressed(had to actually drive around with a CSR to get them to hear the issue) today we were told they fixed the problem for good. My girlfriend picked it up and the creak was still there after 1 mile of driving. Seriously? They can't even get this right. Back to the dealer she went and back into the RDX loaner she had. At least it isn't creaking. I will be contacting the dealership GM again tomorrow.
Old 08-06-2016, 07:51 AM
chickdr's Avatar
Finally a good ending to the story for now. I had to get the GM involved, but the steering hub squeak is gone. They also swapped the front brakes while it was there. The sad thing is it took three visits and me escalating to get it done.
Old 08-08-2016, 11:38 AM
012TL-GLM's Avatar
sorry to hear of the issues OP - seems like Acura went backwards hearing more issues with the 17's than the 16's - we got our '16 Advance as soon as the dealer got them in stock. No issues after a year and 9K miles. Only quirk is the front parking sensors occasionally go off when at a red light but I typically find they don't misbehave for quite some time after a bath, so must be sensitive to grime build-up between washes
Old 08-08-2016, 12:54 PM
Rolf65's Avatar
Forgot to mention that the small gas tank capacity (12.5 gallons?), which means more frequent trips to the fuel pump, is maybe the most annoying part of the car. By comparison, my Mercedes E350 holds about 19 gallons.
Old 08-09-2016, 01:03 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
The gas tank is about 16 gallons, not 12 and a half. Still not huge but not tiny. Current E's have a 21 gallon tank.
Old 08-09-2016, 04:57 PM
Rolf65's Avatar
I'll re-check with the next fill-up, but 12.5 usually fills my 2016 RDX tank, as I recall. My E is 2008.
Old 08-10-2016, 08:08 AM
chickdr's Avatar
From Acura's web site:Fuel Tank Capacity
  • 16.0 U.S. gallons (60.5 liters)
Maybe you aren't running it to empty?
Old 08-11-2016, 09:17 AM
ceb
ceb's Avatar
Your E is about 20.5 gallons
If you're putting 12.5 gallons in then you still have 3.5 in the tank - so about 80 miles or so to go
Old 08-13-2016, 04:38 PM
Rolf65's Avatar
Refilled car this morning: low fuel warning light came on, range was listed at 32 miles, and gauge was at the 1/16 mark (i.e., last mark before empty).
Car took 13.2 gallons to fill.
Old 08-13-2016, 07:38 PM
vbgregg's Avatar
When the low fuel light comes on, you typically have another 2.5 to 3 gallons in the tank. I assume they do this in an attempt to help people from running out of gas.
Gregg
Old 08-13-2016, 10:34 PM
RDX10's Avatar
Gregg
What good is a "warning" if it occured after the fact? Sort of like a fire alarm going off after a fire has consumed your house. So naturally it comes on BEFORE you are out, not after haha.
Old 08-14-2016, 07:42 AM
Rolf65's Avatar
Gregg
I agree and the amount needed to refill the tank supports that. The fuel gauge showing 1/16 and the low range are what are confusing.
Old 08-14-2016, 08:13 AM
quantum7's Avatar
I read somewhere that the low fuel warning is designed into the cars....especially those for the American market. No doubt to avoid stranded drivers.
It can be annoying, but probably good to force me to refuel. My TL shows 0 miles but when I compare fill amount and capacity they are 3 gallons apart.
Old 08-14-2016, 08:50 AM
vbgregg's Avatar
Obviously a warning must occur before and not after the event if it's to be useful. The question is: how much before? My point was that the warning comes on much earlier than many people might have guessed (me included). I might have expected that it would come on with only 1 gallon left in the tank, for example. So I was surprised to find out that it came on with more like 3 gallons left in the tank.
Old 08-14-2016, 12:35 PM
RDX10's Avatar
No I understand and agree with you. My point is just that I prefer to have the advanced warning rather than when I only have a little fuel left because it gives me time to find a gas station. That being said, I am always aware of my fuel level and don't count on the warning to refuel.
Old 08-14-2016, 03:12 PM
Rolf65's Avatar
The issue with the RDX seems to be not knowing how much gas remains a day or so after the light comes on as the gauge and the range estimate apparently aren't true.
My Mercedes does it best: there's a "reserve fuel" message and a light that begin somewhere slightly less than a quarter of a tank. When I see those I think about getting to a station within the next few days, if I am around town, and getting to a station asap, if I am highway driving. If I neglect to heed those warnings, then there's a second message (I cannot remember the wording) that comes up when I have probably < 10 miles range remaining. When I see that, I quit messing around and immediately go to the nearest station.
justinjsw
11-07-2023 07:42 AM
EE4Life
09-01-2023 11:05 AM
AcuraGuy2016
09-24-2016 07:00 AM
TSX69
09-06-2016 04:23 AM
EE4Life
06-27-2016 06:19 PM
Quick Reply: My 2017 RDX Tech AWD has sucked so far....5700 miles.
